A problem for men...
(07-21-2013, 01:44 AM)Buffalohead_imp Wrote: It seems to me that leaning forward (I have never liked) would make the problem worse and, as BuffaloBill said, leaning back with a forward foot position would relieve pressure from the area. One thing to try would be handlebar risers. They will allow you to not lean forward. I'm still waiting to address the red vs. black issue so I can get my CB but I already have a set of Rox 2" risers ready to go (part# 1R-P2SSN). My friend has a set on his CB1100 and he thinks they're great. They make a bigger difference than you'd think. I think the bike looks better too.
Did these risers do ok with stock lines/cables?
Yes, they work fine but there is no extra length. Be sure to loosen everything including the throttle assembly. Then cut all zip ties. Zip tie everything back after you've tightened it all back up. Whoever designed these Rox risers is really clever.
BTW, I also have a set on my Suzuki TU250X. The reason they are so good is because they are universal and fit practically everything, as long as you get the right size for your handlebars. The CB1100 and the Suzuki TU250X are both 7/8".
Cool! I was just mainly concerned with brake line. I have 1" now & it's pretty tight.
(07-20-2013, 11:48 AM)mrhonda1987_imp Wrote: Put simply, after a good 20 miles or so at 55 to 60 mph, my testes are as numb as Hayden Christensen in the new Star Wars movies. My old CB750 caused the same issue, and the seat was much softer on that than the new CB1100. I'm thinking that the 919 would have the same problem, except for the nice forward lean. Any ideas to counteract the numbness? Am I the only one whose manhood feels like its iced down after a ride?
Sir ,
Please change your seat to a more cushiony one . I think That will also change your posture, will provide you more comfort and it will absorb some of the vibrations from the bike that is causing the problem .....
Cheers!!!!!!!!
I watched my friend install them on his CB and it works great but as I said, there is no extra length left over.
I have tried the gel pads and the Airhawk pad. They just don't do it for me even though I sold a lot of them when I was in Biss.
and people liked them. Even though my friends call me velcro butt they just move around to much for me.
This may not address the OP's specific problem, but wearing bicycling shorts underneath your riding pants makes a huge difference in comfort. Briefs will tend to bunch up and bind when you are moving around in the saddle.
(07-20-2013, 01:51 PM)Buffalohead_imp Wrote: Maybe motorcycle seats should be designed with a slight "dip" at the front of the seat. I suppose a seat could be altered and recovered to prevent such a problem and relieve pressure on the crotch. It might make a difference, especially for long rides. I'm also wondering if an enlarged prostate could have something to do with it on some men. It pushes from the other direction and can be uncomfortable. It's a common problem with older men.
(07-20-2013, 01:51 PM)Jim21680_imp Wrote: Do you wear boxers, boxer briefs, or tighty-whities? I usually wear regular boxers most of the time, but on longer rides, I try to wear boxer briefs. They seems to keep things in place a little better. If you haven't tried them yet, you should pick up a few pairs of silk briefs that feel oh-so-nice Smile
I was surprised 2 days ago when my Dr. told me to go back to the titie whities (actually, I have a drawer full of titie blackies). He said it's better on "the boys" if they don't flop around and are more snuggly protected and held in place. Who would have thought?
Airhawk R ordered. If nothing else, I can use it on any bike that I might need it on, 1100 or otherwise. I'll report back.
(07-21-2013, 07:07 AM)Yoyodyne_imp Wrote: This may not address the OP's specific problem, but wearing bicycling shorts underneath your riding pants makes a huge difference in comfort. Briefs will tend to bunch up and bind when you are moving around in the saddle.
I second this.. I've found that it's not the hardness of the seat (if it were then no one could be spending entire days riding a road bicycle with an unpadded seat especially with a hard seat nose sticking right where you'd think that it'd be hurting the most, but people do), it's 'where the stuff is' (and that any critical nerves aren't getting pressured).
I've done weeks of consecutive 8-14 hour days on a motorcycle, both feet forward cruisers and lean a little forward sport tour sitting positions without any problems. Wore spandex/nylon bicycle shorts on these trips. Did they actually prevent any numbness or pain problems ? Don't know, but I never experienced a problem doing it this way.
  Website Presentation problem rbike_imp 3 420 11-18-2023, 06:13 AM
  Thought I had my first problem Swartzracer_imp 13 956 07-25-2018, 09:20 AM
  Problem with RLETs Carlos_El_Pato_imp 15 1,217 05-28-2018, 04:21 AM
  gear shift problem 2017 model ? alprider 12 1,520 03-26-2018, 05:04 PM
Last Post: alprider
  Image viewing problem B-rad G_imp 5 451 03-04-2018, 11:06 AM
  Engine bucking problem fast eddie_imp 2 316 08-06-2017, 11:24 PM
  Different? seat problem Philip Roach_imp 28 1,952 02-06-2016, 01:18 AM
Last Post: Wisedrum
  Design Problem, Rear Wheel shifting to left mockhoff_imp 35 2,639 12-10-2015, 03:53 AM
Last Post: emptysea
  Fuel Injection Problem with a 2014 California model dave 72 5,467 05-06-2014, 10:04 AM
