08-30-2020, 09:48 PM
I figured. Will disconnecting battery reset the computer?
ABS Light Flashing on 2017EX
08-30-2020, 09:57 PM
(08-30-2020, 09:48 PM)Exbex1_imp Wrote: I figured. Will disconnecting battery reset the computer? Not sure. I'd have to do some reading in the service manual. However, if the pulses aren't consistent the ABS will call a fault, or in one members case the speedometer was wonky (slightly bent rear ring). Once the ring is replaced and the gap correct, the fault will most likely clear itself.
08-30-2020, 10:08 PM
Thank you! I’ll get back to you. The part should be here Friday. I'll try not to boger it up again.
Tom
09-14-2020, 06:29 AM
(08-30-2020, 09:57 PM)Lord Popgun_imp Wrote:(08-30-2020, 09:48 PM)Exbex1_imp Wrote: I figured. Will disconnecting battery reset the computer? Not sure. I'd have to do some reading in the service manual. However, if the pulses aren't consistent the ABS will call a fault, or in one members case the speedometer was wonky (slightly bent rear ring). Once the ring is replaced and the gap correct, the fault will most likely clear itself. You are correct sir! 30 minutes, new front pulser ring, and no more flashy flashy! Life is good again! Thanks.
09-14-2020, 07:07 AM
Just as an update on my own situation. I cleaned my calipers thoroughly and since switching to the EBC HH sintered front pads, using a liberal amount of brake-quiet (basically just silicone lube AFAIK?) on the pads I haven't had any issues with the ABS. I still have some front brake squealing, but it's not leading to failure in the ABS at least. I did 20,000 miles on the CB last year so it's working out, whatever problems I had for a bit when the bike was new seem to have just disappeared, I didn't replace anything.
09-14-2020, 07:36 AM
Good work Exbex1! Glad you got it worked out.
« Next Oldest | Next Newest »
| Question re: 2017EX spoke rims tubeless conversion | slmjim n Z1BEBE_imp | 6 | 589 |
10-28-2023, 09:24 PM Last Post: slmjim n Z1BEBE_imp |
| Fuel gauge flashing from center outward.... | mattmcuomo@yahoo.com | 29 | 2,378 |
06-02-2022, 03:13 AM Last Post: thomas_imp |
| HISS flashing | Maturecheese_imp | 7 | 690 |
03-23-2022, 09:34 PM Last Post: GoldOxide_imp |
| Don Guhl video on ecu flashing | max | 8 | 644 |
09-08-2021, 02:52 PM Last Post: Cormanus |
| Tires for 2017ex | pdedse | 25 | 1,560 |
07-29-2019, 10:25 PM Last Post: GoldOxide_imp |
| running light and brake light | Ennsync_imp | 3 | 433 |
01-02-2019, 11:24 PM Last Post: GoldOxide_imp |
