Road Comet Windshield Question
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 200 in 118 posts
Likes Given: 142
RE: Road Comet Windshield Question
#31
If you look here http://www.samurider.com/?cat=259 You will see that there are separate ones for the different year models.
I think the headlight is at different heights on the '13 and '14s.
04-09-2016, 10:55 PM
riceburner_imp Offline
Threads: 1
#32
So i'm wondering where the air flow from the road comet hits, chest height or higher?,ride helmet less and want to keep 70 mph bugs from cratering my face.
07-03-2016, 12:55 PM
Riko_imp Offline
Threads: 47
#33
Helmet!
When riding highwayspeeds and higher, your helmet will be full of that bugs a real masskilling.
Same for the chest area.
07-03-2016, 04:11 PM
jrns_imp Offline
Threads: 3
#34
does anybody have an opinion on the "touring" screen (that's the higher screen) - as to where the airflow hits?
does it change it much from the regular screen on the Road Comet?
Just curious-thanks
07-03-2016, 09:10 PM
Riko_imp Offline
Threads: 47
#35
Yes, I still have them both.
I switched from the touring screen to the normal size screen.
Reason was the noise level. And tbh, the looks.
You can see lots of pictures in the link of my signature.
Also, the bike looks more handsome on our bikes with the stock screen.
Big advantage with the touring screen is the wind protection, you can really hit max speed without many wind if you lay on the tank.
But if you sit normally on the bike, than you will experience a lot of wind noise.
With the stock screen the wind noise is less because you got a cleaner airflow.
But you do get 100% wind on your helmet/face.
With the touring screen, the wind flow is higher and cuts in my helmet/face in normal upright seating position.
For reference, I am 1m84.
So none is 'perfect', but comparing pros and cons, I went for the stock screen.
Maybe in winter time I am gonna switch to the touring screen.
07-03-2016, 09:31 PM
Elipten_imp Offline
Threads: 13
#36
I did not like the taller screen for same reasons. Too much noise and turbulence around my helmet. Needs to be taller, or me shorter. I am 5'8".
07-03-2016, 10:13 PM
Riko_imp Offline
Threads: 47
#37
turbulance was ok, no much buffeting, it was the noise that annoyed me at speed...
07-04-2016, 02:01 AM
Ron in MO_imp Offline
Threads: 14
#38
I purchased the touring screen for my ride to the forum rally this year and felt it did a better job deflecting air flow higher, but both screens create more noise in my helmet that I expected. Nothing some good earplugs couldn't solve!
Another issue I had with both screens, but even more so with the touring screen, is the wind flow over the top of the screen causing movement of the fairing enough to change the turbulence around my helmet at higher (70-80mph) speeds. When I got home from the rally, I researched a fix and came up with some brackets to secure the top of the fairing. Now I find the touring fairing works much better and doesn't move at any speed. I keep the touring fairing on full time now that works like expected. By the way, I am 5'10" tall.
Here is a link to my post on the fairing braces I added:
http://cb1100forum.com/forum/showthread....ht=fairing
Good luck with your research!
07-04-2016, 04:07 AM
jrns_imp Offline
Threads: 3
#39
I have both ..regular and touring. the regular I find is quieter but I'm blasted with bugs every ride..
I put the touring screen on this season and 3 things: 1) noise -louder than the regular, 2) seems to have better wind protection for some reason...airflow? I find highway riding much easier now... and 3) less bugs. they seem to flow over my helmet-so my face shield isn't splattered with bugs now?
Those are my early observations.
Overall - aside from the noise-I like the touring screen. I may have to invest in ear plugs tho.
07-04-2016, 10:29 PM
Riko_imp Offline
Threads: 47
#40
agreed with all points
there are only 2 things that are negative about the touring windscreen, and one is personal:
more noise and it doesnt look good on (my) cb1100 (from most angles)
07-05-2016, 01:40 AM
  Givi Airstar Universal Windshield - A660 peterbaron 2 629 12-28-2025, 02:15 PM
  power port and Samurider Road Comet Fairing 1 tdbru 9 1,055 05-04-2025, 07:20 PM
Last Post: tdbru
  Road Comet Masqeroad: A Beautiful Pragmatic Response rdprdp01 7 1,081 05-04-2025, 11:33 AM
Last Post: rdprdp01
  Road Comet: A Beautiful Pragmatic Response rdprdp01 12 1,095 10-29-2024, 12:25 AM
Last Post: rdprdp01
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,320 01-22-2023, 03:07 AM
  windshield Griz53_imp 3 399 09-24-2022, 04:55 AM
Last Post: 1985CB450_imp
  Road Comet Fairing Catbird_imp 47 4,604 08-16-2022, 10:33 PM
   Road comet 2 fitment correct?? gretle_2.0 8 893 05-07-2022, 11:08 PM
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,136 04-08-2022, 09:28 PM
  Road Comet 2 Impressions Frulk_imp 12 968 11-14-2021, 07:09 PM
Last Post: mrded_imp
