Front brakes squeal...this feels like a saga in the making
#31
Perfection is a real problem. I realize this now, with this bike. The cosmetics are so gorgeous that I lose my mind the second I spot a speck of grease on a wheel, a scuff mark where my knees contact the side of the tank, a swirl pattern or slight haze on the tank, polish lines in the instrument display, etc.
I was similarly anal about my first VFR. I haven't been that anal about any other bike, until now, with this CB1100.
I really need to knock it off, before I drive myself crazy and/or stop enjoying the bike.
The instrument faces need special care. THey are not glass anymore. When they get dusty don't wipe them with your finger. Squirt some water on them first then use a good plastic polish and soft cloth. Same for the headlight.
(03-06-2018, 10:52 AM)VLJ_imp Wrote: Perfection is a real problem. I realize this now, with this bike. The cosmetics are so gorgeous that I lose my mind the second I spot a speck of grease on a wheel, a scuff mark where my knees contact the side of the tank, a swirl pattern or slight haze on the tank, polish lines in the instrument display, etc.
Take up drinking as a second hobby !
Happy to see Honda getting behind this fix and I hope it stays sorted for you VLJ.
(03-06-2018, 10:37 AM)VLJ_imp Wrote: Brought the bike back to the dealer today. Sunny day, so they were able to ride the bike and do their thing.
First off, the Service Manager called Honda to see whether they would authorize a warranty job for squealing brakes. Apparently the answer was yes, because he went ahead with the job. I told him what people here have been advising, i.e., apply brake grease behind the pads, and file off the edges of the pads.
Those two things are exactly what Honda recommended to his service tech, and that's what the guy did.
When the job was finished, I took her out for a quick hundred-mile spin in the foothills. There was one instance when I thought I might have heard some slight squealing, so I removed my earplugs and rode the rest of the way without them. I'm not sure, but there was one additional time when I thought I might have heard a tiny bit of squeal, but it was iffy. It may have been the cars in front of and beside me. Otherwise, there were many other slow, gradual stops that were completely silent. I tried like crazy to make them squeal, and even without earplugs they passed all my usual tests.
So, either it's 100% fixed, or very close to 100%. Hopefully this proves to be a permanent solution.
I have had the same issue with my 2017 EX and plan to bevel the pad edges and add some grease to interface between the pads and pistons. I'll reply back once I know if it solves my problem.
Just a note for anyone who might be planning to perform the same procedure: the factory service manual states that the caliper mounting bolts need to be replaced rather than reused. I assume that means they are a torque-to-yield type of bolt. The part number for the bolt is 90131-MGC-000.
Welcome, Bobcat.
The squeal had been completely absent for a decent while now, but a bit of squeal returned yesterday.
Sigh.
I understand that they are an ALOC bolt with blue Loctite pre-applied.
Don't know if bolt stretch is the issue or just be sure to use Loctite.
If you do re-use, be sure to first remove old Loctite with wire brush and/or acetone, etc.
Is crazy really such a negative thing?!
(04-29-2018, 06:44 AM)VLJ_imp Wrote: The squeal had been completely absent for a decent while now, but a bit of squeal returned yesterday.
Sigh.
Interesting...mine w/out doing anything hasn't happened for several rides now. Maybe I'm subconsciously controlling for it by braking more firmly. When your acts up, can you make it happen every time you come to a stop, or is it sporadic?
Sporadic. It doesn't do it much now, or often.
  making moderating easy the Ferret 9 651 08-21-2024, 10:28 AM
  Anyone making a backrest? daley_imp 22 1,990 09-09-2021, 05:07 AM
Last Post: Dd808_imp
  Rear brake squeal B-rad G_imp 4 467 07-21-2018, 07:44 AM
Last Post: Nortoon_imp
  2017 CB1100 EX ABS brakes 17-CB-002 5 410 06-11-2017, 12:07 PM
Last Post: 17-CB-002
  My Dealer is Making Hard to say no for a CB1100EX CB-Deacon_imp 13 969 05-27-2017, 12:03 PM
Last Post: BamaRider_imp
  Anti lock brakes Mikestib1_imp 29 2,374 01-08-2017, 02:54 PM
Last Post: flynrider
  The DLX saga Beemer Guy_imp 11 845 09-04-2016, 09:37 AM
Last Post: Motogeezer1949_imp
  Poll: How many are having problems with rear Brakes? Jayimpalaman_imp 137 9,373 08-22-2016, 03:47 PM
Last Post: Ulvetanna_imp
  Issues with brakes postoak_imp 11 726 08-08-2016, 02:33 AM
Last Post: redbirds_imp
  Front Brakes Touchy? Rhinosaurus_imp 4 327 08-04-2016, 03:14 AM
Last Post: Rhinosaurus_imp
