Chip Beck Explains HP vs. Torque for Mr. Ferret
#31
As a retired scientist, let me add my two cents:
Dyno's do not directly measure horsepower, they measure torque in foot pounds. Horsepower is then CALCULATED and displayed by the century old formula below:
Horsepower = torque * RPM / 5252
On any dyno chart, horsepower will ALWAYS equal torque at 5252 RPM and the two curves will cross, with horsepower usually exceeding torque beyond 5252 RPM. Bad news for Harleys and other cruisers that top out at 5200 RPM. Their horsepower can never exceed their torque numbers.
If you see any dyno charts that do not cross at 5252 RPM, they are bogus. You can look up where the 5252 number comes from on the web. It is a "units" conversion factor.
Looking at the formula again, you can make bigger horsepower numbers by increasing either torque or RPM above 5252 RPM. That is why GP racers are turning close to 20,000 RPM. Friction losses reduce torque, so there are limits in practicality.
One final point - gearing: Gearing multiplies torque. The "lower" the overall gear ratio, the more torque applied to the rear wheel. Engines that can turn high RPM can be geared lower and apply monstrous torque at the rear wheel. That is why small displacement, high-revving motorcycles can out accelerate big-block low revving bikes. Soichiro Honda figured this out in the 1950's. He obviously got an A in physics class.
BTW - Kevin Cameron is a class act. As busy as he is, he always responds to my emails.
Here is a link that shows where the 5252 comes from: http://www.epi-eng.com/piston_engine_tec...torque.htm
Also, I am not a scientist and don't play one on TV, just posting the link Wink
(03-16-2015, 10:29 AM)thessler3_imp Wrote: As a retired scientist, let me add my two cents:
no - go google HP and torque chart, it very much depend how engine is designed, they don't always crossed at 5252
CB,
You're going to have to explain that one as every scientist and physics expert on Earth says it does. Look at the formula again and tell us how it cannot cross there. Look at the link I provided for more info, or read the post by the SCIENTIST above.
As he said, you may find charts that don't but they are bogus. The 5,252 comes from a mathematical formula. The two lines absolutely must cross there. It would be like saying that Pi isn't always equal to 3.14159
Mmmm pie. I like warm peach the best with vanilla ice cream.
Somebody mentioned Pi R squared
Pie are round, cake are square
Thought that should be cleared up.
  Paint Chip Aaaahhhhhh bigsheep_imp 25 1,688 10-28-2019, 01:20 PM
Last Post: Bighonda14_imp
  Oil Filter Torque ohiorider_imp 11 718 11-18-2017, 03:58 AM
Last Post: SportsterDoc
  Hey Ferret postoak_imp 8 599 08-02-2017, 01:24 PM
Last Post: Retsel_imp
  Rear axle torque question. jdvalero_imp 10 975 03-21-2017, 09:29 PM
Last Post: jimgl3_imp
  Ferret did you Ride The Eldo? hondahoarder_imp 4 381 06-29-2015, 12:42 AM
Last Post: hondahoarder_imp
  Torque Wrenches Chapomis_imp 7 467 03-26-2015, 06:38 AM
Last Post: Chapomis_imp
  Torque specs for Engine Gaurds metalmaven_imp 3 839 03-19-2015, 01:08 AM
Last Post: metalmaven_imp
  Horsepower vs. Torque ? Rebel73_imp 47 3,513 03-16-2015, 10:49 AM
Last Post: thessler3_imp
  Waaaaaa! There's a chip in my tanks paint! TINK_imp 21 1,300 03-13-2015, 01:50 AM
Last Post: Rebel73_imp
  Ferret! Guth!! Stop The Spamming!!! Damfino_imp 13 845 03-10-2015, 03:33 AM
Last Post: ClassicVW_imp
