Threads: 29
(04-30-2013, 06:36 AM)The ferret_imp Wrote: How much oil you guys sticking back in with a filter change...i know it calls for 4.1 gal (4 gals 3.2 oz ?) but the ST 1300 calls for the same amount, but most ST owners just stick a gallon in it and be done with it.
Gentlemen,
I assume you mean 4 quarts and not 4 gallons?
Chip
Threads: 11
Just performed my first service at 516 mi using Repsol 10W30 Full Syn and OE Honda filter. I let the bike drain hot both on the center stand and then on the side stand. I poured in ~3.8 quarts of oil and started the bike and let it run for about 2 min. Oil settled to the lower line. I then added about 1.5 ounces to the top line and started the bike for another minute. Shut off and let it settle. Oil level is right on the top line. After the filter soaks in a bit I may need to add a bit more but will know after my first ride. I would say overall you are replacing 3.9 - 4.0 qts of oil on a typical oil change.
Likes Received: 635 in 284 posts
Likes Given: 799
(06-28-2013, 11:48 AM)ChipBeck_imp Wrote: (04-30-2013, 06:36 AM)The ferret_imp Wrote: How much oil you guys sticking back in with a filter change...i know it calls for 4.1 gal (4 gals 3.2 oz ?) but the ST 1300 calls for the same amount, but most ST owners just stick a gallon in it and be done with it.
Gentlemen,
Chip
Gentlemen,
Chip
Lol...yea just a typo...4.1 qts...One gallon doh! Damn can you imagine sticking 4 gallons of oil in there? It would be running out of every hole including the muffler lol
Thanks for pointing that out Chip.
Threads: 26
My oil level is always too full from the dealer. I would put about 4 ounces less that 4 quarts, run it, and see where you are 3 minutes after stop on the center stand. It is very satisfying to look in the glass and see the level just touching the top mark.
When I got my bike new the oil was full up and over the top of the glass. Even putting the bike on the side stand did not reveal any clearance at the top of the glass. I took it back to the dealer and they drained out the excess (they got the bike from another dealer) and when I got it back it was perfect. They must have taken out half a quart.
Now this time, the oil is up to the top of the glass window, but when I put it on the side stand the level goes all the way down to the bottom of the glass window such that you have to turn the wiper to even see it. I am guessing I am only slightly over with this info and it is ok.
Too much oil in your crankcase is absolutely as dangerous for your engine as too little oil. So it really is important to have it right.
Threads: 85
Likes Given: 133
Well I did my second oil change last Saturday and I put in just about 4.2 Qts. I put in the full 4 quarts and then spun the wiper to make sure I could see clearly and it was under half way between the lines, so I opened Qt #5 and topped it off.
I do let the oil drain until there is about nothing left soo.....
And an odd thing happened. I'm not sure if it's due to the windshield I installed, or the switch I made to synthetic oil, but my mileage jumped in the neighborhood of 15%. On my commute I was getting between 42-44 mpg and after the installation and oil change I'm getting right on 50. This is a 58 mile one way commute with a couple LARGE hill climes and traffic that REFUSSES to go slower that 75mph. Needless to say I was a bit surprised when I got home on Wednesday and filled up (it rained on Mon and Tues).
Threads: 26
(06-29-2013, 01:08 PM)Randy B_imp Wrote: Well I did my second oil change last Saturday and I put in just about 4.2 Qts. I put in the full 4 quarts and then spun the wiper to make sure I could see clearly and it was under half way between the lines, so I opened Qt #5 and topped it off.
Mileage can be all over the place. I've been getting 50mpg since my first tank of fuel using regular Honda GN4 motor oil.
Seems as though you put in a lot of oil. Three minutes after you shut down the motor, on the center stand, where is your oil level on the sight glass?
Threads: 85
Likes Given: 133
I'll have to see about a picture, but it won't be for a couple days at least. I'm not going anywhere today as it's going to be too damned hot and the bike it cornered between a car and my truck in the garage. I HATE having a tandem garage, but it's better than not having one at all.....ugh.
Threads: 11
(06-29-2013, 06:12 AM)meowguy_imp Wrote: My oil level is always too full from the dealer. I would put about 4 ounces less that 4 quarts, run it, and see where you are 3 minutes after stop on the center stand. It is very satisfying to look in the glass and see the level just touching the top mark.
Too right, and I have had the same issue with my dealer. Oil is above the top of the sight glass. Looks like it might be just at the very top so I won't drain any but I prefer to see a little daylight there.
Threads: 16
I noticed in my owners manual on page 46 that oils marked "Resource Conserving" or "Energy Conserving" on the API symbol are not recommended for use in the CB. Every oil I looked at at Walmart and the auto parts store were marked with one or the other with the exception of Mobil 1 high mileage synthetic.
Any thoughts on why?
My 2001 Honda F4i did not have this restriction. I just sold it today. It had 92,000 miles on it and was still running strong.
Likes Given: 799
They havent recommended energy conserving oils in motorcycles for years because the additives mess up the wet clutch
