Tall Windshield
curlyjoe Offline
boston metro
Threads: 18
Likes Given: 6
RE: Tall Windshield
Nortoon, you could contact parabellum to see if they have plans to design a shield for the '17 EX. It still may not fit if you move the turn signals so I would remove the turn signals just to see if the shield can be mounted properly. There's very little room for adjustments.
I have a parabellum shield but it is gathering dust. I found there was just too much wind turbulence at high speeds (70 mph) so I went with the dart flyscreen. I may take it out on a rainy day and cut it down far enough so my helmet is in clean air. After that, it should offer more protection than the dart. I also have a plexistar 3 that's gathering dust. Too much turbulence there too at higher speeds.
I can deal with wind noise (foam ear plugs) but turbulence that causes my helmet to "bobble" is not acceptable.
07-02-2017, 08:05 AM
Nortoon_imp Offline
Threads: 28
RE: Tall Windshield
(07-02-2017, 08:05 AM)curlyjoe_imp Wrote: Nortoon, you could contact parabellum to see if they have plans to design a shield for the '17 EX. It still may not fit if you move the turn signals so I would remove the turn signals just to see if the shield can be mounted properly. There's very little room for adjustments.
I found a lot of inexpensive turn signal brackets available on Amazon, so I ordered a set of chrome ones. However removing the signal lights to see if the shield would fit properly is something I will try on a rainy day. There have been lots of those these last two months. I am expecting there will be other adjustments to make so the shield will fit and perform properly.
Odd you would use the word "bobble" because my Bell MAG-9 helmet makes people look like bobble head dolls because is made so wide to hold the sun visor, face shield, speakers, and helmet peak.
I had a California Scientific windscreen on my CB500XA, and never experienced any helmet bobbling. But I have on my CB1100, so I am going to give this screen a good try. This year has also been terrible for bugs and rain.
In fairness my MAG-9 was never a tight fit (like my Shoei) and is now 4 years old. On my last ride I was able to eliminate the bobbling by removing the helmet peak which is redundant because of the sun visor anyway. It was also a great bug trap. Found two dragon fly corpses when I removed it.
I paid the extra $10 to have the screen tinted. I am hoping it will remove the glare from the sun that makes the digital dash impossible to read.
I also ordered the tallest screen hoping it will push the wind blast over my head and eliminate the wind noise. It would be nice to ride in a quiet zone, something I haven't experienced since I sold my Goldwing 28 years ago.
07-02-2017, 12:56 PM
Jurlie_imp Offline
Threads: 5
RE: Tall Windshield
Guys could you share your findings? What is the ultimate windshield for the CB1100?
The most quiet and comfortable at highway speeds?
04-23-2019, 04:41 AM
Likes Given: 753
RE: Tall Windshield
The law of aerodynamics says unless the top of the shield is just below your eyes (or higher so that you are looking thru it) it cannot push the air over your head. Air bounces over and around things but it only bounces so far.
Probably the best full protection shield for a quiet pocket would be a National Cycle Plexifairing (although you might not think that is the best looking shield aesthetically)
http://www.nationalcycle.com/plexifairing-hd.html
04-23-2019, 05:08 AM
TCinNC_imp Offline
Threads: 3
RE: Tall Windshield
(04-23-2019, 04:41 AM)Jurlie_imp Wrote: Guys could you share your findings? What is the ultimate windshield for the CB1100?
As I said in the beginning of this thread the NC Plexistar 2 with MRA X-Creen Touring wing mounted on top provides excellent wind protection with no buffeting at freeway speeds...
04-23-2019, 07:47 AM
fritzwilliger_imp Offline
Threads: 3
RE: Tall Windshield
#26
TCinNC,
The set up you've detailed is the very same one I've had on my CB1100 DLX for the past 4 years. As you mentioned, it works really well because of the wind splitting effect of the added MRA screen, which can be adjusted in multiple directions and with various degrees of tilt to optimize the airflow over and around my head and shoulders. I join you in highly recommending this particular combo set!
-fritz
04-23-2019, 09:16 AM
Stichill_imp Offline
Threads: 92
RE: Tall Windshield
#27
These tall windshields remind me of a high top fade haircut. ROFL
[Image: cb07b382eb090a1f62291a555de85b33.jpg&f=1]
04-23-2019, 01:35 PM
Jurlie_imp Offline
Threads: 5
RE: Tall Windshield
#28
How tall this combo is? Do you look at the road over it or thru it?
04-23-2019, 04:46 PM
TCinNC_imp Offline
Threads: 3
RE: Tall Windshield
#29
I’m 5’9 and I look over it, as mentioned by others the key is the X-Creen wing which has a multitude of adjustments for every individuals needs. Google MRA X-Creen Touring for more info.
04-24-2019, 09:48 AM
Threads: 3
RE: Tall Windshield
#30
How tall this combo is? Do you look at the road over it or thru it? I'm 6'3" and I look over the top of the windshield and X-Creen combo.
-fritz
04-25-2019, 03:56 AM
  Givi Airstar Universal Windshield - A660 peterbaron 2 574 12-28-2025, 02:15 PM
  Tall seat for 2017+ CB1100 Run Away_imp 23 1,609 09-18-2024, 02:51 AM
Last Post: Darrell_imp
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,132 01-22-2023, 03:07 AM
  windshield Griz53_imp 3 356 09-24-2022, 04:55 AM
Last Post: 1985CB450_imp
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,084 04-08-2022, 09:28 PM
  Windshield With Vertical Lip eddi0_imp 8 813 06-12-2021, 08:50 PM
Last Post: Randy B
  Light pod in windshield? bflint 6 609 08-12-2020, 02:42 PM
Last Post: bflint
  Windshield teamwoods5@att.net_imp 28 1,874 04-06-2020, 06:16 AM
  Slipstreamer Original large windshield IndianRider_imp 6 481 12-02-2019, 09:46 AM
Last Post: IndianRider_imp
  Windshield for cb1100ex 2017 Asdf23_imp 6 531 08-03-2019, 07:30 PM
