I think I've asked this before (drive line lash)
The 2017's slipper clutch may have something to do with mine having no drivelash, while Eric's '14 Standard had a lot. At the time, I attributed his bike's drivelash to a loose chain, just as I attributed his bike's heavy steering and rough suspension action to worn, squared-off tires.
I don't know. I just know that my '17 has no drivelash, on or off the throttle, gently applied, or hard on the gas.
(07-16-2019, 12:21 AM)The ferret_imp Wrote: Chop the throttle and you will really feel it, roll the throttle and you will hardly feel it
(+1) Sounds about right for me ('14).
can't recall ever double clutching the CB... just saying...
(07-16-2019, 03:40 AM)VLJ_imp Wrote: The 2017's slipper clutch may have something to do with mine having no drivelash, while Eric's '14 Standard had a lot. At the time, I attributed his bike's drivelash to a loose chain, just as I attributed his bike's heavy steering and rough suspension action to worn, squared-off tires.
Maybe I'll run across a 2017 I can take for a ride. It would be interesting to compare the two bikes, especially since Honda front suspension now uses what would appear to be a better fork, with damping handled by the Showa Dual Bending Valve system. Also would be interested to observe any difference between my 2014 and the newer bike with slipper clutch.
(07-16-2019, 08:30 AM)jimgl3_imp Wrote: can't recall ever double clutching the CB... just saying...
Perhaps you were thinking rev matching?
Double clutching requires going to neutral and releasing clutch between gears...helpful with a non-synchronous trans.
Hard to double clutch on a bike, I’d have thought, other than between 2nd and 1st.
yes, exactly. a previous poster posted "I don't think our CB1100 tranny would be defined a 'synchronized." I was being facetious
Sorry to bring up an old thread. I notice my CB front sprocket can still turn about 1 to 2 tooth position after I engage the gear (stationary with engine stop). I am wondering if this freeplay is what Max explain here, by design, or I had damage the gear. Sometimes when I upshift on the higher rev range I kind of miss it and end up in a kind of false neutral before the gear suddenly engage in a violence way (either up or drop back) with loud grinding and banging sound. The 60mm freeplay Max explained here, is it the distance the chain can travel front and back when gear are engage with a stop engine?
(07-14-2019, 02:35 PM)max_imp Wrote: Being curious i just measured the lash in all gears of the rearwheel, the first three gears are identical and have 60mm. travel ( freeplay or lash ) at circumference, the cushdrive in the hub has no play but some flexibility.
The chain has 5mm. play, that is about 10% of the total.
The chain tension is a conservative 40mm. between top and bottom movement.
As a reference the 40 year old cb550 measures 50 mm play when in first or second gear, so not much change there.
And Jim is exactly right, it shifts fine clutchless, when slowing down i apply a small amount of pressure on the gearlever, reduce throttle until it shifts down etc.
Zirconxi i have just uploaded a clip with all the different ways to measure gear lash on our bikes.
Hope this helps you.
https://www.youtube.com/watch?v=exAZj1X427s
Interesting vid Max.
Question, where it says this is "how I adjust chain", are you just showing before and after free play? I didnt see you doing any adjusting.
  Looking for Advice about etiquette on Skyline Drive. misterprofessionality 12 1,102 08-25-2021, 06:44 AM
  On-line Parts Fiche Question. 17-CB-002 5 589 04-27-2020, 06:11 PM
  Van asked me to have a word with you fine gentlemen. VLJ_imp 51 3,192 01-26-2018, 02:42 PM
Last Post: VLJ_imp
  Holding a line ohiorider_imp 13 895 10-22-2017, 11:58 PM
Last Post: jdvalero_imp
  Question re drive line lash on CB1100 ohiorider_imp 17 976 08-31-2017, 04:28 AM
Last Post: Rocky_imp
  Break in Drive Home From Dealer VAslim16_imp 5 382 05-17-2015, 04:08 PM
Last Post: Pterodactyl_imp
  Do dings and scratches drive you NUTS??? Rebel73_imp 40 2,048 04-29-2015, 11:09 AM
Last Post: gossman_imp
  Made her a place at the head of the line hondahoarder_imp 5 394 06-30-2013, 07:08 PM
Last Post: Guth_imp
