Redesign ideas
I'd recommend a local seat guy if you have one (or two). Being local they are available for tweaking and customer service will be better. I now consider the seat as is from the factory a cover to keep stuff off the battery. Getting it redone to suit you can be inexpensive or pretty expensive (local guy redid my 650L and Griso seats for $120 each). Price will vary depending upon the work needed to be done.
I have a buddies Sargent seat (built on a Corbin core - original owner went with Corbin, thought it was terrible and had Sargent have a go at it - then sold that seat to my buddy: common thread, did not go with a local seat guy!) that is not too bad, has some good points and was used to make up a seat for me for the Griso.
With a local guy, you have a lot of choices for the seat cover material; not just what a mass producer does. Smile
(01-26-2016, 02:27 PM)Rboe_imp Wrote: I'll go for 5 and 7. More range would be nice, a buffer for an oops.
7; my Sidi boots and my feet tend to ride the rear brake (I bent it in a bit and that has helped).
Shaft drive: get a Guzzi. There are good reasons for shaft and chain. For this bike chain makes more sense.
Pegs, I'm tempted to put GL1800 pegs. Found out some Norge owners have done that. Wider, more comfort.
The balls of your feet should be on the pegs. In that configuration, it's nearly impossible to be touching the brake pedal. Of course, everyone rides how they like, but that's how pegs are meant to be ridden/used. :-)
Sounds like you should look for a cruiser rather than a standard like the CB1100.
(01-26-2016, 09:06 PM)Rocky_imp Wrote:
(01-26-2016, 02:48 PM)LongRanger_imp Wrote: ^ Agreed. I'm 6'6" 220 lbs and the ergos are spot on for me. No risers, no peg lowering, no Corbin. OE is fine.
Same for me at 5' 9", 180.
Everything is a natural fit for me.
I have to agree with my fellow Nova Scotian.. Rocky.
the bike fits me fine- the "only" issue I have (and its my issue more than the bikes) is I find the saddle uncomfortable during long cruises (3 hours plus).
But IMO the bike wasn't designed specifically for this so its a non issue.
The CB11 is a great all rounder, good at just about everything it seems...but it will never be the best at everything.
However- If you only own 1 bike - its the best looking, best value for the dollar out there (IMHO).
having said that I may pick up an after market saddle for longer all day rides.
You would think! Due to long legs, my feet tend to move a bit forward and toe down. Same issue I have on the Griso - but the Griso's brake lever is tucked in to such a degree that I have to search it out to use.
So in theory I agree, in practice, when I drape my body over the bike - theory goes out the window. Sad
At 6' tall and fairly long-legged, I can certainly understand just about all of your points (in fact, getting a taller seat made the bike go from "eh" to "perfect" as far as my own ergos go), but as most others have said, this was meant to be a retro bike, not a cruiser or long distance tourer, and being a niche bike on top of that...well, you no doubt have gotten the point by now.
I think they did a fantastic job on this bike - the jewel-like quality and finish is second to none, by the way - but just as with almost everything else in life, you just can't please EVERYONE, and with a motorcycle, there's no such thing as "one size fits all", either. In other words, changing the bike to fit your listed concerns would then make the bike less than perfect for every American that's shorter/lighter/however different than your own personal ideal.
Luckily there are outfits like Samurider and Webbike to help us personalize and fit the bikes to our incredibly varied physiques and tastes. Problem solved.
In my experience it was rare to find a bike that fit me perfectly. When I was young it was easier. Most of the comfort problems involved the seat. Later on in life it was the seat and handle bars. As more years went by it was seat, handle bars and foot pegs. The higher Corbin seat made a difference in longer ride comfort on the CB1100. There is a riding postilion you might try, it is called the Master Yoda position. It revolves around a slight lean forward, bending at the hips, elbows bent and forearms parallel with the bike, and slight pressure on the pegs. It really helps with back and shoulder pain. Depending on your height a higher seat, lower pegs and the Master Yoda position might just be the ticket. Good luck.
Folks accustomed to riding cruisers, especially those with large bellies or those who own bikes with forward controls, often have a difficult time accepting the idea of sitting slightly leaned forward with their feet below them and their forearms parallel with the bike. They tend to be the same riders who only know their rear brake, not their front, and resort to "layin' her down" as an evasive maneuver. I agree with a previous poster who mentioned that forward controls lead to reduced rider control.
Sounds like you need something more like my Vulcan Classic....
Sent from my C6725 using Tapatalk
I think I may "look" at a Triumph sometime. Big engine, 6-speed, belt drive. But, I'm in no hurry.
  Mod Ideas mgallimore32_imp 16 888 06-29-2014, 01:30 AM
Last Post: Ridem32_imp
