EOT meter for OEM oil cooler
uscgmac_imp Offline
Threads: 23
RE: EOT meter for OEM oil cooler
#41
You lost me a long time ago when I got to the make a long story short part, then I saw pages more of paragraphs. So I guess you were trying to say you put a fan on an air/oil cooled bike. Now it doesn't run as hot. That's kinda short and to the point. Lol.
I would say Honda already did all the engineering, you should just ride and enjoy. With all the time spent on this you could have already been in your second oil change. Don't worry and just ride. Their are air cooled engines probably older than you are still out there running just fine.
06-21-2016, 07:04 PM
dsinned_imp Offline
Threads: 22
Independent research shows . . .
#42
http://www.haydenauto.com/featured%20pro...ntent.aspx
06-23-2016, 12:35 PM
Ulvetanna_imp Offline
Threads: 78
#43
Think of it this way: the earlier inline four air-cooled engines did pretty well without even having an oil cooler. We just changed the oil more frequently to insure it was doing its job.
Adding the oil cooler to the engine has already accomplished the thing you are trying to do by adding a fan to the oil cooler. The oil cooler itself extends the life of the oil. You don't need a fan. It is gilding the lily.
06-24-2016, 12:28 AM
dsinned_imp Offline
Threads: 22
#44
Agreed, however, it did little to guard against "undesirable" EOT excursions in stop and go traffic.
06-24-2016, 03:16 AM
dsinned_imp Offline
Threads: 22
#45
Since I started this thread, I've only heard from one other forum member (privately) who did the same Trail Tech meter mod to his CB1100. That sort of surprises me. This is a relatively inexpensive ($43) and inconspicuous temperature meter, that is easy to install and easy to use.
No matter how you slice it, this little device provides useful information on an important engine operating parameter (oil temp). For example, when riding on a really hot Summer day, and/or two up, thereby putting an extra heat burden on the oil cooler, wouldn't you want to know if your engine is on the verge of overheating? If nothing else, such information is "educational". LoL
I've been using my Trail Tech temperture meter for the last several hundred miles and it works flawlessly. It works so well, I have another Trail Tech meter on my 2015 Triumph Bonneville T100.
I also added fans to the oil coolers on both my air cooled bikes, which have been beneficial, even though many of you feel that is unnecessary. I'm not advocating doing that to a CB1100, due to a safely concern with the front suspension brought to my attention by one of the members here. However, I do feel EOT "monitoring" is still very worthwhile, and certainly one of the simplest possible mods that can be done to the CB1100.
Btw, I'd be interested in hearing from anyone else doing this mod. How did it work out? What is the highest EOC temperatue you've measured and under what circumstances?
07-21-2016, 08:36 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
#46
There was quite the after market oil cooler thing going on in the late 70' early 80's as folks added oil coolers to their inline fours. No one that I was aware of added a fan though. But cars were just getting on demand fans for their radiators so I'm sure the thinking was not that far along.
For the folks that don't quite see the usefulness of this, ride in southern California or Arizona in the summer and the light will come on. Or you'll switch to your car until sane temps return. Big Grin
07-21-2016, 09:16 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
#47
Dsinned, don't keep us in suspense, what temps have you seen on it? I also agree that more info is always a good thing.
Rboe, are you saying you have seen the overtemp light come on? No one has reported that so I though you out West guys were good.
07-21-2016, 09:43 AM
dsinned_imp Offline
Threads: 22
#48
Rboe, in the Summer heat of the Southwest, I can well imagine the usefulness of this mod. "If" its true that the CB1100's engine overheat warning light turns on at whooping 340F! That would be like Three Mile Island only having a Rx scram when there is a thermal runaway core temperature pegged in the red zone!
Popgun, based on my empirical test results, I realized nearly 30F reduction in peak EOC temperature with a suitable "pusher" type fan running vs. no fan (stock) under a slow paced, continuous uphill riding situation. However, as expected, at higher road speeds, like on the freeway, there is not that much of a significant difference.
The TT EOC temperature monitoring capability is still a very worthwhile accessory to have on ANY stock, air/oil cooled bike.
07-21-2016, 10:10 AM
Lord Popgun Offline
Virginia
Likes Given: 136
#49
Dsinned, I forgot where the other thread is and didn't feel like looking for it Smile
Anyway I rechecked the dimentions of my test strip and found that 10mm will not fit. So I had to go with 8mm and ordered the TrailTech with that size. If nothing else, it should be fun to play with and hopefully give some meaningful information. Maybe it will show up while the big heat wave is on.
07-25-2016, 11:10 AM
Lord Popgun Offline
Virginia
Likes Given: 136
#50
The Trail Tech temp meter arrived today. I haven't installed it yet, but here are some comments. It is pretty small so should not be hard to mount by the big fork nut (I will have to move my power connector).
The 8mm sensor fits perfectly. I got the longest wire and it looks plenty long.
The instructions say that to set different modes or C or F reading, to press the (little blue) button on the back. That does not work. After calling tech support, I was told to use a ball point pen. I used a toothpick. You have to press the button a ways below the surface of the back of the unit.
The sensor is connected to the meter with a connector so if desired, you can use different length/size sensors. Or replace a messed up one.
No ride tests yet, I'll have to think about mounting. The meter will mount either with a sticky they provide along with some screw hole plugs, or you can screw it down. You have to provide your own screws.
08-01-2016, 09:04 AM
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 2 444 04-14-2025, 05:16 PM
Last Post: deuce17EX
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 11 935 04-11-2025, 02:41 PM
Last Post: rdprdp01
  Soft cooler for Djangos trip Frulk_imp 7 464 06-02-2019, 06:22 PM
  Oil Cooler Guard Chris Goldson_imp 10 856 11-09-2017, 11:41 AM
Last Post: Dvassino_imp
  2013 Meter covers Uberjason_imp 6 506 02-16-2015, 12:32 PM
Last Post: rboe
  chrome meter covers for 2014 Dlx ss2wheels_imp 9 515 05-09-2014, 01:11 AM
Last Post: Ridem32_imp
  Aero Bobbins and Cooler Guard Tyke57nz_imp 5 429 03-02-2014, 01:04 PM
Last Post: Tyke57nz_imp
  Dart fly screen bracket issue with chrome meter covers Elipten_imp 2 241 01-21-2014, 01:07 AM
Last Post: Bayoucityrider_imp
  Chrome Meter Covers Added Guth_imp 10 684 10-13-2013, 01:41 PM
Last Post: wildezt_imp
  Oil Cooler enzo_imp 11 701 09-10-2013, 07:11 PM
Last Post: enzo_imp
