Sidestand Foot
jamboa_imp Offline
Threads: 10
RE: Sidestand Foot
I have managed to drop my CB11 on its right side while putting it on centerstand . What happened was I jerked it up on just one leg of centerstand and down it went. Dented tank!
03-28-2015, 01:22 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: Sidestand Foot
Jomboa,
I feel your pain. Mine went down in a low speed garage drop and dented my tank. I got a another tank from a member on the board.
If you can't get one from a member here, try Mr. T. He has used tanks and may be able to save you some money. A new one is not cheap. The good thing is changing it is not hard.
03-28-2015, 01:35 AM
Rocky_imp Offline
Threads: 26
RE: Sidestand Foot
(03-28-2015, 01:22 AM)jamboa_imp Wrote: I have managed to drop my CB11 on its right side while putting it on centerstand . What happened was I jerked it up on just one leg of centerstand and down it went. Dented tank!
My CB has been siting in my basement since last November waiting for winter to get over. I haven't manhandled it in a while so your post rang a bell with me.
Just a few minutes ago I was down there and wanted to move the CB over a bit and put it up on the center stand.
I put the stand down and slowly leaned it over to the right which seemed a long time before the other leg touched down. I was getting worried that it might go over - but it didn't and easily came up on two legs Big Grin
03-28-2015, 03:22 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: Sidestand Foot
If the bike is difficult to put up on the centerstand when putting it in its parking spot try this:
Let's say there is a 1" gap under the rear wheel when on the centerstand.
Place a piece of board or plywood or whatever, maybe 9" x 12", lengthwise on the ground where your front wheel would be. Any board thickness will help, the thicker the better, as log as there is a gap under the rear wheel when on the centerstand. In this case, 3/4", 7/8" might be optimal.
Now roll the front wheel on the board just past the midpoint, push the stand down with your right foot until you feel both legs touch the ground, steady the handlebar with the left hand (DON'T PULL ON IT), lift up on the grab rail as you put your weight on the centerstand arm with the right foot.
The board is a cheat that effectively moves the centerstand a little closer to vertical, and the centerstand's leverage arm is closer to it's ideal leverage point.
As long as the rear wheel is not touching, the bike will be perfectly stable and secure. Actually, it is a little more secure, as the front wheel is elevated, and less likely to roll off the stand!
03-28-2015, 04:50 AM
Damfino_imp Offline
Threads: 13
RE: Sidestand Foot
I dropped mine when my foot slipped off the center stand pad and I lost my balance. Kind of held onto the bike as it fell away from me and managed to lessen the blow. Only managed to scratch up my crankcase cover and bend my brake lever. Fortunately, no damage to the tank or turn signal's!!! Rolleyes
03-28-2015, 05:28 AM
Chapomis_imp Offline
Threads: 64
RE: Sidestand Foot
#26
I haven't taken delivery of my DLX yet, just been living vicariously through the Forum for the last month or so till the big day arrives (when he** thaws). So, never having had a bike with a centerstand I started getting a little concerned after reading various posts on this forum where riders either hated their centerstand or even worse dropped it while trying to put it up. I had trouble with the centerstand in the showroom and the sales person didn't offer me any advise, just helped, and said to myself "don't be a wimp Reed, you'll figure it out". I have watched a few recommended videos that made perfect sense and feel confident now. What I noticed in the videos was that most bikes with a centerstand also had a sidestand. Does the 2014 DLX have both ??
03-29-2015, 12:56 AM
Likes Given: 752
RE: Sidestand Foot
#27
Yes DLX has both. ALL bikes come with side stands, only some come with centerstands. Using a centerstand is learning technique. Even with technique some can be harder than others. To me a CB falls in the middle. Easier than some , harder than others.
03-29-2015, 01:06 AM
Threads: 64
RE: Sidestand Foot
#28
Pheew... Thanks Ferret. I was having nightmares about bringing the bike over on the ferry. It's already dicey taking a bike over when the seas are high, wasn't looking forward to standing on the freight deck for 2+ hours babysitting the bike on a centerstand.
03-29-2015, 01:17 AM
Django Offline
Threads: 71
Likes Given: 20
RE: Sidestand Foot
#29
I think, all CB1100 from factory have a side stand and a center stand.
I use the center stand in really most cases. It's not difficult, to push the bike onto the center stand. Correct technique counts, not force. When you give weight to the pad of the stand, it jumps onto the stand more or less by itself.
Just try and find out.
03-29-2015, 01:20 AM
Lord Popgun Offline
Virginia
Likes Given: 136
RE: Sidestand Foot
#30
Here is a big thread on using the center stand. Might help you.
http://cb1100forum.com/forum/showthread....nter+stand
03-29-2015, 01:35 AM
   Foot pegs Nick_imp 3 383 01-02-2025, 04:14 AM
  SHIFT AND BRAKE FOOT LEVERS omnimj_imp 14 1,120 09-23-2024, 12:56 AM
  side stand foot for 2017 Houtman_imp 7 602 09-17-2019, 08:13 AM
  SIDE STAND FOOT ENLARGER for 2014 peterbaron 22 1,419 12-14-2018, 01:31 PM
Last Post: alprider
  Moving foot pegs and controls forward 2+" RoyP_imp 14 988 12-12-2018, 02:09 PM
  Moving front foot pegs forward RoyP_imp 4 465 08-08-2018, 11:01 PM
Last Post: HigginsNYC_imp
  Adjustable Alloy Foot Pegs Frulk_imp 3 314 06-19-2018, 06:27 AM
Last Post: warman_imp
  Foot Control Relocation Kit reinie_imp 6 571 01-10-2018, 12:13 PM
Last Post: Nightengale_imp
  Driver foot pegs White Dog_imp 5 399 03-22-2016, 09:23 AM
Last Post: jedd_imp
  Side Stand Foot redbirds_imp 20 1,097 02-24-2016, 12:06 AM
