Rubber Lever End Thingies
Likes Given: 1,015
Good man.
02-28-2015, 06:04 PM
Chapomis_imp Offline
Threads: 64
RE: Rubber Lever End Thingies
I spent an hour yesterday searching for RLETS. Most sites said that the part number did not exhist. I did find 2 sites selling them for less than $3 each, but then they wanted over $20 for shipping. Anyone have a reliable source they might want to shre ?
02-28-2015, 10:03 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Just go to the dealer. They can order them no problem. Still less then $3 each.
02-28-2015, 10:04 PM
Threads: 698
Likes Given: 792
Plug that number into GOOGLE and you will find more than you can imagine..all the way down to $2.06 each, but your local Honda dealer either has them or can order them for less than $4.00 each
https://www.google.com/?gws_rd=ssl#q=95010-16001
02-28-2015, 11:47 PM
Threads: 64
Thanks Ferret, I was Googling Honda part sites and entering the number there
02-28-2015, 11:52 PM
BIGGREEK_imp Offline
Threads: 6
Yea mine were about 3.60 each and they will ship it straight to my residence free of charge.
03-01-2015, 01:43 AM
Threads: 698
Likes Given: 792
Hmmm they left off "and very cool" 2010-2014 CB 1100's
Overview
95010-16001 CAP A, LEVER
Description
This Honda 95010-16001 CAP A, LEVER is used on these models and components:
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CB450K3 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
CB450K3 A MASTER CYLINDER + BRAKE HOSE
CB450K4 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
CB450K4 A MASTER CYLINDER + BRAKE HOSE
CB450K5 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
CB450K5 A MASTER CYLINDER + BRAKE HOSE
CB450K6 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
CB450K6 A MASTER CYLINDER + BRAKE HOSE
CB450K7 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
CB450K7 A MASTER CYLINDER + BRAKE HOSE
S65 A HANDLEBAR
S90 A HANDLEBAR + FORK TOP BRIDGE
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CT90 A HANDLEBAR
CT90K6 A HANDLE LEVER + SWITCH + CABLE
S65 A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CL125A A HANDLEBAR
CL450 A LEFT SWITCH + CABLE II
CL450 A RIGHT SWITCH + CABLE I
CL450K2 A RIGHT SWITCH + CABLE I
CL450K3 A LEFT HANDLE SWITCH + LEFT LEVER
CL450K3 A RIGHT HANDLE SWITCH + RIGHT CABLE + RIGHT LEVER
CL450K4 A LEFT HANDLE SWITCH + LEFT LEVER
CL450K4 A RIGHT HANDLE SWITCH + RIGHT CABLE + RIGHT LEVER
CL450K5 A LEFT HANDLE SWITCH + LEFT LEVER
CL450K5 A RIGHT HANDLE SWITCH + RIGHT CABLE + RIGHT LEVER
CL450K6 A LEFT HANDLE SWITCH + LEFT LEVER
CL450K6 A RIGHT HANDLE SWITCH + RIGHT CABLE + RIGHT LEVER
CL90 A HANDLEBAR + FORK TOP BRIDGE
CT90 A HANDLEBAR
S65 A HANDLEBAR
SS125A A HANDLEBAR
CA175 A CA175 HANDLEBAR
CA175K3 A CA175 HANDLEBAR + SWITCH
CB350 A LEFT HANDLE SWITCH + CABLE II
CB350 A RIGHT HANDLE SWITCH + CABLE I
CB350K2 A LEFT HANDLE SWITCH + CABLE
CB350K2 A RIGHT HANDLE SWITCH + CABLE
CB350K3 A LEFT HANDLE SWITCH + CABLE
CB350K3 A RIGHT HANDLE SWITCH + CABLE
CB350K4 A LEFT HANDLE SWITCH + CABLE
CB350K4 A RIGHT HANDLE SWITCH + CABLE
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CL125A A HANDLEBAR
CL175 A CL175 HANDLEBAR
CL175K3 A CB-CL175HANDLEBAR + SWITCH
CL175K4 A LEVERS + SWITCHES + CABLES
CL175K5 A LEVERS + SWITCHES + CABLES
CL175K6 A LEVERS + SWITCHES + CABLES
CL175K7 A LEVERS + SWITCHES + CABLES
CL350 A LEFT HANDLE SWITCH + CABLE II
CL350 A RIGHT HANDLE SWITCH + CABLE I
CL350K2 A RIGHT HANDLE SWITCH + CABLE
CL350K3 A LEFT HANDLE SWITCH + CABLE
CL350K3 A RIGHT HANDLE SWITCH + CABLE
CL350K4 A LEFT HANDLE SWITCH + CABLE
CL350K4 A RIGHT HANDLE SWITCH + CABLE
CL350K5 A CL350K5 RIGHT HANDLE SWITCH + CABLE
CT90 A HANDLEBAR
SS125A A HANDLEBAR
CB175K3 A CB-CL175HANDLEBAR + SWITCH
CB175K4 A LEVERS + SWITCHES + CABLES
CB175K5 A LEVERS + SWITCHES + CABLES
CB175K6 A LEVERS + SWITCHES + CABLES
CB175K7 A LEVERS + SWITCHES + CABLES
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CB750K A BRAKE MASTER CYLINDER
CB750K A LEFT HANDLE SWITCH + CABLE
CB750K1 A BRAKE MASTER CYLINDER
CB750K1 A LEFT HANDLE SWITCH + CABLE
CB750K2 A BRAKE MASTER CYLINDER
CB750K2 A LEFT HANDLE SWITCH + CABLE
CB750K3 A BRAKE MASTER CYLINDER
CB750K3 A LEFT HANDLE SWITCH + CABLE II
CB750K4 A BRAKE MASTER CYLINDER
CB750K4 A LEFT HANDLE SWITCH + CABLE II
CL125A A HANDLEBAR
CT90 A HANDLEBAR
S65 A HANDLEBAR
SL350 A CABLE + HORN & LIGHTING SWITCH
SL350K1 A LEFT HANDLE SWITCH + CABLE II
SL350K1 A RIGHT HANDLE SWITCH + CABLE I
SL350K2 A LEFT HANDLE SWITCH + CABLE II
SL350K2 A RIGHT HANDLE SWITCH + CABLE I
SL90 A TURN SIGNAL + LIGHTING SWITCH + CABLE
SS125A A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CT90 A HANDLEBAR
SL100 A TURN SIGNAL + LIGHTING SWITCH + CABLE
SL100K3 A TURN SIGNAL + LIGHTING SWITCH + CABLE
SL175 A CABLE + SWITCH
SL175K1 A CABLE + SWITCH
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CB500 A FRONT BRAKE MASTER + CYLINDER
CB500 A LEFT HANDLE SWITCH + CABLE
CB500K1 A FRONT BRAKE MASTER + CYLINDER
CB500K1 A LEFT HANDLE SWITCH + CABLE
CB500K2 A FRONT BRAKE MASTER + CYLINDER
CB500K2 A LEFT HANDLE SWITCH + CABLE
CT90 A HANDLEBAR
SL125 A TURN SIGNAL + SWITCHES + CABLES
SL125K1 A LIGHTING SWITCH + CABLE I
SL125K2 A LIGHTING SWITCH + CABLE II
CB350F A BRAKE MASTER CYLINDER
CB350F A LEFT HANDLE SWITCH + CABLE CLUTCH
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CT90 A HANDLEBAR
XL250 A LEFT SWITCH + CABLE
XL250 A RIGHT HANDLE SWITCH + CABLE
CB125S2 A SWITCHES + CABLES S2
CB350G A CB350G MASTER BRAKE CYLINDER
CB350G A LEFT HANDLE SWITCH + CABLE
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CB550 A FRONT BRAKE MASTER + CYLINDER
CB550 A HANDLEBAR + CABLE
CL125S1 A SWITCH + CABLES (2)
CT90 A HANDLEBAR
ST90 A HANDLEBAR + TURN SIGNAL
TL125 A HANDLEBAR + HANDLE LEVER + CABLE
TL125K2 A HANDLEBAR + HANDLE LEVER + CABLE
XL175 A HANDLEBAR + CABLES + MIRRORS
XL175K1 A HANDLEBAR + CABLES + MIRRORS
1974 CB125S2 A SWITCHES + CABLES S2
1974 CB200 A HANDLEBAR + CABLE
1974 CB350F A BRAKE MASTER CYLINDER
1974 CB350F A LEFT HANDLE SWITCH + CABLE CLUTCH
1974 CB450K1 A HANDLEBAR
1974 CB450K2 A HANDLEBAR
1974 CB450K3 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
1974 CB450K3 A MASTER CYLINDER + BRAKE HOSE
1974 CB450K4 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
1974 CB450K4 A MASTER CYLINDER + BRAKE HOSE
1974 CB450K5 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
1974 CB450K5 A MASTER CYLINDER + BRAKE HOSE
1974 CB450K6 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
1974 CB450K6 A MASTER CYLINDER + BRAKE HOSE
1974 CB450K7 A LEFT HANDLE SWITCH + LEFT LEVER + LEFT CABLE
1974 CB450K7 A MASTER CYLINDER + BRAKE HOSE
1974 CB500 A FRONT BRAKE MASTER + CYLINDER
1974 CB500 A LEFT HANDLE SWITCH + CABLE
1974 CB500K1 A FRONT BRAKE MASTER + CYLINDER
1974 CB500K1 A LEFT HANDLE SWITCH + CABLE
1974 CB500K2 A FRONT BRAKE MASTER + CYLINDER
1974 CB500K2 A LEFT HANDLE SWITCH + CABLE
1974 CB550 A FRONT BRAKE MASTER + CYLINDER
1974 CB550 A HANDLEBAR + CABLE
1974 CB750K A BRAKE MASTER CYLINDER
1974 CB750K A LEFT HANDLE SWITCH + CABLE
1974 CB750K1 A BRAKE MASTER CYLINDER
1974 CB750K1 A LEFT HANDLE SWITCH + CABLE
1974 CB750K2 A BRAKE MASTER CYLINDER
1974 CB750K2 A LEFT HANDLE SWITCH + CABLE
1974 CB750K3 A BRAKE MASTER CYLINDER
1974 CB750K3 A LEFT HANDLE SWITCH + CABLE II
1974 CB750K4 A BRAKE MASTER CYLINDER
1974 CB750K4 A LEFT HANDLE SWITCH + CABLE II
1974 CL125S1 A SWITCH + CABLES (2)
1974 CL200 A HANDLEBAR + CABLE
1974 CL450 A LEFT SWITCH + CABLE II
1974 CL450 A RIGHT SWITCH + CABLE I
1974 CL450K2 A RIGHT SWITCH + CABLE I
1974 CL450K3 A LEFT HANDLE SWITCH + LEFT LEVER
1974 CL450K3 A RIGHT HANDLE SWITCH + RIGHT CABLE + RIGHT LEVER
1974 CL450K4 A LEFT HANDLE SWITCH + LEFT LEVER
1974 CL450K4 A RIGHT HANDLE SWITCH + RIGHT CABLE + RIGHT LEVER
1974 CL450K5 A LEFT HANDLE SWITCH + LEFT LEVER
1974 CL450K5 A RIGHT HANDLE SWITCH + RIGHT CABLE + RIGHT LEVER
1974 CL450K6 A LEFT HANDLE SWITCH + LEFT LEVER
1974 CL450K6 A RIGHT HANDLE SWITCH + RIGHT CABLE + RIGHT LEVER
1974 CR125M A HANDLEBAR + CABLE
1974 CR250M A HANDLE GRIP + CABLE
1974 CT90 A HANDLEBAR
1974 CT90K6 A HANDLE LEVER + SWITCH + CABLE
1974 MT125 A SWITCHES + LEVERS + CABLES
1974 ST90 A HANDLEBAR + TURN SIGNAL
1974 TL125 A HANDLEBAR + HANDLE LEVER + CABLE
1974 TL125K2 A HANDLEBAR + HANDLE LEVER + CABLE
1974 XL100 A HANDLE SWITCH + CABLE K0
1974 XL100K1 A HANDLE SWITCH + CABLE K1-76
1974 XL125 A HANDLE LEVER + SWITCH K-K1
1974 XL125K1 A HANDLE LEVER + SWITCH K-K1
1974 XL175 A HANDLEBAR + CABLES + MIRRORS
1974 XL175K1 A HANDLEBAR + CABLES + MIRRORS
1974 XL250 A LEFT SWITCH + CABLE
1974 XL250 A RIGHT HANDLE SWITCH + CABLE
1974 XL350 A HANDLEBAR + HANDLE LEVER
1975 CB125S2 A SWITCHES + CABLES S2
1975 CR125M A HANDLEBAR + CABLE
1975 CR250M A HANDLE GRIP + CABLE
1975 CT90 A HANDLEBAR
1975 CT90K6 A HANDLE LEVER + SWITCH + CABLE
1975 MT125 A SWITCHES + LEVERS + CABLES
1975 ST90 A HANDLEBAR + TURN SIGNAL
1975 TL125 A HANDLEBAR + HANDLE LEVER + CABLE
1975 TL125K2 A HANDLEBAR + HANDLE LEVER + CABLE
1975 XL100 A HANDLE SWITCH + CABLE K0
1975 XL100K1 A HANDLE SWITCH + CABLE K1-76
1975 XL125 A HANDLE LEVER + SWITCH K-K1
1975 XL125K1 A HANDLE LEVER + SWITCH K-K1
1975 XL175 A HANDLEBAR + CABLES + MIRRORS
1975 XL175K1 A HANDLEBAR + CABLES + MIRRORS
1975 XL250 A LEFT SWITCH + CABLE
1975 XL250 A RIGHT HANDLE SWITCH + CABLE
1975 XL350 A HANDLEBAR + HANDLE LEVER
1976 CB125S2 A SWITCHES + CABLES S2
1976 CR125M A HANDLEBAR + CABLE
1976 CR250M A HANDLE GRIP + CABLE
1976 CT90 A HANDLE LEVER + SWITCH + CABLE
1976 CT90 A HANDLEBAR
1976 CT90K6 A HANDLE LEVER + SWITCH + CABLE
1976 MT125 A SWITCHES + LEVERS + CABLES
1976 TL125 A HANDLEBAR + HANDLE LEVER + CABLE
1976 TL125K2 A HANDLEBAR + HANDLE LEVER + CABLE
1976 XL100 A HANDLE SWITCH + CABLE K0
1976 XL100 A HANDLE SWITCH + CABLE K1-76
1976 XL100K1 A HANDLE SWITCH + CABLE K1-76
1976 XL125 A HANDLE LEVER + SWITCH K-K1
1976 XL125K1 A HANDLE LEVER + SWITCH K-K1
1976 XL175 A HANDLEBAR + CABLES + MIRRORS
1976 XL175K1 A HANDLEBAR + CABLES + MIRRORS
1976 XL250 A LEFT SWITCH + CABLE
1976 XL250 A RIGHT HANDLE SWITCH + CABLE
1976 XL350 A HANDLEBAR + HANDLE LEVER
1977 CB125S2 A SWITCHES + CABLES S2
1977 CR125M A HANDLEBAR + CABLE
1977 CT90 A HANDLEBAR
1977 CT90K6 A HANDLE LEVER + SWITCH + CABLE
1977 MT125 A SWITCHES + LEVERS + CABLES
1977 XL100 A HANDLE SWITCH + CABLE K0
1977 XL100K1 A HANDLE SWITCH + CABLE K1-76
1977 XL125 A HANDLE LEVER + SWITCH K-K1
1977 XL125K1 A HANDLE LEVER + SWITCH K-K1
1977 XL175 A HANDLEBAR + CABLES + MIRRORS
1977 XL175K1 A HANDLEBAR + CABLES + MIRRORS
1977 XL250 A LEFT SWITCH + CABLE
1977 XL250 A RIGHT HANDLE SWITCH + CABLE
1977 XL350 A HANDLEBAR + HANDLE LEVER
1978 CB125S2 A SWITCHES + CABLES S2
1978 CR125M A HANDLEBAR + CABLE
1978 CT90 A HANDLEBAR
1978 CT90K6 A HANDLE LEVER + SWITCH + CABLE
1978 MT125 A SWITCHES + LEVERS + CABLES
1978 XL100 A HANDLE SWITCH + CABLE K0
1978 XL100K1 A HANDLE SWITCH + CABLE K1-76
1978 XL125 A HANDLE LEVER + SWITCH K-K1
1978 XL125K1 A HANDLE LEVER + SWITCH K-K1
1978 XL175 A HANDLEBAR + CABLES + MIRRORS
1978 XL175K1 A HANDLEBAR + CABLES + MIRRORS
1978 XL250 A LEFT SWITCH + CABLE
1978 XL250 A RIGHT HANDLE SWITCH + CABLE
1978 XL350 A HANDLEBAR + HANDLE LEVER
1979 CB125S2 A SWITCHES + CABLES S2
1979 CB500 A FRONT BRAKE MASTER + CYLINDER
1979 CB500 A LEFT HANDLE SWITCH + CABLE
1979 CB500K1 A FRONT BRAKE MASTER + CYLINDER
1979 CB500K1 A LEFT HANDLE SWITCH + CABLE
1979 CB500K2 A FRONT BRAKE MASTER + CYLINDER
1979 CB500K2 A LEFT HANDLE SWITCH + CABLE
1979 CT90 A HANDLEBAR
1979 CT90K6 A HANDLE LEVER + SWITCH + CABLE
1979 XL100 A HANDLE SWITCH + CABLE K0
1979 XL100K1 A HANDLE SWITCH + CABLE K1-76
1979 XL250 A LEFT SWITCH + CABLE
1979 XL250 A RIGHT HANDLE SWITCH + CABLE
1980 CB125S2 A SWITCHES + CABLES S2
1980 XL100 A HANDLE SWITCH + CABLE K0
1980 XL100K1 A HANDLE SWITCH + CABLE K1-76
1980 XL250 A LEFT SWITCH + CABLE
1980 XL250 A RIGHT HANDLE SWITCH + CABLE
1981 CB125S2 A SWITCHES + CABLES S2
1981 XL250 A LEFT SWITCH + CABLE
1981 XL250 A RIGHT HANDLE SWITCH + CABLE
1982 CB125S2 A SWITCHES + CABLES S2
1982 XL250 A LEFT SWITCH + CABLE
1982 XL250 A RIGHT HANDLE SWITCH + CABLE
1983 CB125S2 A SWITCHES + CABLES S2
1983 XL250 A LEFT SWITCH + CABLE
1983 XL250 A RIGHT HANDLE SWITCH + CABLE
1984 CB125S2 A SWITCHES + CABLES S2
1984 XL250 A LEFT SWITCH + CABLE
1984 XL250 A RIGHT HANDLE SWITCH + CABLE
1985 CB125S2 A SWITCHES + CABLES S2
1985 XL250 A LEFT SWITCH + CABLE
1985 XL250 A RIGHT HANDLE SWITCH + CABLE
1990 CB125S2 A SWITCHES + CABLES S2
2013 CB500 A FRONT BRAKE MASTER + CYLINDER
2013 CB500 A LEFT HANDLE SWITCH + CABLE
2013 CB500K1 A FRONT BRAKE MASTER + CYLINDER
2013 CB500K1 A LEFT HANDLE SWITCH + CABLE
2013 CB500K2 A FRONT BRAKE MASTER + CYLINDER
2013 CB500K2 A LEFT HANDLE SWITCH + CABLE
03-02-2015, 02:28 AM
the_undecider_imp Offline
Threads: 43
(03-02-2015, 02:28 AM)The ferret_imp Wrote: Hmmm they left off "and very cool" 2010-2014 CB 1100's
Overview
Description
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
S65 A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CT90 A HANDLEBAR
S65 A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CL125A A HANDLEBAR
CT90 A HANDLEBAR
S65 A HANDLEBAR
SS125A A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CL125A A HANDLEBAR
CT90 A HANDLEBAR
SS125A A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CL125A A HANDLEBAR
CT90 A HANDLEBAR
S65 A HANDLEBAR
SS125A A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CT90 A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CT90 A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CT90 A HANDLEBAR
CB450K1 A HANDLEBAR
CB450K2 A HANDLEBAR
CT90 A HANDLEBAR
I'm only replying because that list is hilarious!
03-02-2015, 03:54 AM
Threads: 698
Likes Given: 792
ROFL probably not an easy read on a smart phone lol
Maybe the most relevant, most single used part in Honda history!
03-02-2015, 04:04 AM
Lord Popgun Offline
Virginia
Likes Given: 142
But I have to ask, did you really have to quote the longest list in history just to say you were replying?
03-02-2015, 04:48 AM
  2014 Shift Lever Extension Modification, Replacement? HeavyMetalMech_imp 12 1,102 08-02-2021, 10:29 AM
Last Post: HeavyMetalMech_imp
  Brake lever guard for track days mrded_imp 17 1,306 05-26-2021, 07:50 PM
Last Post: mrded_imp
  U-Lock Rubber Band LakeWylieJoe_imp 39 2,501 05-02-2021, 04:00 AM
Last Post: LakeWylieJoe_imp
  Little black thingies GIXXERMAN_imp 18 1,208 12-17-2013, 10:40 PM
