Does the CB1100 motor become smoother over time?
#31
(03-13-2019, 05:08 AM)GoldOxide_imp Wrote:
(03-13-2019, 04:40 AM)MMC_imp Wrote:
(03-13-2019, 04:37 AM)Rossi_imp Wrote:
(03-13-2019, 03:27 AM)MMC_imp Wrote: I ride my CB a lot! Over 53,000 miles in 3 years. I’ve found it gets “buzzy” when it’s time to clean, lube and adjust the chain.
Hi MMC,
I’m curious about the valve adjustments you have seen in that many miles?
Thanks
Hi MMC,
Thanks
None. Never even checked them. Still runs like a top!!
Hi MMC,
Thanks
That is some sweet talk there MMC.
Hi MMC,
Thanks
Lol. Yeah. Too bad most of it is commuting!!!! [Image: a7a3147bf763eb2b7fd29d934275bc53.png]
This bike has always ran great!
I do not experience engine buzz, but mine is a 2014 E.
(03-14-2019, 02:34 AM)jitaylor_imp Wrote: I do not experience engine buzz, but mine is a 2014 E.
(+1) I reckon "engine buzz" varies in the eye of the beholder. Sleepy
....or ear, or butt.
Ear and butt is much more correct. Thumbs Up
I have buzz in my grips. Grip Puppies have helped, but not eliminated my numb hands after 30-45 minutes ride time. Requent breaks are my solution.
(03-14-2019, 10:34 AM)DBM_imp Wrote: I have buzz in my grips. Grip Puppies have helped, but not eliminated my numb hands after 30-45 minutes ride time. Requent breaks are my solution.
I think some Forum members have gone to the foam-based grips. If that is something you can reckon with, it might help. Expect to maybe replace them yearly.
Interesting thread. On the last four obikes I have bought, the first thing I did was change the oil, and went from a full-syn to a dead-dino oil, Castrol 20W50. It made every bike run smoother, quieter, and shift better.
I reckon southern California riding demands a heavier oil more of the time due to its elevated regional temperatures.
I've owned a couple of bikes that required removal of the rear mufflers to remove the rear wheel (or at least removing them made the wheel removal easier.) I'm thinking of my 2003 Triumph Bonneville, specifically.
First time I replaced the mufflers, I tightened everything to spec, and immediately encountered a lot of vibes. So, upon the advice of an old timer (older than me??) I loosened slightly (key word is slightly) the muffler mounts and clamps, rode the bike around the block several times up and down through the rev range, then re-tightened everything I'd loosened. I think this procedure allowed the pipes to find their natural resting position, instead of being in a slight bind.
This cured the vibe issue, apparently coming from the engine through the pipes, into the frame, then to me. This also happened when I replaced one of the exhaust headers and mufflers (one piece) on my 2000 W650. This is purely anecdotal. What I'm suggesting is ...... you're probably feeling engine vibes, but there may be several reasons they're being transmitted to the frame and then to you.
Some of the first BMW K bikes experienced excessive vibes, that could be partially cured with a pair of shims. This was a case of the rear engine frame mounts being slightly spread perhaps 1/8" further apart, due to irregularities in the frames from bike to bike. In this case, the frame wasn't a 'cradle' like ours, but one where the engine was a stressed member. Some of the vibes were being caused due to the frame being under tension when the right and left mounts were fully tightened. A pair of shims removed this tension. However, the vibe issue on these bikes wasn't totally eliminated until the arrival of the K1200, with full frame and rubber-mounted engine. The flopped over four (Flying Brick) wasn't counterbalanced.
Food for thought. Hope you find the problem. BTW, the K100/K1100 did get smoother with miles
Bob
  motor cycle magazine subscription problems Houtman_imp 4 494 01-02-2021, 12:21 PM
  that pinging noise when you turn off the motor.... jedd_imp 24 1,353 04-06-2018, 05:17 AM
Last Post: VLJ_imp
  Hero motor corp Bheezy27403_imp 5 388 11-30-2017, 12:02 PM
  All Black Motor - Can you do anything with it? Wanka_imp 9 517 07-06-2016, 02:00 PM
Last Post: riceburner_imp
  Emissions for Motor Bikes activedirt_imp 12 814 10-29-2015, 10:39 AM
Last Post: rboe
  Tokyo Motor Show - New CB1100 Shinchan_imp 9 662 10-29-2015, 12:28 AM
Last Post: Shinchan_imp
  Vin# & motor # Ridem32_imp 17 1,052 05-12-2014, 10:10 AM
