Larger rear sprocket
#41
(04-01-2018, 08:21 AM)PowerDubs_imp Wrote: If he can figure out the factory part number from a non U.S. 900RR- it had a 42t that would fit. U.S. had a 43t and I can’t find the part # for ROW
Got it. Let's see how he responds and I will ask.
Takahashi's response,
Thank you for the inquiry.
Regarding your question, I am sorry 42 tooth is not available, but I can get 41 tooth rear sprocket.
I wrote back and asked about the 900rr sprocket. We'll see.
Found this on the JT Sprocket site. I think it's what we're looking for. Need to check the measurement.
[Image: 6b414377f68b9210f13c3e1afbc36f54.jpg]
Think I figured it out. JT has the same part number, JTR302, for all the CB1100 Models. So it has to fit! Found it on Amazon
https://www.amazon.com/JT-Sprockets-JTR3...B000GS6KEQ
Placed order. Should be here around the 9th.
I know the 900RR application will fit- I just don't know JT sprockets or their quality.
The Sunstar I tried is the same company that makes the factory sprocket on our bikes.
I would still love to find the Honda factory part # for ROW 900RR 42t sprocket. My google fu is failing as I have not been able to find it. Sad
Well, returning the sprocket, bought from Amazon, I have been informed that the supplier, Powersports911, will be contacting me. When they do I will ask if they have the 900rr, international, 42 tooth sprocket from Sunstar.
I did check reviews on JT. Didn't see anything alarming. Here's one, http://earth-roamers.blogspot.com/2013/1...ckets.html
Powerdubs,
From my searching it looks like the 900RR came with a 43 tooth?
I found a post on a Fireblade board that the (at least) ‘94 Austrailian bike came with 42T. And I found this: https://us.fowlersparts.co.uk/parts/4853...rear-wheel
Funny looking part number if this is it: 41200MW0000
Hope this helps.
Pop- the 900RR came with a 43 in the U.S.- 42 rest of the world.
Which given the size of the world- blows my mind the part would be impossible to locate...??
If that is the part number, maybe Cormanus could check some of his sources...
Or just check them as I guess they can look it up.
Try 41201-MEL-D20 for the 2003 CBR900R.
From http://www.peterhillhonda.com.au/honda-parts-epc
  Advice on sprocket replacement? Inhouse Bob 5 571 06-24-2025, 12:57 PM
  Going up 1 on the front sprocket DBM_imp 17 1,334 08-21-2018, 08:36 AM
Last Post: riggies_imp
  Chain and sprocket replacement cost ecka00_imp 2 284 03-16-2016, 07:22 AM
Last Post: Motogeezer1949_imp
  larger tanks on the '14s. Olyrider 1 229 05-12-2015, 05:52 AM
