CEL after Jump Start
Found this thread today after having the solid MIL showing after a dead battery jump start. Not sure if what I did was the fix, but posting in case somebody else finds this thread for the same reason and wants to give it a try.
Followed the thread advice and service manual instructions of making sure the run switch was on, then turning on the bike without starting to see if the MIL flashed any codes. It didn't. Just glowed steady. Re-read things and realized I didn't have the kickstand down. While the ignition was turned on (and the MIL was lit), I lowered the kickstand. MIL turned off. Went for a 15 mile ride and it never came back on.
Did lowering the kickstand reset it? Seems random. But when it comes to bike electronics, if the manual or anyone here told me to pat my head and rub my belly while counting backwards from 10 while I turned on the ignition--I'd probably try it.
(04-11-2023, 10:26 AM)TXBikerGuy_imp Wrote: Found this thread today after having the solid MIL showing after a dead battery jump start. Not sure if what I did was the fix, but posting in case somebody else finds this thread for the same reason and wants to give it a try.
ROFL
Just out of interest, given both hands were occupied, how would one turn in the ignition?
ROFL
ROFL
That's what teeth are for Cormanus!
I have not gone thru all the replies, but have you tried cycling the ignition switch 3 times in a row?
  High engine revs on start up CBX1000_imp 21 1,826 06-06-2024, 02:40 AM
  Won't start RLS_imp 5 465 05-12-2022, 05:58 AM
Last Post: RLS_imp
  CB 1100 won't start GeorgiaRider_imp 30 2,083 12-19-2020, 11:19 PM
  Low rattle on cold start. shahyaan_imp 22 1,610 11-30-2020, 12:01 AM
  Bike crank but wouldn't start. zirconxi_imp 67 3,930 04-25-2020, 01:37 AM
Last Post: White Dog_imp
  strange start pdedse 48 2,829 02-02-2020, 06:34 AM
  Won’t start? bsavoy04_imp 26 1,460 08-05-2019, 04:38 AM
Last Post: LongRanger_imp
  2014 Start - Cutoff Switch Question deltamark 16 1,264 04-18-2019, 06:23 PM
Last Post: flynrider
  Motorcycle doesn't start, high oil temperature indicator comes on Saarang_imp 17 1,199 07-20-2018, 07:14 AM
Last Post: SportsterDoc
  No start - Battery replaced - No start jerrycon_imp 20 1,509 07-16-2018, 01:28 PM
