First oil change
Django, you can do so.
I use the same oil 10W40 year in year out and lenghten the cange interval into 12.000km. After 44.000km no bad experience til yet. But who knows. I will find it out on the long run.
Wisedrum
(11-17-2017, 02:07 AM)SportsterDoc_imp Wrote:
(11-16-2017, 02:35 PM)LongRanger_imp Wrote: I live at 8,000' and have taken my CB to 14,000' many times (also joined by the Ferret and Offroad on their CB's). No issues with the stock air intake, or anything else, at those elevations. The bikes work great up there and have plenty of power, precise fueling, and excellent drivability. No need to overthink this.
I like the intake sound, whether air flow is improved or not.
Reminds me of buying a taller air filter for a 4 barrel carb to allow air flow around the circumference, rather than just through the silencing tube...or the open element on the Carter AFB on the 350 in my Datsun pickup.
Also, the air filter can be inspected by only removing the right side cover.
Curious, if you wear ear plugs and/or a helmet (as you should) how the heck do you hear "intake sound" with wind noise and the exhaust? I take it you don't wear either when riding?
Seems like messing with a snorkel on a finely tuned machine just to hear "intake sound" that you may or may not hear properly equipped is a battle not worth fighting?
I'll be doing my first oil change soon. Ordered Honda GN 10W-30, Honda filter, and a magnetic drain plug which is probably overkill in a Honda but I have them in all my vehicles. Hope I don't have that super tight factory installed filter.
(11-18-2017, 10:30 AM)Bar None_imp Wrote: I'll be doing my first oil change soon. Ordered Honda GN 10W-30, Honda filter, and a magnetic drain plug which is probably overkill in a Honda but I have them in all my vehicles. Hope I don't have that super tight factory installed filter.
Did my first one recently and it was really tight
Hand tightened plus a 1/4 turn on replacement
I wear a 3/4 helmet and often add ear plugs for long distances on the highway, such as 600 mile roundtrip to Clarkdale, AZ (daughter #3).
I used ear plugs on my last trip to Overton (160 miles round trip), before modifying the snorkel, but not since.
On my Bonneville, I could hear the snorkel removed intake over the exhaust, even after the center of the stock mufflers was drilled out.
It sounded like a 4 barrel with secondaries full open.
I do not like loud, but the Stock Bonneville came from the factory in stealth mode.
Most of my 33 four wheel vehicles and 17 M/C had modified intakes.
My wife's 2016 Nissan Frontier 4WD with 4.0 is almost stock, other than than strap hooks to secure a water tank for our ranch, interior and cargo bed LED lights. But the factory intake directed air flow to only one spot on the air filter, as evidenced by color. It was modified to eliminate that.
BTW, the cap could be glued back on the stock snorkel, if it had adverse effects.
As for performance, since I did the mod before break-in completed, I cannot advise if there is improvement, but it performed very well going up a 8%+ grade this morning, from 3,000 feet to 8,000 feet.
Getting on highway 95 out in the desert, this afternoon, I entered from a side road to merge with 80 MPH+ traffic. I had to back off before 4th to avoid overtaking a group. I was intending to wait until 1,000 miles before getting close to 8,000 RPM, but it sure pulls strong over 6,500.
(11-18-2017, 05:38 AM)Django_imp Wrote: Summer:
[Image: f39eacfecc84688db2bc621501363afa.jpg]
Winter:
[Image: 5a609c8e2fb1f837354df47282829aea.jpg]
Thanks for reinforcing one of the directions intended.
(11-18-2017, 12:17 AM)The ferret_imp Wrote: Seems to me the stuff I was using was a 15w40. Not sure if it was a t5 or t 6 but there does seem to be some discussion on the net that the formula was changed, along with a name change.
Google informs but it doesn't discuss lol
Shell changes the formulation and specs every few years to keep us all guessing. Big Grin
For the last few years, plain Rotella T was a 15w-40 dino oil that met the JASO-MA spec. That's what I used to use, but was having heat/shear issues in the extreme summer heat.
The synthetic T6 5w-40 is a synthetic that also met the JASO-MA spec and is what I use now.
Rotella T5 is a synthetic/dino blend, but as far as I know has never met the JASO spec.
Since Shell is fond of changing names, formulations and specs, it's a good idea to check the label on the bottle and make sure it meets the spec. For example, Shell makes two types of T6 synthetic (0w-30 and 5w-40), but only the 5w-40 oil meets the JASO-MA spec for motorcycles with wet clutches.
Helmets: I wear a helmet to (a) comply with NRS 486.231 when I am in Nevada or CVC 28703 when in California or and (b) to keep my head warm or keep the sun off my head when in Arizona or Utah. I ALWAYS wear eye protection and ALWAYS wear gloves. When I started riding on the street in 1963, there were no helmet laws in California nor M/C endorsements. I've had two crashes (not counting slides in the rain or on ice or dirt bike end-over-end) in 1963 and 1981. Was not wearing a helmet either time. 1963 resulting in a broken back and body cast, but no cuts, abrasions, etc. Repaired the bike and rode it wearing a body cast...until my parents forced me to sell it! 1981 resulting in injured wrist (minor) and scuffed boot. It folded the forks on my 1976 CB750F, but I was able to ride it back to my shop. Not against helmets, but prefer freedom of choice. I was party two in both instances. First should have been avoidable with more experience. Second would have been very difficult to avoid.
Battle: When I operated Cycle Tuning Unlimited, decades ago, I did very little trans, clutch or top-end rebuild, but did mostly "tuneups", which involved replacing points, setting gap/dwell, setting timing custom for the motor (often a major improvement, but more time consuming that just using a timing light), adjusting/jetting carb and often modifying the air box. This was on everything from 125 cc dirt bikes to the first years of the naked Gold Wing. "Tune-ups" also included skirting the intake side of two stroke pistons on bikes before the implementation of reed valves. Every client was satisfied.
OTOH we all could buy vehicles and leave them totally stock, but I do not find that as enjoyable...although the CB1100 is close to perfect, form the factory.
Researching before the CB1100 purchase, I read on this forum that there was little to be gained from opening up the intake and that may be correct. On the New Triumph Bonneville forum, the opposite was posted.
On Sportster.org, several dyno charts showed significant improvement on modifying a Sportster (883 or 1200) to stage 1 with high flow intake and less restrictive exhaust. More HP came from the high flow intake.
Some of those dyno charts were posted by George Crim
http://www.nightrider.com/biketech/lsr_gallery.htm
Two common ways of doing the intake mod:
a. Spend $100+ for a Screamin' Eagle high flow unit
b. Drill the air box or otherwise circumvent the limited flow around the ham can.
On my XLH883 I went the SE route along with 49 state legal H-D "Torque Mufflers".
On my 1200 Sport I drilled out** the back of the air box on the OUTSIDE the filter and drilled 1/2" diameter holes in the center of the mufflers (required 8" long drill bit). **actually done on a mill, 1/2 dozen 3/4" holes.
The % improvement was very close.
I am not twisting anyone's arm to mod as I did, but did offer photos to anyone interested.
After 600 miles, the snorkel mod and a LED tail/stop light are the only non-stock items. Once my Dart Marlin arrives, I am probably done.
On my 1976 CB750F, I did an air box mod, replaced dual points with a Martek 440 module, replaced factory exhaust for (a) appearance and (b) to facilitate riding off curbs. Had to weld a large washer inside the after-market exhaust to reduce the obnoxious decibel level. Reamed out the washer ID until it no longer sounded like a Cadillac 500 ci at full throttle...resulting in a mellow but throaty note. Also added a mini switch on the headlight bucket if I wanted to run without a headlight and an indicator light powered though a zener diode with a threshold voltage of 13.8 VDC. When illuminated, it indicated minimum stator/regulator output.
This is way too long, but hope it provides some comfort level for my minor mod.
Good enough, sir, carry on!
Hand tightened plus a 1/4 turn on replacement Just did the 600 mile service and didn't have a problem getting the oil filter
off.
Doc, thanks for sharing your experiences. I'll stayed tuned. Look forward to hearing more!
  tire change Tom_imp 7 730 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,636 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 910 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 4,073 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 823 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,243 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 1,042 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 420 03-12-2018, 08:46 PM
Last Post: Wisedrum
  Completed second oil change (DIY) venturer434_imp 5 470 05-11-2017, 07:47 PM
Last Post: Rocky_imp
  First Oil change Ltrypsin_imp 13 902 10-25-2016, 07:18 PM
