Road Comet Fairing
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
RE: Road Comet Fairing
#31
(09-07-2014, 01:45 PM)OldF7Guy_imp Wrote: Just curious, how much trouble is it to install/take off the rode comet fairings? I like the naked look but I am getting old and taking wind at 70-75 is old too. In fact, its beating me to death. For once, I think a short rider like myself my even benefit more from one of these. Just trying to think ahead.
The install is to replace the bolts holding the bucket to the bracket with the supplies ones and attach a bracket to the horns and bolt it on with three bolts.
You do need to attach the windscreen before installation, but that's not that hard. Just make sure to clean any fingerprints off before you install in on the bike. Blush
09-07-2014, 01:51 PM
ClassicVW_imp Offline
Threads: 6
#32
If you meant taking it off and on once in a while, I'd say 5-10 minutes.
Be aware, though, that it will not take the airstream off of you. It's not big enough for that. It will only redirect it. I'm 6' tall and without the Comet I was feeling way too much air directly on my stomach, so much that at 60 MPH+ it felt like I'd be pushed off the bike.
With the Comet, the air now hits me across the collarbone area, there's somewhat less force to it than what I was feeling before, its kind of welcome in the summer heat, Probably not so welcome in colder temperatures. A shorter rider may get the air square in the faceshield, which also may not be desirable, could be tiring to your neck.
The comet is short, and it's angled so the air is still directed backward, not like a taller windshield which may direct the air up and over you. Hope this helps you.
09-07-2014, 09:59 PM
Huladog_imp Offline
Threads: 23
#33
Ditto what ClassicVW says. I'm shorter at about 5'7" and the airflow with the stock screen hits me in the chest/collar bone area, but it's a clean airflow and welcome in the heat. I had the taller touring screen and thought it was fine but started to wonder how come my new helmet seemed noisier than my older helmet so I stood up on the pegs to get my head into clean airflow ..... and it got quiet.
Tested out riding the bike without any fairing or windscreen and it IS pretty quiet, but yeah you do get the full blast of wind on the freeway. So I switched back to the stock lower screen on the fairing and the airflow is clean, the helmet is quieter and my body stays cooler ...... won't work well for you guys when the weather gets cool soon, but I'm in Hawaii so what the heck?
Yep, removing or installing is quick with just three hex head screws, one on each side of the headlight bucket, one underneath to the supplied support bracket by the horns.
I installed the almost invisible nylon washers (wait till you drop one and have to crawl around finding it) in between the screen and the fairing for cushioning and to provide the small gap so water could drain from between the two. The only way I could hold those nylon washers in position was to use a tiny dab of hot glue so they wouldn't run away when I positioned the screen. A bit of grease would also work, but the old glue gun was handier.
When I had the washers under the bolt heads on the top surface of the screen (nothing in between the screen and the fairing) water would get stuck in between and would not drain or dry out cleanly, so I used the washers to get the gap in between them.
Just be careful when tightening the windscreen bolts and don't get aggressive and crack the screen, somehow I managed to get a small crack from one bolt hole to the edge from stress.
Aloha,
Huladog
09-09-2014, 03:52 AM
Streetshark07_imp Offline
Threads: 9
#34
Hi,
I bought the Road Comet 2 and I think I understand the part about the screws near the head light, but I don't get what you're supposed to do with the horn bracket.
I guessed that the screw in the front middle of the horn system would come out to mount that 3rd bracket there, but when I tried that, it seemed like the 3rd bracket wouldn't fit in there.
My other question: Don't we need a nut for the small screw on the other side of the L. Maybe I'm missing something, but I was thinking a nut would be necessary for that bolt and washer to be worth anything.
Thanks,
Ben
10-29-2014, 10:32 AM
Threads: 6
#35
Yes, a small bolt and nut and an "L' bracket is supplied with the Road Comet. That bolt goes thru the top leg of the small "L" bracket and into the Road Comet, and the nut gets secured on top.
For the lower end of the "L" bracket, you unscrew the nut that is on the front of the horn bracket. You then put the lower end of the "L" bracket onto the bolt that is on the horn bracket and resecure the nut you removed.
10-29-2014, 10:40 AM
Threads: 9
#36
Ok, I guess my nut must have gotten lost. I'll go and buy something that matches the bolt at Advance Auto or something.
Also, my L bracket came with an extra washer taped to it, is that meant to go in with the washer and the nut that are already part of the horn bracket type system? I took that nut off the horn bracket once already and explored the idea of putting the L bracket on it, and it looked like it would be a very tight fit if possible at all.
Thanks,
Ben
10-29-2014, 10:47 AM
Threads: 6
#37
It is a tight fit, I recall wondering if it would work, but it did. I used the washer on the top part, against the fairing, under the nut, so not to stress the fairing fiberglass.
10-29-2014, 11:19 AM
Threads: 9
#38
Ok, in the meantime, I looked at the indiscernible "instructions" again and based on the vague illustrations, I guessed that the nut I was supposed to use on the top part of the "L" was that nut that's part of the "L" and I made that be above the bottom of the fiber glass for the bolt to secure the two together (with a washer between the bolt and fiberglass. I did this and it looks cool and whatever, but I can undo it if this isn't right.
Also, I'm wondering if I should have done the headlight mount bits on the left and right sides first, don't think I can get the original bolts out with the fairing sitting there, doh!.
Thanks,
Ben
10-29-2014, 11:27 AM
AndyHe_imp Offline
Threads: 9
Likes Received: 2 in 2 posts
#39
I just got a road comet 1 from samurider this past Thursday and it is unchanged from the one in the picture in original post. Looks like either they still haven't changed the design or they are still getting rid of old stock. They had it in stock so it could be the case that newer ones will have a redesigned lip. There is a bit of light leakage at night through the fairing from the headlight but it is very slight and nothing distracting at this point. If it gets worse, I'll fix it with some electrical tape or something.
Yeah, the L bracket on the bottom hooking to the horn bracket was a pain as was figuring out how/why to replace the horn bracket extensions. It didn't take too long to figure it out though.
12-06-2014, 03:16 AM
Jurlie_imp Offline
Threads: 5
#40
(09-03-2014, 05:06 AM)Randy B_imp Wrote: I got the taller windscreen and I am happy with it. I too am getting the wind right about at my chin, but I'm good with that. I had a Streetshield EX and had quite a bit of buffeting above 65 MPH, but with this my head is in clean air and everything is much smoother.
[Image: 67c46a7bf94a3349428e3f8d8079a44f.jpg]
I'm thinking of exactly same touring screen.
How it behaves at 80-90 mph?
Riding for hours at speed 80+ mph on naked bike develops huge load on neck, which was a reason for me to visit doctor. I understand, the best option is probably to get some touring bike which is built for that purpose, but I love my CB, and I'm trying to find the way to fix the problem staying with the same bike.
04-21-2019, 02:58 PM
  power port and Samurider Road Comet Fairing 1 tdbru 9 1,012 05-04-2025, 07:20 PM
Last Post: tdbru
  Road Comet Masqeroad: A Beautiful Pragmatic Response rdprdp01 7 1,054 05-04-2025, 11:33 AM
Last Post: rdprdp01
  Road Comet: A Beautiful Pragmatic Response rdprdp01 12 1,066 10-29-2024, 12:25 AM
Last Post: rdprdp01
  Batwing fairing ISO Griz53_imp 1 346 01-22-2023, 03:11 AM
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,271 01-22-2023, 03:07 AM
  Road Comet Fairing Catbird_imp 47 4,490 08-16-2022, 10:33 PM
  Rebel 500 SE style fairing? LayerCake_imp 0 305 06-12-2022, 09:03 AM
Last Post: LayerCake_imp
   Road comet 2 fitment correct?? gretle_2.0 8 844 05-07-2022, 11:08 PM
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,127 04-08-2022, 09:28 PM
  vetter fairing help Canadianredneck_imp 12 1,067 03-31-2022, 12:51 PM
Last Post: rboe
