Stock Exhaust Mod
specialist8 Offline
Tennessee
Threads: 15
Likes Given: 1
Stock Exhaust Mod
#31
Check and check.
05-24-2016, 10:23 PM
BIGGREEK_imp Offline
Threads: 6
RE: Stock Exhaust Mod
#32
Yup, all I did was drill one hole at a time (3/8") until it didn't sound like an exhaust leak. I think 8 or 9 holes, and just put the cap back on, sounds perfect.
Sent from my XT1254 using Tapatalk
06-11-2016, 07:00 AM
Catbird_imp Offline
Threads: 5
#33
(04-26-2016, 11:24 AM)Carguy1959_imp Wrote: Mine sounds about the same. I drilled 3, 1" holes, removed the snout and opened up the cap.
Exactly how did you do that? It seems that if a person drilled the holes and then reinstalled the end cap, that would negate the sound improvement coming from the holes. Huh
06-12-2016, 11:32 PM
TCinNC_imp Offline
Threads: 3
#34
Exactly how did you do that? It seems that if a person drilled the holes and then reinstalled the end cap, that would negate the sound improvement coming from the holes. Huh It doesn't, I drilled 6 half inch holes. My bike has a pleasant rumble now with the end cap installed.
06-13-2016, 01:13 AM
Retsel_imp Offline
Threads: 24
#35
Just think what it would sound like if the holes were properly, simetrcally spaced!
06-13-2016, 12:41 PM
pwh421_imp Offline
Threads: 11
#36
(04-23-2016, 07:05 AM)SStan11_imp Wrote: [Image: 60db2008216bd7a55ed9d25f69fab295.jpg]
So no other work? No baffle changes?
and, again, is there a MPG cost here or a HP gain? Or is it just tone?
-Peter
06-15-2016, 12:47 AM
TCinNC_imp Offline
Threads: 3
#37
-Peter
-Peter Nothing else required. If anything my mpg has slightly increased. My seat of the pants dyno tells me no hp gain. The sound is a much deeper rumble than stock, no excessive noise.
06-15-2016, 01:18 AM
GaryMNM_imp Offline
Threads: 2
#38
(05-10-2016, 03:58 AM)specialist8_imp Wrote: Will be doing this mod in the next few days. I'll also submit a riding video with Spielberg quality production as well. Wink
Add me to the list of looking forward to your riding and/or drive-by video version! Thumbs Up
06-15-2016, 01:35 AM
kennyw Offline
N9PHW
Sultan, WA
Threads: 42
Likes Received: 5 in 4 posts
Likes Given: 3
#39
I did this mod drilling holes only and was getting no change in mpg. Commuting is still 48 for mixed city/highway, road trip is 55-60 mpg for all highway. For me it was just to make sure the bike could be heard by pedestrians.
06-17-2016, 03:33 PM
Biggin_imp Offline
Threads: 0
#40
I did this mod, I drilled 8 3/8 holes similar to picture posted.
Sounded pretty good , pulled end cap while running notice improvement so I took a dremel tool and cut the pipe off that protrudes out of the end cap.i cut it about 3/8 " from plate that the holes were drilled in.
This left a bigger hole for exhaust to go thru instead of being squeezed
Between the small pipe and end cap. Really like the sound.
06-20-2016, 08:40 AM
  Stock Mirrors MrBob_imp 5 603 04-11-2025, 03:33 AM
Last Post: balkanhound_imp
  Stock Muffler jbird06_imp 8 755 05-02-2024, 11:21 AM
  Stock exhaust or aftermarket header? milkmaster_imp 17 1,420 07-20-2023, 04:11 AM
  Decat stock pipes ozigoo 4 489 05-22-2020, 10:55 AM
  Stock vs. aftermarket exhaust LongRanger_imp 15 1,119 11-30-2019, 06:30 AM
  Shaved Stock or K+H Low GroovyBunny86_imp 18 1,613 06-18-2019, 12:58 AM
Last Post: BayAreaRick_imp
  Modify stock muffler? DBM_imp 2 362 07-30-2018, 05:08 PM
Last Post: FLYTYM_imp
  Anybody modify a stock 014' seat? el duque_imp 9 746 06-05-2018, 03:39 PM
Last Post: el duque_imp
  stock seat mod TCBronson_imp 6 637 10-03-2016, 06:19 PM
Last Post: ryanschillinger_imp
  Stock Honda Rack Frulk_imp 14 1,148 08-07-2016, 07:35 PM
