Lower engine knock
#31
I had this same issue and never found resolution. Did you have any luck diagnosing yours?
Finally got around to replacing the cam chain tensioner. Noise 95% gone. I've put about 100 miles on it and I don't even notice the noise anymore. The old one I pulled out seems normal. Maybe it got stuck? I reloaded it and popped the release and seemed okay. Went ahead and put the new one in anyways.
Thank you for all the advise.
P.S> Anyone interested seeing my current build? I am building an 77 CB750f and converting it to a single sided swing arm from a VFR, Front end from a CBR1000 and the engine punched out to 836cc plus many other goodies including Motogadget M-unit and CR carbs to say the least. Fab work is done and everything has been though paint and powercoat. Now for assembly.
Good to know she is fixed, you happy and thanks for your update Airenping
airenping, post your build in the Other Bikes section. We'll be interested.
  Unhealthy Engine Knock / Noise spakins_imp 33 1,783 01-30-2020, 01:22 AM
Last Post: max
  Lower suspension apehair_imp 3 378 08-26-2019, 11:51 AM
  Location of Engine Number on Engine? cb1100_dude_imp 2 332 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  Lower bike bikerpipes_imp 13 952 04-13-2018, 06:57 AM
Last Post: Perry_imp
  Outside lower fork tube diameter Mscb1100_imp 5 516 01-12-2018, 10:34 AM
Last Post: Aussieflyer
  Knock sensor? GS-911 Ulvetanna_imp 10 936 12-02-2016, 04:26 AM
Last Post: Ulvetanna_imp
  Lower Cover instrument panel linuxology_imp 5 450 11-01-2016, 10:19 AM
  Click/Knock Ferrealls_imp 34 2,365 09-07-2016, 12:47 AM
Last Post: 12cb96vfr_imp
  Perhaps a sprocket change for lower revs? meowguy_imp 17 966 09-26-2015, 10:10 PM
  Knock Knock Southpaw50_imp 10 796 08-08-2015, 09:50 PM
Last Post: sanoke_imp
