Cylinder Plating?
#41
(02-17-2014, 12:31 PM)Dakota_imp Wrote:
(02-17-2014, 11:33 AM)Red Mist_imp Wrote:
(02-14-2014, 11:37 AM)Dakota_imp Wrote: Hi Dakota.
Electroplated cylinders bored into the top half of the crankcase, as opposed to a distinct cylinder block, which is then bolted to the top half of the crankcase. Honda was the first of the Big-4 who started doing this, and they touted "lighter weight", "reduced gasket interfaces", "17% stiffer", etc.
Honda now does this to nearly all of their sportbike lineup, but it's not a good idea IMO, and here's why: when you wear out a cylinder block, you can replace it--just bolt a new one on, replace the piston rings and a few other parts. But when you wear out the cylinders bored into the top half of a crankcase, you must replace that entire crankcase, the crankbearings, and many other non-transferrable parts--essentially the entire engine.
Crankcases are drilled and finished as sets, so you cannot simply replace the top half.
OK. I am on the same page now. It may be semantics, but the crankcase is the structure surrounding the crankshaft. The cylinder barrel is what houses the piston. The engine block is the combination of the two.
Many aftermarket companies offer sleeves for motorcycles. I don't understand why you couldn't have bored the original engine and installed one? Even my lowly B&S push mower has an iron sleeve. Only the cheapest garbage mowers have parent bore engines with no sleeve. This is not a dig against your bike; I am sure that they designer used something to increase wear life. But, it seems to me that iron would be the best...
If a sportbike has a high piston speed, it will wear out faster than similar motorcycles with lower piston speeds.
(02-13-2014, 11:17 AM)Rboe_imp Wrote: Honda has made some "blunders" with oiling with its' engines over the years. The original V4's, V45 and V65 needed extra external oil lines to keep the cams happy. You guys may know of more examples. So I would not discount that they make design errors from time to time and simply cheapen the product.
What really bothers me is that there is NO excuse for this. I am a degreed engineer, have owned GM vehicles my entire life, and have models spanning from '47 to '06. I have an interest in engine development history and read SAE journals for fun at night to clear my head. Much of what is good engineering practice was known for a long time but GM never seems to learn their lessons and has always lagged far behind state of the art engineering practices. And, they do it because they can. People will continue to buy garbage because the outside is shiny and the inside smells new.
GM and Ford can't seem to build reliable ignition switches and we are going to trust them with drive by wire steering???????
Have a couple of new 2013 drive by wire (electric steering) Chevys in the family: A Sonic and Equinox. Also have a Toyota Venza with electric steering.
The Chevys have got it down. They work very well. Toyota is good too, but tends to hunt a little more. Has a little more of a mind of its own.
Now the new Tahoe also has electric steering. It's the future. No hydraulic leaks and you don't have to back off at the limit to prevent it from howling.
I guess that I've had a bit less than good luck with my vehicles and my confidence is low. I have NO idea what to purchase when it is time to replace in a couple of years.
[/quote]
I'm in the opposite boat. I've been driving the same Nissan truck for 15 yrs. and it's needed two repairs in all that time (not counting consumables). I've had my Nighthawk 750 for 18 yrs. and it has also needed two repairs, but both of those were because of things that I broke.
The one thing that made me nervous about buying the CB11 was, with it's increased complexity (computers, etc...), would it be as reliable? Time will tell.
In order for the universe to balance out, on the other end of the spectrum is my 1968 Piper airplane. It consumes an average of $4K in parts and maintenance every year.
[/quote]
In order for the universe to balance out, on the other end of the spectrum is my 1968 Piper airplane. It consumes an average of $4K in parts and maintenance every year. Hah! But how cool is it to have your own plane? That's priceless. Worth every penny. What model is it? PA28?
(02-19-2014, 01:36 PM)Dakota_imp Wrote: Popular literature says that the big three have gotten better; the engineering forums say that the imports have gotten worse.
I have a 2002 Dodge ram 2500 with the 5.9 Cummins purchased new. Having previously owned a Chrysler car which was a POS, I only purchased the dodge ram because dodge had nothing to do with the drivetrain. The Cummins has a great reputation as a durable engine. Looked at objectively, it is an economy diesel engine. I am currently at ~82k miles. I had to replace the injection pump and lift pump at 60k miles. Not typical, but unheard of. I have kept up with antifreeze replacement and used long life, diesel antifreeze; the heater core is leaking. I have to put in refrigerant every spring to get cold AC. I had to put in all new brake shoes and rotors last year. The original pads swelled up, disintegrated and wore out the rotors. Seems like a lot of repairs for less than 100k miles. I very rarely tow with the truck but when I do it sucks down fuel with impunity.
My GM vehicles are all far worse. Lots of leaks. GM's wonderful combination of dexcool and plastic lower intake manifold gaskets. Worn out tie rod ends. Poor brakes. Radio digital encoders that quit working. Heater motor resistors. Etc.
GM sucked before the crash. When the government bailed them out, there were a lot of strings attached and they really reshaped their entire way of doing things.
I would never have believed I would own an "all-GM" fleet but that's how it worked out. Not a single hiccup from any of them and owner satisfaction is 100 percent.
A buddy is in the auto industry selling O-rings of all things. Well before the crash Ford and GM were making very good vehicles but public perception had not caught up yet. My 2007 Ford tends to bear this out (I've had less luck with Chrysler and Volkswagon). Our new Subaru, knock on wood, has been very very good too. Smile
[/quote]
Yep, it's the Cherokee 180 that you can see in my avatar, if you squint a bit Wink . And when the alternative would be not having a plane, you're right, it's worth the money.
[/quote]
Yep, it's the Cherokee 180 that you can see in my avatar, if you squint a bit Wink . And when the alternative would be not having a plane, you're right, it's worth the money. Not having a plane? Forget that, if you're a pilot, you need a plane!
(02-14-2014, 06:30 PM)calamarichris_imp Wrote: Heh--regulator/rectifryer.
Does the VFR have a primary chain between the main crank and the tranny? Most V-twins do. The V-four is not as unbalanced as a V-twin, and do you know if the VFR has electroplated cylinders bored into the top half of the VFR's crankcase?
Your VFR is not burning any oil at all?
The wear was the leading and trailing (front back edges) of my VTR's cylinders. They were more than TWO millimeters out of round--pretty much zero compression.
The cams on my 1998 VFR800 are gear driven, which makes valve adjustments much quicker and easier. The top half of the crankcase has pressed-in steel sleeves. 92,000+ miles and it does not burn any oil.
(01-31-2014, 01:27 PM)Rboe_imp Wrote: After 250K the fasteners are completely frozen.......Angel
Very good remark Rboe. Could essentially be a throw-away engine. Undecided
  Clutch slave cylinder gasket Maturecheese_imp 3 400 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  Chrome cylinder head cap Juancho76_imp 21 1,758 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  1 cylinder running rich? frank_imp 33 2,250 01-05-2021, 10:35 PM
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 659 09-01-2020, 12:19 AM
  Key Cylinder Spins Freely deltamark 16 1,184 10-28-2019, 11:06 AM
Last Post: Chuckk_imp
  Help with Master cylinder seals any help please dsan1964_imp 10 726 10-30-2018, 11:32 AM
Last Post: dsan1964_imp
  cylinder lining or coating? 3rdbike_imp 3 380 12-03-2017, 11:09 AM
Last Post: 3rdbike_imp
  Looking for a Speed bleeder P/N for Clutch Slave Cylinder venturer434_imp 6 952 10-14-2017, 09:01 PM
Last Post: venturer434_imp
  Cylinder head cover discoloration LongRanger_imp 15 998 09-23-2016, 08:38 PM
  CAP CYLINDER HEAD SIDE - sticks out, worry? Riko_imp 11 767 04-18-2016, 04:46 AM
Last Post: Riko_imp
