Tires?
jimgl3_imp Offline
Threads: 27
RE: Tires?
bridgestones need air in them for one thing. put that on the correct rim width and put air in it. it will not look like that.
12-28-2018, 07:11 AM
LongRanger_imp Offline
Threads: 129
RE: Tires?
Fair enough. If that's how it looked after it was mounted and inflated, then yikes!
12-28-2018, 08:07 AM
peterbaron Offline
Likes Received: 574 in 312 posts
Likes Given: 954
RE: Tires?
[url=https://www.tacomaworld.com/tirecalc?tires=140-70r18-140-60r18][Image: 41e27a09e379be55deb34507d06892eb.png]
[url=https://www.tacomaworld.com/tirecalc?tires=140-70r18-160-60r18][Image: 1b5be4370b92029550c8df12d7a58402.png]
*****[url=https://www.tacomaworld.com/tirecalc?tires=140-70r18-150-65r18][Image: dda493bae43669519c66c254af05f3fe.png] *****
[url=https://www.tacomaworld.com/tirecalc?tires=140-70r18-150-70r18][Image: 6ce410ab1cb12595411c2f0437722022.png]
...so now you know the difference...calculate....
***** 150/65/18 = closest to OEM
I would never install 140/60/18 on my 2014 CB
12-28-2018, 09:09 AM
bflint Offline
San Diego
Threads: 72
Likes Received: 24 in 7 posts
Likes Given: 7
RE: Tires?
(12-25-2018, 06:20 PM)Cormanus_imp Wrote: If you're prepared to go up a size, many of us are running Michelin PR3s. They come in a 120 front and 160 rear. We seem to be able to get the 110 front in Australia, but I've been told the rear is no longer available.
I know two CB riders with Pirelli Angel GTs which also seem good and an improvement on the OEM tyres. They come with a 110 front and a 160 rear.
Bridgestone has just released a Battlax T31 radial wchich comes in the OEM sizes. I've not heard of anyone running them yet, but I'm sure there soon will be. I'll be tempted to try them if the PR3 is no longer available.
I installed a pair of T31's about two months ago. Have about 500+ miles on them. Tough for me to really quantify diffs between T31, PR3, and Pirelli GT, but my personal fav is still the PR3 (went thru 2 pair).
12-31-2018, 06:58 AM
DBM_imp Offline
Threads: 16
RE: Tires?
I installed a pair of T31's about two months ago. Have about 500+ miles on them. Tough for me to really quantify diffs between T31, PR3, and Pirelli GT, but my personal fav is still the PR3 (went thru 2 pair). I have almost 4k miles on my new 2014 STD. The stock front tire is almost worn down to the wear bar on the center groove. The rest of the tire still looks great. Should l replace it now?
01-02-2019, 04:00 PM
Wisedrum Offline
Threads: 9
Likes Given: 3
RE: Tires?
#26
The law in Germany says yes, you have to.
Don't know the US law.
Some always are looking for safety while riding a motorbike. I have a different view concerning this topic.... I get more than double of the amount of km/mls out of the front tire Bridgestone BT54, though it doesn't seems to have any rubber on it right from the start in comparison to the rear one.
If you feel uncertain, go for a change! Or ride very cautios, especially more than you normally will do in wet and rainy weather. But there are no real preventing certainties while riding a motorbike, except the ones you have in your heard, in your controlcenter, if you're totally aware and awake out on the streets. Everything else comes after this.
Wisedrum
01-02-2019, 09:00 PM
alprider Offline
Threads: 92
RE: Tires?
#27
grip means life....Huh
01-02-2019, 09:06 PM
Cormanus Online
Threads: 346
Likes Given: 963
RE: Tires?
#28
And life means grip.
So which comes first? Huh
01-02-2019, 09:08 PM
alprider Offline
Threads: 92
RE: Tires?
#29
hehehe....
or only sharp turn drive even if it goes straight out until the tires are too down on the sides....Tongue
01-02-2019, 09:10 PM
Houtman_imp Offline
Threads: 115
RE: Tires?
#30
Always replace a tire when it is worn DOWN , do not wait till it is worn OUT.
01-02-2019, 10:52 PM
