Where to buy Road Comet, etc
uscgmac_imp Offline
Threads: 23
RE: Where to buy Road Comet, etc
Is the 2013 and 2014 the same, the samurider website says its for a 2013 cb1100.
03-15-2015, 09:51 AM
Elipten_imp Offline
Threads: 13
Ask Mr T, but I doubt the same.
03-15-2015, 03:31 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
Well, check this out: http://www.samurider.com/?cat=259
Says '14
Ferret can confirm, but I believe the headlight is mounted at a different height on the '13 and '14 bikes.
03-15-2015, 09:32 PM
Likes Given: 752
It is my understanding on the 14 dlx, and I don't know about the 14 std, that the headlight and horns were raised 1" for a more traditional look.
Seeing as how now Samurider lists different Road Comets in the link above that popgun provided for 13s and 14's that this would indeed be the case
03-15-2015, 10:35 PM
simplest2remember_imp Offline
Threads: 8
Hmmm. Road comets seem to be the most natural looking front fairing, think I'll go for the taller aeroscreen in clear plastic, but not sure which black to get. Does anyone know where there are any pictures of the different stripe / 3 tone / standard black colours - since my bike is a custom colour (see below). BTW the rack is also custom made and works very well - it's a cross between the honda and the Rentech from memory - i.e. directly fits a honda box, but includes sissy bars. Dead cheap, but then I do live in Hanoi.
Anyway, back to the screen - the bike is 2012, which I think means it's the same fitting as 2010-2013, and the link I have is this one - http://www.samurider.com/?p=6690 - any pics of the black anyone? Which black would suit my bike?
(03-15-2015, 09:32 PM)Lord Popgun_imp Wrote: Well, check this out: http://www.samurider.com/?cat=259
Says '14
Yes I was looking at some new CB1100s only yesterday, examining the difference between the deluxe and standard. I was at the garage because I needed to have my weak horn fixed (I want no clever comments about this), the fix was, by the way, to simply bend it forward. Anyway, what I discovered was that not only were there 2 horns (dual tone?) on the newer bikes, but they are mounted under the headlamp, rather than a single one mounted in front of the radiator (radiator - I thought it was air cooled??). My older (2012) machine looked slightly different to the newer ones.
Hope this helps,
03-29-2015, 05:40 PM
Threads: 346
Likes Given: 963
#26
My 2011 and Pterodactyl's 2010 CBS have dual horns. The radiator is an oil cooler.
03-29-2015, 05:52 PM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Received: 41 in 24 posts
Likes Given: 123
#27
I looks to me as if you have a flat black on your bike. I would see if you can get one shipped unpainted and have it color matched when you get it or it will never look right.
03-30-2015, 01:28 AM
Threads: 8
#28
(03-30-2015, 01:28 AM)Randy B_imp Wrote: I looks to me as if you have a flat black on your bike. I would see if you can get one shipped unpainted and have it color matched when you get it or it will never look right.
A fine tip Randy B. That's exactly what I'll do.
By the way Randy - I took the liberty of checking out some of your pics, and it appears you have a comet 1 with the aeroscreen option - the same as I plan to get. Can I have some feedback on this - don't you regret not getting the standard screen, which would probably wobble less, or are you more than happy with the taller screen? And to put this in context, would you mind revealing your height? I'm 5 foot 11 inches.
03-30-2015, 02:28 AM
Likes Given: 752
#29
Simplest, was yours a wreck rebuild. I almost took it for a CB700S until I looked closer. The reason I ask, 2012, repaint, 1 horn, front and rear brake levers appear bent?
03-30-2015, 02:43 AM
Randy B Offline
Threads: 85
Likes Given: 123
#30
I'm fine with the taller screen. I'm 5'10" and somewhat of a bigger guy (260 lbs) and the wobble doesn't bother me, but there was a guy that put some foam between the gauges and the faring and he said that cured most off that issue. There is also a trick to put a thin strip around the inside of the housing around the headlight to keep the light from shining at you at night and I will probably do both of these "fixes" at some point.
03-30-2015, 03:35 AM
  power port and Samurider Road Comet Fairing 1 tdbru 9 972 05-04-2025, 07:20 PM
Last Post: tdbru
  Road Comet Masqeroad: A Beautiful Pragmatic Response rdprdp01 7 962 05-04-2025, 11:33 AM
Last Post: rdprdp01
  Road Comet: A Beautiful Pragmatic Response rdprdp01 12 973 10-29-2024, 12:25 AM
Last Post: rdprdp01
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,131 01-22-2023, 03:07 AM
  Road Comet Fairing Catbird_imp 47 4,187 08-16-2022, 10:33 PM
   Road comet 2 fitment correct?? gretle_2.0 8 799 05-07-2022, 11:08 PM
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,079 04-08-2022, 09:28 PM
  Road Comet 2 Impressions Frulk_imp 12 846 11-14-2021, 07:09 PM
Last Post: mrded_imp
  road comet fairing vfrpaul98_imp 75 4,997 10-21-2021, 02:41 AM
   Saturday morning project - Road Comet 2 Fairing LuckyNLife_imp 11 893 09-16-2019, 11:36 PM
Last Post: Cobalt23_imp
