Race Tech Fork Springs
Can I necro this thread? It was posted to me as a reply and I was looking at the Racetech springs.
What I'm not sure of is, do I need any of the other stuff they're selling? Honestly doubt my seals/etc. have ever been replaced, but I don't have any reason to suspect a leak.
The previous springs I swapped were Bonnevilles, on a less than a year old bike, and all we did was open the tubes and swap springs. Little bit more cautious since this is my bike, and I'm not sure what the previous owner did, as far as maintenance, aside from fall over.
Changing fork springs improves the ride? Did you change to a different spring rate? Were you experiencing bottoming, or excessive front end dive when braking that possibly a higher rate spring cured? Installing a higher rate spring can also cause the forks to ride higher in their stroke, which may improve the ride, is this possibly the case you are experiencing? Or did you change to lower rate springs, which would make the ride smoother? If you replaced your stock springs with springs that have the exact same spring rate I don't understand how the ride can be improved. Can you please explain why your new springs improved your bike - what exactly are the changes you are seeing?
Thanks.
(04-25-2017, 10:51 AM)Dave_imp Wrote: Changing fork springs improves the ride? Did you change to a different spring rate? Were you experiencing bottoming, or excessive front end dive when braking that possibly a higher rate spring cured? Installing a higher rate spring can also cause the forks to ride higher in their stroke, which may improve the ride, is this possibly the case you are experiencing? Or did you change to lower rate springs, which would make the ride smoother? If you replaced your stock springs with springs that have the exact same spring rate I don't understand how the ride can be improved. Can you please explain why your new springs improved your bike - what exactly are the changes you are seeing?
Thanks.
I went with a heavier spring, I believe stock cb1100 to be set up for a 165# rider . I believe the springs are .75. I went with progressive 1.0. I also went with 15w. Oil . Night and day as far as the ride goes I used to crash down hard on potholes, cornering wash slushee, I need to bite the bullet on rear shocks to even it out.
Thanks.
I have a '13 model and RaceTech recommends a 0.83 Kg/mm rate for the forks for me, 175 lbs. Is the stock spring 0.75 Kg/mm? If so, all I need is the damping mods, right? Looks like totally new rear shocks are needed, any recommendations? I like RaceTech, they performed magic on my old ZX9R.
I love the Ohlins on my 2013 and 2014 but had them put on heavier springs because of my 220 lbs.
Thanks.
From the pics I've seen , the 2013 uses progressive (or dual) rate springs (ie, one section of coils is wound tighter than the rest), so spring rates for a progressive spring will typically have two numbers to indicate the two different coiled sizes.
[url=https://www.denniskirk.com/progressive-suspension/front-fork-springs-35-50-spring-rate-lbs-in-11-1527.p582656.prd/582656.sku]THIS IS AN EXAMPLE OF progressive spring rates.
That 0.75kg/mm spring rate is more likely that of a linear rate spring.
If you decide to go with Racetech emulators, [url=http://m.cb1100forum.com/forum/showthread.php?tid=7735]THIS POST has excellent info
(05-02-2016, 09:18 AM)TINK_imp Wrote: Just in case anyone needs it, here's my slide show on fork spring replacement > http://www.photosbytink.com/cb1100forksprings/
I have to agree with aschem; suspension is the best upgrade you can do to your bike.
It's been a couple of years since I upgraded my fork springs to Race Tech.
I recently serviced my fork oil with 15W and adjusted the preload to 15mm, per Race Tech's recommendation.
http://racetech.com/ProductSearch/12/Hon...ro/2013-17
TINK
Agreed, thank you for the slide show. Very interesting, I like you organized mind. Thanks!
(04-23-2016, 06:13 AM)aschem_imp Wrote: Installed them on Friday. As a 225lb rider, I can say that this has been the best $100 spent on my bike. Goes over bumps smoother and less harsh when I hit hit rough spots on the road.
Ooooooo. Just noticed.
So your preference? The CB or the Bandit? I am curious.
Just curious, why couldn’t you just remove the caps and pull the springs without disassembling the forks?
  Front Fork Springs sprint 1 390 05-28-2025, 03:17 PM
Last Post: SadRodBearing
  fork overhaul vs. fork replacement? misterprofessionality 20 1,765 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Race Tech Gold Valves in stock suspension ozigoo 9 695 06-24-2020, 03:59 AM
  Hyper pro fork springs HBFL_imp 14 1,101 02-17-2017, 08:01 AM
Last Post: gtmn_imp
  CB1100 Featured on Race Tech Website aschem_imp 23 1,435 02-02-2016, 08:48 PM
Last Post: spacetiger_imp
  Shock & Front Springs Motoblues_imp 0 164 10-19-2014, 10:17 AM
Last Post: Motoblues_imp
  Tech Questions from an Aspiring Owner calamarichris_imp 12 940 02-10-2014, 06:23 AM
Last Post: calamarichris_imp
