ECU on its way to Guhl's!
Cormanus Online
Likes Received: 893 in 487 posts
Likes Given: 1,024
RE: ECU on its way to Guhl's!
Only a reflash can eliminate the speed limiter.
06-02-2016, 04:58 PM
DaSwami_imp Offline
Threads: 25
I would consider this just to remove the speed limiter. It is quite apparent to me the bike will easily smash the 112 mph (or whatever the factory limit is) if left to its own devices. Not that I need or want to go faster, it's just the principle of the matter....leave the untapped potential of the motor alone!
06-02-2016, 05:00 PM
Cormanus Online
Likes Given: 1,024
DaSwami, a few members have done it for precisely that reason.
06-02-2016, 05:07 PM
LARIDER_imp Offline
Threads: 2
(06-02-2016, 04:58 PM)Cormanus_imp Wrote: Only a reflash can eliminate the speed limiter.
I just want to get the rev limiter removed.
It's annoying when it kicks in because sometimes I have to really give'er the gas when I'm getting on the Freeway. (Some of the Freeway entrances I have to use actually have stop signs at the end of them!)
06-03-2016, 04:26 AM
Rebel73_imp Offline
Threads: 79
I talked do Don Guhl this morning. I should have my ECU back on Monday. I'll report back!
06-03-2016, 04:28 AM
Cormanus Online
Likes Given: 1,024
#26
I think a reflash can do that too.
06-03-2016, 07:59 AM
dsinned_imp Offline
Threads: 22
#27
Somewhere I read that the "revlimiter" ACTUALLY kicks in at ~9000 rpm, not at 8500 as the tach's redline suggests. Is this true? All the Dynojet test results I've seen show the cutoff engine rpm to be 8500. Not wanting to find out as I'm still breaking in the engine, nevertheless just curious what others here may have determined for themselves.
How much does Guhl charge for the reflash and where is he located, so I can calculate shipping?
06-03-2016, 08:51 AM
Rebel73_imp Offline
Threads: 79
#28
He charges $375 and is in PA.
102 S State St, Ephrata, PA 17522
The $375 includes 2 day return shipping.
06-03-2016, 02:57 PM
modmaster_imp Offline
Threads: 12
#29
I hope you have better luck than I did with the reflash. I have a K&N filter, TSR air filter cover, gutted stock headers, Oxygen sensor remover, and the reflash. It seems to have picked up a bit of part throttle responsiveness because of the increased ignition advance maybe, but I have to have the engine above 5000 rpms before I can give it half throttle with out it feeling boggy or soft as I wind it up. If I give it full throttle at anything below 6000rpms it holds back or is boggy again big time. I think it was set too rich for my bike as setup now. It feels like I'm riding a 600 supersport bike with a bit more grunt at low end. Not as good as the way it was set up with the stock ECU settings. I'm not happy with it and I guess I'll have to send it back to try some leaner settings at midrange and WOT settings.
modmaster
06-03-2016, 03:59 PM
CIP57_imp Offline
Threads: 68
#30
(06-03-2016, 08:51 AM)dsinned_imp Wrote: Somewhere I read that the "revlimiter" ACTUALLY kicks in at ~9000 rpm, not at 8500 as the tach's redline suggests. Is this true? All the Dynojet test results I've seen show the cutoff engine rpm to be 8500. Not wanting to find out as I'm still breaking in the engine, nevertheless just curious what others here may have determined for themselves.
You are correct, there is a 500 RPM difference between the tach and actual. Flashed bikes will redline @ 9500 on tach actual 9000 with the 500 RPM bump.
(06-03-2016, 03:59 PM)modmaster_imp Wrote: I hope you have better luck than I did with the reflash. I have a K&N filter, TSR air filter cover, gutted stock headers, Oxygen sensor remover, and the reflash. It seems to have picked up a bit of part throttle responsiveness because of the increased ignition advance maybe, but I have to have the engine above 5000 rpms before I can give it half throttle with out it feeling boggy or soft as I wind it up. If I give it full throttle at anything below 6000rpms it holds back or is boggy again big time. I think it was set too rich for my bike as setup now. It feels like I'm riding a 600 supersport bike with a bit more grunt at low end. Not as good as the way it was set up with the stock ECU settings. I'm not happy with it and I guess I'll have to send it back to try some leaner settings at midrange and WOT settings.
modmaster
I did not notice any of what you are describing. Had my bike flashed stock which had no noticeable difference under 6K and when added the full Yoshi it performed excellent with perfect air/fuel ratio's. I have video runs both stock and flashed with no bog or hesitation from the hole. 1/4 and 1/2 throttle response where also spot on.
06-03-2016, 09:28 PM
  Don Guhl No Longer Tuning Motorcycle ECUs tj_gee_imp 45 3,296 03-08-2022, 02:48 AM
  Guhl Tune/Derestriction Rox_imp 84 6,822 04-10-2021, 07:23 AM
