Shift without clutch.... much?
#31
Well, it would be wise to consider that the transmission in the S1000RR and RSV4 are built to withstand the hammering of a much higher horsepower engine. As I mentioned, the transmission in my CBR1000RR shifts without the clutch perfectly, every time. The CB, not so much. Even with the clutch, the CB's transmission is notchier and not nearly as smooth, in comparison.
(12-07-2015, 01:42 AM)Motogeezer1949_imp Wrote: I've gone clutchless all my life, every bike I've owned, even at the 1-2 shift. Never had a tranny or clutch or related problem and I've had plenty of bikes on which I racked up over 70k miles. There's no need to use the clutch except for starting, stopping and downshifting, AND after a while, after one learns to match revs, one can downshift in pretty near every gear with the exception the 2-1 down shift.
The motorcycle tranny is constant mesh, unlike mostly all auto/truck trannys, so it's a non-issue, a no brainer. Hurts nothing unless one is a totally inept rider.
Plus, I've never replaced a clutch cable Wink
+1
(12-16-2015, 04:18 AM)AzBob_imp Wrote: Well, it would be wise to consider that the transmission in the S1000RR and RSV4 are built to withstand the hammering of a much higher horsepower engine. As I mentioned, the transmission in my CBR1000RR shifts without the clutch perfectly, every time. The CB, not so much. Even with the clutch, the CB's transmission is notchier and not nearly as smooth, in comparison.
that's strange... my CB has the smoothest transmission ever.
Been doing clutchless shifts since my '71 SL125. Never thought about it being unusual... guess I assumed everybody did it!
Guess I know what I'll be trying from now on. Appreciate the forum here for showing what other people are doing.
  2013 Clutch issue. Frulk_imp 7 909 04-17-2025, 10:46 AM
Last Post: Whoops
  Arthritis and Clutch Lever jodytek_imp 37 3,420 04-18-2021, 03:48 AM
Last Post: michael1954
  DCT w/Clutch. Have you cake and eat it too. activedirt_imp 18 1,382 04-24-2018, 01:10 PM
Last Post: Marc_imp
  gear shift problem 2017 model ? alprider 12 1,491 03-26-2018, 05:04 PM
Last Post: alprider
  Clutch and Brake Lever Adjustment retroman_imp 6 566 06-18-2017, 12:53 PM
Last Post: NightRider_imp
  Shift peg. Ghis_imp 2 261 07-26-2015, 08:43 AM
  Recommended shift points the Ferret 23 1,542 04-12-2014, 12:30 PM
Last Post: cbdtran_imp
