Oil Change Time!
#41
I treat my CB1100 better as it deserves and specified in the Honda manual.
As a return, she serves me fantastic without any failure so far. Period!!
(08-30-2020, 08:04 AM)SportsterDoc_imp Wrote: InMy Moto Guzzi had a separate sump for the transmission and also had a dry clutch; but I did not use automotive oil to lubricate the engine for at least two reasons:
1. There are additives / detergents in automotive oils that may not be good for a motorcycle engine.
2. Automotive oils have less zddp.
https://www.rymax-lubricants.com/blog/ca...cycle-oil/
Same with my Can-Am Ryker. It has a separate transmission sump for forward-reverse (ratios change by CVT) and no wet clutch.
Also, 10W60, as specified for the Moto Guzzi and 10W50, as needed for the Ryker at temps above 104 F may be difficult to find an automotive oils.
As for 0W20 or even 5W20 oils, there are many automotive manufacturers having serious oil consumption issues with their engines for which of these weight of oils have been specified.
Changing oil on an air-cooled motorcycle at 3,000 miles can be beneficial.
Using pure synthetic oil is most likely beneficial.
Using oil filter without a bypass valve is questionable.
Using automotive oil to save a few dollars may be costly in the long run.
Sportster Doc, I read the Rymax link you sent. Thanks for the link. Here is my commentary.
They point to two reasons that point to the formulation differences between car and bike that their warnings are based on:
1) Car oils have friction modifiers
2) Car oils have detergents
So, looking back in this thread I pointed to the API symbol, and according to my understanding, you do not want to use car oils that have these. I have personally had to change my clutch plates after using car oils with friction modifiers that caused my friction plates to slip. I suppose Rymax might call this "major motorcycle damage". So, you do not need to convince me on this one. That clutch pack change was on a Honda '88 Hawk GT I had two decades ago. That was a PITA! Ever since then, and having learned my lesson, I have never used car oil with friction modifiers. You must avoid any oil that says "Energy Conserving, or Resource Conserving". It is my understanding, and also my experience in the two decades since (and many, many oil changes on many, many brands and engine configurations: twins, inline 4's, V-4's). I have NEVER had a problem since. I would consider that last statement as anecdotal evidence from one person on a board.....Some modifier ingredients could include Teflon. There are also likely others I cannot list or name as there are many proprietary formulations that are not divulged. In short, don't use them. Their warning says "Using the wrong oil can seriously damage your motorcycle." If you use synthetic oil (w/o friction modifiers that could impact your clutch), then both motor and gear box should be happy as they are well lubed and protected from wear.
The second detergents..."that could result in formulation of deposits on piston crowns and as well as the valve train".
Ahem. I am sorry on this one. As far as I know, there is nothing inherently different between car and motorcycle pistons or valvetrains, or inherently different in their basic Internal Combustion Engine construction. If I am wrong here, please tell me where. Seriously, I don't know everything and could be educated. I mean that respectfully.
There are some m/c specific designs you generally do not see in cars, like the desmodomic valve actuation system used by Ducati, or in cars (mostly abandoned push rod actuation....but still used by Harley). Maybe someone can explain to me the inherent significant difference in a piston designed for use for a car, and one for a bike. They all run the gamut in terms of compression ratios, but most now in either category are made of light-weight alloys with coated cylinders. Many in either have variable valve timing schemes. Most have chain driven overhead cams for valve actuation in either.
The warning on detergents "these could result in the formation of deposits on the piston crowns as well as the valve train. Because detergents are the main cause of pressure build up, this will cause perforation and burning on the components".
I am sorry and am going to call BS on this one and point it to marketing. I will call "true" to the friction modifiers. Don't use oil that has them. So detergents don't cause damage to car piston crowns and valves, but they do on bikes? Also, I thought the point of detergents was to avoid build up on components. I look at it like this. If deposits form on pistons, then they can heat and cause preignition resulting in damage. But I thought detergents help prevent this. I call this marketing with frightening statements to corral us. That's me though and all IMHO.
Interestingly, on the Guzzi threads, some there are lamenting the use of Motul and other Racing oils because of their lack of detergents!
In terms of Zinc dialkyldithiophosphate (ZDDP), zinc and phosphorus used as an anti-wear agent, those have been phased out of motor oil formulations in recent years because the zinc and phosphorus found in ZDDP can negatively affect catalytic converters. From Amsoil "classic-car owners having older vehicles with flat-tappet camshafts and, in particular, engines that include high-tension valve springs or other modifications that create high contact pressures, can suffer premature wear due to reduced ZDDP levels". So those guys want that.
TO ME, don't buy oils with the wrong API symbol. I used photos to show you (MY understanding) of a right one and wrong one.
One last wrt to your 10W60. Wow, that is oddball. wildguzzi and guzzitech have lots on that. If you are worried about shear taking down the weight to 40W-50W in only 1-2K miles, I might just change more often. The Mobil-1 20W50 is $4/q. That oddball 60W is $15/q! What is the recommended change interval? How much effort is it to do it?
In the Wildguzzi thread on the 10W60, SmithSwede says:
"Great psychological analysis of oil threads! I'd add one other point---it is an interesting psychological fact that people worry so much about oil, and "protecting their engine," when the vast majority of them don't get anywhere close to using the normal service life of the machine.
If you are only going to run the bike 10 to 30,000 miles before you sell it for something else, it probably doesn't matter that much what oil you use if it's decent quality and at least close to the recommended specification. For these people, the engine isn't going to wear out in any meaningful sense---you are going to divorce it long before you could perceive any differences between Oil A versus Oil B.
Seems to me that the only people who should rationally obsess about the subtle nuances of tribology are people who really do plan to run the engine 200,000, 300,000, or more miles. There probably are a few such people on a Guzzi forum; not so much on a Ducati race bike forum. "
LOL.
One maybe last post on this very old and possibly tired topic.
In the end, it may be best to just do whatever it is that gives you comfort you are doing the best job possible to protect your investment (ahem, depreciating asset) and what makes you sleep well at night.
Some of the stuff you see from me is based on a fact that I am an extremely frugal person....in a sense, in that I like to do things myself and save money (including things like buying cheap sets of quality tires at sale prices in Winter, and mounting/balancing them myself), and also trust in my own mechanical expertise, that there are a great number of fine details I will take that a paid mechanic will not. Case in point is cleaning my case with a brush till new, no paid mechanic will do. I do this when addressing my brakes, with everything cleaned and freshly lubed, whereas a paid mechanic will just slap in the new pads. I extend this mindset everywhere in my existence, to building my own house (bomb shelter), to working on my cars, to fixing anything. With the money saved, I am "free" to splurge on the things that make my hobbies have more satisfaction and fun. Standing back and looking at the modification to my CB knowing it was done right and the least cost possible is a way to derive tremendous satisfaction to me.
As to oil, as was said earlier, and it is like debating religion, "has the debate changed anyone's mind yet?"
(08-30-2020, 01:07 AM)SportsterDoc_imp Wrote:
(08-30-2020, 12:55 AM)The ferret_imp Wrote: ROFL
LOL not hardly.
Wonder if anyone's mind and methods have been changed
Probably not. Forgot to mention that I used Honda oil filters at every change.
I do not want to dampen Jambo's enthusiasm (although a Reader's Digest version would be easier to follow) but bypass valves have two purposes:
1. Already mentioned by Jambo, to allow oil flow to continue if the filter media becomes clogged.
2. To allow cold, relatively thick oil to flow upon cold starts. Without a bypass valve, oil flow could be reduced/impeded upon cold startup.
Well I’m going to OEM filter after today’s ride. I’ve read the horror stories about the K&N and never use them. I’ve been using the hiflow racing . I was out riding wonder where the oil smell was coming from 300 miles into the ride I realize my rear brakes weren’t working so good the spot weld on the nut broke on the filter and started blowing oil back
That's no good, dean. Glad you're OK. When Pterodactyl's K&N filter suffered the same fate, I had to go riding to the next town to find a replacement. All I could get was a HiFlow Premium, but that didn't have the spot-welded nut and was fine. Seems to me spot-welding a nut on the end of a filter is a design weakness.
At the time of Pterodactyl's mishap, I also had a K&N filter on the bike and replaced it immediately with a HiFlow Premium. It was fine.
aww geez, that's no good.
Are the HiFlows made by K&N? or just a similar design?
I sleep well at night because I use the OEM filter and Mobil 1 10/40 synthetic motor cycle oil. How much is a good night sleep worth in dollars ?
Ferret, dunno, but I will never again buy an oil filter with a nut spot welded on to it.
Houtman, $516.24.
(08-31-2020, 09:33 AM)Cormanus_imp Wrote: Ferret, dunno, but I will never again buy an oil filter with a nut spot welded on to it.
Houtman, $516.24.
That money must include sleeping with some one else....
Jambo
It would facilitate response if you would number each chapter in your book / post.
Meanwhile you may want to research the effects of ash, phosphorous and sulfur content in 2T oil relating to the potential effect on motorcycle valve stems.. the CB 1100 has 16 of them.
Another research suggestion would be regarding the additives used in 4T oil specifically for high RPM motorcycle engines.
When I buy a vehicle I service it as though I were going to keep it forever.
BTW, Can-Am specifies 4T oil for a 8250 RPM motor, separate from trans.
  tire change Tom_imp 7 723 05-31-2021, 11:37 PM
Last Post: Tom_imp
  engine oil change time interval in kilometers CB1100 EX 2015 Alfgaxatico_imp 21 1,444 03-28-2021, 07:40 AM
Last Post: Speed_imp
  First oil change for this heathen koehlerk_imp 67 4,556 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 901 09-15-2020, 09:40 PM
  where is the sticky post to first time oil change? buckwheat_imp 4 424 09-10-2020, 05:41 AM
Last Post: buckwheat_imp
  Oil change before/after winter? HikerToo_imp 11 815 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,234 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 1,025 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 408 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 2,232 11-28-2017, 09:24 AM
Last Post: SportsterDoc
