Flat Tire I am Stumped!!!
Alright guys autozone had the cores. I did notice some bubbles when I put soapy water into the core area. replaced the valve core I see no more bubbles. Did a short ride lost no PSI. I have plugs but looks like I need to invest in those co2 fillers incase this happens again. Anyone have any recommendations for a tubless patch kit or co2 fillers that are small enough to leave on the bike?
Great! Glad you found the source of the leak. Hope you ruled out air leaks at the tire bead also.
I carry a generic plug kit with 2 sizes of plugs from an auto supply store, along with a CO2 flat filler kit with 3 cartridges (one or two cartridges are not enough to fill the rear tire). Bicycle shops have a greater variety, and are usually cheaper. Be sure you get one for Schrader valve stems. There's plenty of room to store these and more under the seat.
Good Luck
Glad the new core fixed it! That's great news. I go a different route when it comes to CO2. Instead of relying on cartridges, I carry a mini 12V compressor from a company called Dynaplug (they also carry plug kits). So far, with Murphy on my side, I've never needed it (knock on wood). It's about the size of two decks of cards,
I also am definitely interested in tire road repairs and one shot inflators.
My local tire store just handed me several schrader valves (cores) when I inquired about purchasing a supply.
(05-29-2017, 06:21 AM)LongRanger_imp Wrote: Glad the new core fixed it! That's great news. I go a different route when it comes to CO2. Instead of relying on cartridges, I carry a mini 12V compressor from a company called Dynaplug (they also carry plug kits). So far, with Murphy on my side, I've never needed it (knock on wood). It's about the size of two decks of cards,
Same here. I carry a Slime mini compressor. It fits under the seat (even with a tool kit). I keep the plug kit in a pocket of my backpack. Like you, I've also never had to use it, but I feel better knowing it's there if I should need it.
[url=https://www.amazon.com/Slime-40001-Motorcycle-Tire-Inflator/dp/B000ET9SB4/ref=sr_1_3?s=automotive&ie=UTF8&qid=1496123386&sr=1-3&]https://www.amazon.com/Slime-40001-Motor...86&sr=1-3&
I have a [url=https://www.revzilla.com/motorcycle/dynaplug-micro-pro-inflator?gclid=CJbP8r3Zl9QCFc9XDQodD-8MYA]DYNAPLUG Micro Pro Inflator that I carry with me along with a tire plugging kit.
The micro pro has a screw on valve stem connector which I like better than the clamp on versions. It also has a port from which I can check the air pressure with a tire pressure gauge when the inflator is attached to the valve stem.
  Front Tyre wearing flat across centre Davidjill 8 1,378 05-29-2025, 07:24 PM
Last Post: Davidjill
  flat repair. ‘17 CB1100 EX sleeper_imp 15 1,318 08-29-2022, 06:31 AM
  2014 CB1100 - rotational vibration/wobble - flat spots in tires? rozbabbo1100_imp 7 659 08-04-2022, 10:10 AM
Last Post: 1973cb750
  my new pr3 has a flat spot max 9 749 12-30-2021, 03:53 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,227 07-19-2021, 08:28 AM
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 978 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Flat spot between 2500 and 3000 revs. Garry Richards_imp 1 283 06-16-2015, 10:49 AM
Last Post: Gumby 1100_imp
  OEM Battery just flat dead. meowguy_imp 27 1,973 08-27-2014, 02:42 AM
Last Post: AzBob_imp
  is this the first flat tire ??? Houtman_imp 5 500 05-25-2013, 11:34 AM
