Missed Oil Change Step?
#31
(05-07-2018, 06:25 AM)2017EX_imp Wrote: My intent in starting this thread was just meant to be a helpful reminder that step one for oil changes, after warming the old oil, as described in the shop manual, is to remove the oil filler cap before removing the drain bolt, and or filter. I think many of us have found over the years, that removing the filler cap before the drain bolt, works a bit more efficiently. That said, I also agree that I am not going to worry about what little might still still be in the sump. I have never had a problem with any machine by following procedures spelled out in the Shop Manual, but have had problems from time to time when I experimented or deviated from the Manual.
Your intent is appreciated and your point about better drainage on most bikes is valid.
However, I get less of a surge and hot dirty oil in places unwelcome, if I remove the drain plug, get the flow going, then open the filler cap.
YMMV
YMMV
YMMV Interesting, I had not thought of that small twist on the procedure outlined in the Shop Manual, but it makes sense while still staying within the spirit of the process. I will try it next oil change.
I totally agree, 2017EX. removing the oil filler cap helps. I was trying to point out the potential risk of the diesel "treatment".
I totally agree, 2017EX. removing the oil filler cap helps. I was trying to point out the potential risk of the diesel "treatment". No worries taureg, and I think there are more potential negatives than positives to the diesel flush as well. The Forum is doing exactly what it is supposed to do, exchange ideas and see which ones are good and which ones are probably not. I am glad Cormanus brought it up to discuss. I am also glad SportsterDoc brought up his small twist on the procedure too.
  tire change Tom_imp 7 666 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,272 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 813 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 3,720 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 773 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,195 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 921 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 369 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 2,090 11-28-2017, 09:24 AM
Last Post: SportsterDoc
  Completed second oil change (DIY) venturer434_imp 5 446 05-11-2017, 07:47 PM
Last Post: Rocky_imp
