Chain making clanking grinding sound.
#31
Local San Diego Fun Bike Center dealership replaced both sprockets and chain with exact OEM parts. Service rep recommended non-OEM stuff (better/cheaper) but I said absolutely not!). When I picked up, Service rep showed where the wear was on the sprockets ... also said it was a good call on my OEM requirement because he did not know that OEM was actually good quality and had rubber dampening on the front sprocket. Said chain was in very good condition but worn (atta-boy for my regular Honda Pro Moly chain lubing). Bike is more responsive off the start line now Smile Next up valves and debugging that darn ticking/clicking noise that sounds like leaky sparkplug wire harness but is not.
Good deal Bflint. Ready now for some more long distance trips
Any idea if sprockets/chain would be covered under the Honda extended warranty?
My guess would be that since they are wear items the answer is no.
(11-06-2020, 10:04 AM)The ferret_imp Wrote: Good deal Bflint. Ready now for some more long distance trips
Yeah ... trying to figure out how to get my CB1100 to Ireland, England, and western Europe (Germany, etc) without breaking the bank Smile
now THOSE are some trips!
My OEM chain and sprockets had almost 36,000mi (58,000km) on them as a set. Although there was virtually no stretching to speak of (tension adjustment at the new end of the green wear indicator), it began to make more noise over time. Also, there began to be some kinks along the lengths between sprockets. I decided to swap it out with a new high-end RK XW-Ring chain and new OEM sprockets when I had the wheels off for a tire swap.
The old chain was very stiff and the few pins I pushed out to inspect had some galling on them. The original O-rings were in good condition and the original sprockets showed no visible wear (teeth looked to be same shape as the new ones).
The new one runs quietly and should lower the rolling resistance quite a bit.
  Grinding into second gear World8_imp 5 477 09-12-2022, 12:19 PM
  Sound check what wrong tory_imp 3 425 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Best Honda CB1100 Exhaust Sound RS EX? charles2021_imp 1 267 05-27-2021, 09:47 AM
Last Post: bioman_imp
   Ticking / clicking sound after oil change simplest2remember_imp 12 960 02-03-2021, 01:32 AM
  Ticking Pinging sound Maurice_imp 17 1,236 05-05-2020, 11:19 PM
Last Post: alprider
  Engine sound kklandzw_imp 3 413 11-17-2019, 04:01 PM
Last Post: zirconxi_imp
   Engine Sound Changed After Service EarsOnWheels_imp 19 1,174 07-28-2017, 11:07 AM
  clanking when shifting PilotPaul_imp 53 3,473 11-09-2016, 05:29 AM
Last Post: Ulvetanna_imp
  'Whine' sound/problem ride4now_imp 17 1,172 10-10-2016, 09:43 AM
Last Post: ride4now_imp
  Sound Library for the CB1100? coliban_imp 4 403 09-29-2016, 01:26 AM
