Where to tap speed sensor signal?
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 211 in 121 posts
Likes Given: 155
RE: Where to tap speed sensor signal?
Egleaves, Does your diagram have page numbers on it? What are they?
Example 20-5
I ask as in the service manual they do not reference bikes by 1100E or 1100SA. Just CB1100 ‘13 model, or CB1100A after ‘13 model. That would be the deluxe as in ‘14 it was the only ABS model. I’m not sure what E model is, although Cormanus posted a list somewhere.
I only have up to 2014. Don’t have any other other years.
07-05-2018, 03:06 AM
egleaves_imp Offline
Threads: 11
(07-05-2018, 03:06 AM)Lord Popgun_imp Wrote: Egleaves, Does your diagram have page numbers on it? What are they?
Example 20-5
It has 20-5 on the lower left and 20-4 lower right.
07-05-2018, 03:11 AM
Lord Popgun Offline
Virginia
Likes Given: 155
That diagram is not correct as I noted above. Max combined 2 different diagrams by mistake. I’m sure he will correct them as soon as he finds out.
Is your bike a 2014 standard (non ABS) or a DLX. The DLX has 2 mufflers and ABS (sensor ring on front and back).
07-05-2018, 03:21 AM
Threads: 11
(07-05-2018, 03:21 AM)Lord Popgun_imp Wrote: That diagram is not correct as I noted above. Max combined 2 different diagrams by mistake. I’m sure he will correct them as soon as he finds out.
Standard....no ABS.
07-05-2018, 03:25 AM
Lord Popgun Offline
Virginia
Likes Given: 155
Egleaves, Check your PM
07-05-2018, 03:52 AM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
#26
guys i just checked my left and right pictures and the now famous pink/green wire does simply not exist on the right page, it just stops on the left one.
normally not an issue until i stitched them together, what can we do?
07-05-2018, 04:25 AM
Threads: 349
Likes Received: 941 in 515 posts
Likes Given: 1,107
#27
CB1100A is likely the 2010 model. 2014 is CB1100E.
07-05-2018, 06:37 AM
Lord Popgun Offline
Virginia
Likes Given: 155
#28
Max, I am going to send them both the 2 proper scans. You just need to put the proper scans together. You got them mixed up. If you still have them, the file names should allow you to get the right ones matched up.
Or email me and I’ll re-send them.
07-05-2018, 07:12 AM
peterbaron Offline
Likes Received: 620 in 338 posts
Likes Given: 1,057
#29
(07-05-2018, 06:37 AM)Cormanus_imp Wrote: CB1100A is likely the 2010 model. 2014 is CB1100E.
This mayn't be quite correct, in Canada, when I bought my 2013 CB1100 ABS, it was 2013 CB1100A...but it is possible that 2010-2013 were called CB1100A..with or without ABS Huh, for 100% sure 2013 CB1100 A in Canada was ABS
07-05-2018, 09:23 AM
Threads: 349
Likes Given: 1,107
#30
You may well be right, Peterbaron, although the letter at the end usually denotes the year. However, some of the usuage seems to be at the discretion of national distributors. Honda Australia called my 2011 the CB1100B
07-05-2018, 09:53 AM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,559 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Turn Signal Indicators balkanhound_imp 5 787 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,822 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Negotiator-S Speed Pulse Modulator? TonyJames_imp 18 2,169 11-14-2022, 04:50 PM
Last Post: rich_imp
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 1,003 05-15-2022, 11:42 AM
  auto tune 02 sensor outback_imp 18 1,631 03-16-2022, 07:48 AM
Last Post: outback_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 3,060 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 847 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 1,088 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 865 02-20-2020, 10:22 AM
Last Post: Ben70_imp
