Where to tap speed sensor signal?
SportsterDoc Offline
New Mexico
Threads: 33
Likes Received: 43 in 22 posts
Likes Given: 6
RE: Where to tap speed sensor signal?
#41
(07-08-2018, 04:11 AM)PowerDubs_imp Wrote: I'm going to tap the pink/white wire off the rear wheel sensor later this afternoon and hope for no puffs of smoke from the ecu, power commander, dash, etc... Wink
I do keep a fire extinguisher in my garage!
(but, I only used one at home once, for a carb issue)
Be interesting to know the voltage range.
07-08-2018, 01:12 PM
egleaves_imp Offline
Threads: 11
#42
Not yet. I spent too much time doing other things this weekend. Now I'm interested in hearing the results of PowerDubs stab at this wire before I mess with mine.
07-09-2018, 02:57 AM
New Mexico
Threads: 33
Likes Given: 6
#43
(07-09-2018, 02:57 AM)egleaves_imp Wrote: Not yet. I spent too much time doing other things this weekend. Now I'm interested in hearing the results of PowerDubs stab at this wire before I mess with mine.
So, you are admitting that PowerDubs is braver?!
07-09-2018, 09:13 AM
PowerDubs_imp Offline
Threads: 125
#44
Local hardware store didn't have any posi-tap or comparable.
Placed an order from Amazon- experimentation will have to wait a couple days.
Sorry.
Here is what I am trying to do-
07-09-2018, 09:29 AM
Threads: 11
#45
Many people are braver than me when it comes to electrical work. I'm much better at being a plumber. Big Grin
07-09-2018, 10:02 AM
New Mexico
Threads: 33
Likes Given: 6
#46
Humor response award to you!
I hate plumbing...dealing with leaks...much rather keep the smoke inside the insulation!
07-09-2018, 10:11 AM
Threads: 125
#47
I'm no electrician. I'm much more mechanical in nature.
I have zero fear of mechanical things, and zero mechanical sympathy.
Makes for interesting hobbies when I have a lift in my garage.
12 cylinders are fun. I'm just not rich enough for a Veyron.
07-09-2018, 10:20 AM
Threads: 125
#48
Tapped into the white on the rear speed sensor (changes to green/pink under side cover.)
Put my meter on it, dcv setting, other lead grounded to a screw. Started bike on center stand and put it in first. No reading.
Thoughts?
07-14-2018, 06:18 AM
peterbaron Offline
Likes Received: 620 in 338 posts
Likes Given: 1,057
#49
My schematic, after 2013, NO ABS
Exclamation ASSUME there is NO carbon wire sealed to connector's end.ExclamationExclamationExclamation.
What is the DC voltage reading to OEM connector of RWSS = 2 pin connector - blue and white- back-probed, rear wheel spinning in a gear, while speedo showing speed...voltage will vary while speed changes, please
What are you talking about other lead grounded to a screw..what SCREW?????????
Do you have any electrical knowledge???
07-14-2018, 06:53 AM
Threads: 349
Likes Received: 941 in 515 posts
Likes Given: 1,107
#50
(07-14-2018, 06:18 AM)PowerDubs_imp Wrote: Tapped into the white on the rear speed sensor (changes to green/pink under side cover.)
Thoughts?
You need a new meter? Tongue
07-14-2018, 06:56 AM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,559 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Turn Signal Indicators balkanhound_imp 5 787 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,822 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Negotiator-S Speed Pulse Modulator? TonyJames_imp 18 2,169 11-14-2022, 04:50 PM
Last Post: rich_imp
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 1,003 05-15-2022, 11:42 AM
  auto tune 02 sensor outback_imp 18 1,631 03-16-2022, 07:48 AM
Last Post: outback_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 3,060 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 847 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 1,088 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 865 02-20-2020, 10:22 AM
Last Post: Ben70_imp
