Wheel cleaners
LouA_imp Offline
Threads: 14
RE: Wheel cleaners
1100rider...I use Simple Green Wheel Cleaner. There are two kinds of Simple Green,regular and the one marked Wheel Cleaner. It works great. Spray on,wait a bit and hose off. I highly recommended it.
05-08-2015, 11:21 PM
mustakoira_imp Offline
Threads: 3
Wheel cleaners
Another vote for WD40 here.
05-09-2015, 03:16 AM
Novice_imp Offline
Threads: 17
RE: Wheel cleaners
Honda spray cleaner and polish has worked great for me. It removes brake dust and chain grease plus bugs etc and it waxes too. I also used it to remove the sticker residue from the tank.
05-09-2015, 05:39 AM
Grinton_imp Offline
Threads: 10
RE: Wheel cleaners
(05-08-2015, 06:10 AM)mjezek_imp Wrote: WD40 for pretty much everything !!!!!! and yes clean and lube at the same time the chain !
personally do not recommend to use WD40 to clean the chain, you may remove the grease inside of the O-rings
05-09-2015, 06:56 AM
mjezek_imp Offline
Threads: 6
RE: Wheel cleaners
True that if you soak the chain in WD-40 .... LOL .... spray it on a shop towel first and then clean the chain ....
05-10-2015, 06:28 AM
wildezt_imp Offline
Threads: 9
RE: Wheel cleaners
#26
Good ole WD40 does the job.
05-10-2015, 08:32 AM
  Wheel Chocks DAC 8 770 07-22-2023, 10:23 AM
Last Post: DAC
  An update on my spoke wheel conversion. FLYTYM_imp 20 1,199 06-17-2023, 02:09 AM
Last Post: FLYTYM_imp
  Wire Wheel / Cast Wheel Swap pekingduck 37 2,474 06-05-2020, 12:35 PM
Last Post: michael1954
  Houtman's new wheel chock The A-man 14 1,004 07-04-2019, 07:05 AM
  modifying wheel trim misterprofessionality 18 1,354 05-14-2019, 02:49 PM
  cb1100 RS wheel conversion misterprofessionality 34 2,164 04-26-2019, 03:59 PM
  Another question about the spoke wheel conversion. FLYTYM_imp 2 327 05-14-2018, 03:34 PM
  17" Wheel Conversion mjezek_imp 38 2,324 12-24-2017, 03:00 AM
  Another 17" Wheel Convert chync_imp 17 1,189 05-14-2017, 01:18 PM
Last Post: Aussieflyer
  Stripping wheel lips PowerDubs_imp 6 471 04-05-2017, 09:25 AM
Last Post: TINK_imp
