Rear Brake Hanging
Rboe, since you are used to short pedals on your other bikes, and since the rear brake on the CB is so useless anyway, or as so many people have told me you are not supposed to use the rear brake anyway, why not take the pedal off a shorten the end a bit?
(04-11-2015, 11:46 AM)White Dog_imp Wrote: Well I got my bike back today with a new rear rotor Honda shipped overnight. I was lucky that the head mechanic did the work. Here are two things I learned and hope everyone can remember.
1. The distance from the rotor surface to the caliper is about .050" with a new rotor.
2. It only takes about 1/4" depression on the brake lever to activate the pads to move tighter onto the rotor. That's not enough to stop the cycle but it is enough to build up heat and eventually the rotor will warp and the caliper will start touching the rotor causing it to bind.
While at the Honda shop today, I asked the Service Manager if the rear brake lever could be adjusted downward and he said they could do it for a fee. So, I politely declined but asked him how they did it. He pointed to this nut and said "turn it to lower the lever." Well I did, but it did not change the height of the lever up or down.
[url=http://s105.photobucket.com/user/WhiteDog14/media/DSCN5765_zpsqusoyjzh.jpg.html?sort=3&o=1]http://s105.photobucket.com/user/WhiteDo...sort=3&o=1
Does anyone know how to lower the rear brake lever?
WELL DUH! I WASN'T TURNING THE SMALL NUT. THAT'S THE ONE THAT LOWERS THE LEVER! THE BIG NUT IS JUST A LOCKING NUT.
Ferret. I use the rear brake for making tight U turns (like when I leave the Grotto and have to make a U turn on the divided road to head back home) and for aggressive stopping.
I'll use it the presence of gravel, so I don't consider it useless by a long shot. Smile
I've also used it to warp the rear rotor but that wasn't planned. Angel
  Rear brake pad replacement LongRanger_imp 39 3,393 05-03-2025, 10:45 AM
Last Post: Delphisa
  Rear Brake Pedal Adjustment Gone in 60 12 1,050 04-04-2024, 08:18 AM
   Rear brake pedal Mixagon_imp 28 2,066 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Rear brake pad thickness. 17-CB-002 4 431 06-18-2022, 12:42 AM
Last Post: 17-CB-002
  rear brake question Crossfire_imp 12 814 02-18-2022, 03:02 AM
Last Post: bvictory_imp
  Rear brake rotor and new pads Sandhog_imp 13 900 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Rear brake installation? White Dog_imp 9 787 07-27-2020, 02:48 AM
  Rear Brake "clunk" iogear99_imp 3 344 04-25-2020, 01:47 PM
  Rear Brake Help Needed White Dog_imp 21 1,420 10-01-2018, 07:10 AM
Last Post: Jim21680_imp
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,530 09-14-2018, 12:35 AM
