Oil Pressure/Temperature guage????
DAC Offline
Threads: 17
Likes Received: 12 in 6 posts
Likes Given: 12
RE: Oil Pressure/Temperature guage????
#31
Great pics! Wow - 220 boiling point. I remember my VFR getting to that temp before the radiator fans kicked in. Always ran Rotella in that one. I was considering returning to Rotella T6 5w40 for the hotter part of the summer in the CB.
06-05-2015, 02:26 AM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
#32
Mobil 1 synthetic lists the flash point for 10w30 at 220*C (428*F) and 10w40 at 227*C (440*F). I doubt you would see any difference in the two grades boiling in our engines. Three oils I'm looking at are probably not correct for our bikes, but I would not expect too much variation.
https://mobiloil.com/en/motor-oils/mobil...gh-mileage
06-05-2015, 03:29 AM
DAC Offline
Threads: 17
Likes Given: 12
#33
Thanks - saw 220 and didn't know it was °C and not °F.
06-05-2015, 03:35 AM
xNE0x_imp Offline
Threads: 6
#34
(06-05-2015, 03:29 AM)kennyw_imp Wrote: Mobil 1 synthetic lists the flash point for 10w30 at 220*C (428*F) and 10w40 at 227*C (440*F). I doubt you would see any difference in the two grades boiling in our engines. Three oils I'm looking at are probably not correct for our bikes, but I would not expect too much variation.
Thanks for that info. I said F and not C, my mistake. Corrected.
Mobil 1 Racing 4T:
Flash Point, °C (ASTM D93), 212 / 413.6 Degrees F
Bob the oil guy's review:
Flash Point, ºC, ASTM D 92 253 / 487.4 Degrees F
No idea why the difference?
I could not find any specs on the GN4 that honda recommends for our bikes, but I did find this:
Pro Honda GN4 - Black bottle/red label. Intended as an all around 4-stroke
oil motorcycle for normal everyday riding; low heat applications. GN4 is a
petroleum-based motorcycle 4-stroke oil recommended for scooters, ATV's and
motorcycles used for light duty and low heat usage. Commuting, normal street
rides, casual trail use and low engine stress situations do not cause as much heat
to build up in the engine therefore a less expensive additive package can be
utilized. This is our original motorcycle oil formula developed specifically for
motorcycles and blended with an additive package to meet the unique shifting
requirements of shared engine and transmission sump designs. GN4 is packaged in a 1-litre black
bottle with a red label, available in 10W30, 10W40, 20W50 and also 5w30 weight for cold
weather ATV use.
06-05-2015, 03:43 AM
Xyzzy_imp Offline
Threads: 2
#35
(06-03-2015, 10:17 PM)The ferret_imp Wrote: If you get the opportunity, shoot a reading on the spark plug area where Honda went to great lengths to keep temps down with oil galleries and bolt on finning.
This was taken after a 30 minute ride and while idling for maybe a minute or so. (The engine is running.) The oil cooler read 220°F and the ambient air temperature was ~80°F. (You can see how the mirrored cam caps don't register properly due to the reflective nature of their finish.)
06-09-2015, 07:23 AM
ish_imp Offline
Threads: 1
#36
This was taken after a 30 minute ride and while idling for maybe a minute or so. (The engine is running.) The oil cooler read 220°F and the ambient air temperature was ~80°F. (You can see how the mirrored cam caps don't register properly due to the reflective nature of their finish.) This is really neat. Thanks! Synthetic 5W40 T6 oil all day.
I feel really bad whenever i get stuck on a long left hand turn light and can feel the heat from the motor. Do you guys think its better to shut the engine off for a bit or keep it running in idle when you're stopped for a long light?
06-09-2015, 08:17 AM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
#37
Around here I'm usually riding in temps of 100F or more for about half the year. I don't bother shutting off the engine unless I'm going to be sitting still for 10 min. or more.
One of the only times I overheated a bike was waiting in a long line for an emissions test on a hot day. I couldn't shut off the bike because the battery was toast. It was about 30 min. and when I finally got to the front of the line, the bike failed the test because it was overheated. This was on my carbed CB750 and the first clue that it was overheating was that the idle would start to get rough and lower than normal. Not sure if you'd see that on a fuel injected, computer controlled CB11.
06-09-2015, 09:37 AM
xNE0x_imp Offline
Threads: 6
#38
I would imagine not. The biggest thing is people need to understand how an air cooled motor behaves. It's not like it's liquid cooled brethren.
06-09-2015, 06:27 PM
veech_imp Offline
Threads: 3
#39
Good to know as I run Mobil 1 Synthetic in mine as well. Thanks for sharing! Thumbs Up
06-10-2015, 12:58 AM
kmoney_imp Offline
Threads: 29
#40
Anyone actually know what steps the bike takes to prevent itself from overheating at idle? I've looked around and can't find anything on the Internet. I would think it would be something like dropping random cylinders, but if it is I sure can't feel it.
06-10-2015, 09:39 AM
  FOBO tire pressure monitoring system report.. Chuckk_imp 120 8,421 11-28-2020, 10:38 AM
Last Post: Chuckk_imp
  Adding an oil pressure gauge wiscoaircraftmech_imp 7 586 06-30-2020, 01:41 AM
Last Post: wiscoaircraftmech_imp
  Designing an Engine Oil Temperature Display Gauge Project 17-CB-002 37 2,550 11-06-2019, 04:10 AM
  Oil Temperature Gauge Paul_imp 12 882 03-18-2017, 12:29 PM
Last Post: BestStandard_imp
Users browsing this thread: 6 Guest(s)
