Yoshimura Slip-on!
ChipBeck_imp Offline
Threads: 29
RE: Yoshimura Slip-on!
Most aftermarket slip-ons are smaller than the stock muffler. This is the first one I've seen that is bigger than the stock muffler.
Chip
02-23-2015, 01:43 PM
1100rider_imp Offline
Threads: 41
I believe that the power commander would be a personal choice. I installed the RS-3 last summer and have not noticed any problems.
02-25-2015, 03:08 AM
Bike #12_imp Offline
Threads: 6
I ordered my RS-3 earlier today. I'll post a video after I get it installed.
03-01-2015, 06:25 PM
CBAnonymous_imp Offline
Threads: 5
Had my RS-3 installed on bike before even bringing home from dealership. Quite happy with it so far. Gives a nice throaty note, which I like.[url=http://s1299.photobucket.com/user/cstanley040254/media/CB1100/0A95E0E1-7C28-459A-9704-5ABBA0174000_zpsbvnsggvg.jpg.html][Image: 9a5d11ae6df7c381cd9aea4b33904e52.jpg]
03-15-2015, 06:20 AM
cwa5534_imp Offline
New to the Forum
Threads: 0
I had exact same problem with the center stand bracket, so no washers on mine either.
(02-12-2014, 02:31 PM)IndianRider_imp Wrote: Called home from work and found out the "package" arrived at home so got off early to install the slip on ..
First impressions :
It weights almost half as much as the stock exhaust .. Did not weigh the mufflers ..
The yoshimura finish/quality is ok .. not as good as stock and other exhaust systems I had in the past ..this is the cheapest yoshimura can ..
The yoshimura center stand bracket is a PITA to install and I busted my fingers but finally installed it without the washers and will revist the install later .. If any owners have tips on the center stand bracket install please share them with me
The sound with the baffle out is nice but a bit louder than my taste ..
With the quiet baffle in, I like the muted bassy sound and that's what I'll be running it with .. The stock can may go back on for any long trips
Overall the can looks pretty good to me with a sporty look .. The CB was missing the big bore Superbike hum and growl like my old zrx 1100 and the slip on gets it close to that feeling ..
[Image: c67ce1108b9487a9c407536d7608dcf6.jpg]
[Image: 3d1908e832c70c106e41d9521a0254eb.jpg]
03-28-2016, 09:38 AM
uscgmac_imp Offline
Threads: 23
#26
Tip on installing the washers, use a very small piece of black electrical tape to hold the washers in place and then install the bracket.
03-28-2016, 11:48 AM
adventureAF_imp Offline
Threads: 1
#27
(03-28-2016, 11:48 AM)uscgmac_imp Wrote: Tip on installing the washers, use a very small piece of black electrical tape to hold the washers in place and then install the bracket.
I'm trying to install this on a '14 standard. Is the center stand attached differently between the '13 and '14?
Sent from my SM-G900V using Tapatalk
02-04-2017, 08:28 AM
uscgmac_imp Offline
Threads: 23
#28
If you own a 14 and bought the 13 muffler the center stand is different. The 14 center stand spring is in the middle as the 13 has the spring off to the side. I bought the 13 muffler for my 14 and had to buy the 14 center stand bracket separate. You can order the bracket straight from the company.
Sent from my SM-T350 using Tapatalk
The 2013 muffler center stand bracket will not work on the 14. The advantage of the 2013 muffler is that it has a removable baffle as the 2014 version of the muffler does not have a removable baffle and is much quieter. The bracket will run you about another 40.00 or so.
02-04-2017, 08:37 AM
Threads: 1
#29
(02-04-2017, 08:37 AM)uscgmac_imp Wrote: If you own a 14 and bought the 13 muffler the center stand is different. The 14 center stand spring is in the middle as the 13 has the spring off to the side. I bought the 13 muffler for my 14 and had to buy the 14 center stand bracket separate. You can order the bracket straight from the company.
Cool, thanks for the info! I think I have both brackets, (I bought my can used) so I guess my question is more of installation. The instructions are a little vague, they say to remove the center stand shaft bolt, I don't see how to do this without dropping the entire center stand.
02-04-2017, 11:28 AM
dsan1964_imp Offline
Threads: 18
Yoshimura Slip-on!
#30
Same here I ordered a 14 center stand from yosh I bought mine used from jamboa. .... still need to put it on..
02-04-2017, 11:52 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 618 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Exhaust system/slip-on johnny_elpino_imp 26 2,060 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Arrow Slip-On Thoughts le_penseur_imp 84 5,089 05-15-2023, 05:20 AM
Last Post: mrded_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 3,610 11-29-2022, 10:38 AM
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,775 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,283 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  delkevik slip on mufflers outback_imp 4 545 10-14-2021, 12:44 AM
Last Post: outback_imp
  Delkevic Muffler slip-on wgscheib_imp 2 361 06-08-2021, 01:48 AM
  Arrow slip on mufflers DougsZ28_imp 15 1,218 05-13-2021, 04:09 AM
  The 2013/2014 Yoshimura Centerstand Bracket Issue Rox_imp 0 241 07-28-2020, 02:40 PM
Last Post: Rox_imp
