 Lumbago - lower back pain
(10-31-2016, 03:15 PM)dsan1964_imp Wrote: I have a nice alpinestar touring kidney belt... I like it. Recommend it.
I'm definitely looking into this as I had a back thing too after a trip this Summer.
(10-30-2016, 07:06 AM)Riko_imp Wrote: While its not an injury sustained from riding or a crash, it is related to the bike.
Yesterday I was best man for a friends wedding, it was a long day Smile
So after a night sobering out I collectd my bike, rode home, all is good, felt good myself.
Than tried to put the bike on its centre stand, as I always do when I enter the garage.
Than all of a suden Ièhad this severe pain at my lower back.
Left the bike on the side stand and I could not even stand on my two feet Undecided
Lumped my way to the living room still all geared up with back pack and all...trying to hold myself together.
I suppose I have an Lumbago, from my google research.
From reading, 50% recovers completely already after 1 week and 95% after 3 months.
I hope I'm in the first category cause it hurst like heck.
At first simply walking worked out fine, but now I can't even walk without pain, and if I walk I walk like a freaking monkey.
And laying down is also a battle against pain.
The bike is actually easy to put on its center stand.
But to protect the floor my dad put a piece of wood on the ground where the bike must rest on.
And that piece, how thin it may be, makes a difference in difficulty.
Without it, I bet I wouldn't get the injury.
That piece goes out the door.
Aiaiai, I hope it'll all work out fast...never saw this cuss coming.
I have sworn off centerstands. Centerstands can bring on exactly this kind of problem. I removed mine. It is not that easy to get the bike on this centerstand compared to a lot of bikes I've previously owned. That piece of wood had little or nothing to do with, I'd wager. You should not use that stand again unless you're willing to risk further injury and pain. You can get a real nice Pit Bull rear stand, takes some technique but practically no effort. GET HELP and a spotter the first few times until you figure it out, as with anything else.
Or, you can use a jack stand, but same thing, the bike can still fall over. Be careful out there.
Lumbago is a archaic term and is non-specific. You could have some very problematic injuries, such as a herniated disk. You definitely need to have it examined by a doctor. Good luck!
(10-30-2016, 07:08 AM)Cormanus_imp Wrote: Riko, that's no good. Go and see a physiotherapist as soon as you can to help you sort it out.
Absolutely, don't mess around with back pain.Thumbs Up
(10-31-2016, 09:22 PM)Cormanus_imp Wrote: But, Riko, having to lift the bike onto a piece of wood is what made it so hard.
indeed! Gotta find some compromise here, he wants to protect his floor and I dont want anything that raises the bike more than 3mm or so from ground level.
I already have a mat
[Image: db4b5615a24a35b71f7b0da0b1f04adb.jpg]
if it was up to me that will do to protect the floor....
Anyhow, Monday I was officially diagnosed with Lumabago.
I got 2 prescriptions, something against inflamation, forgot the name.
And something to relieve the muscle tension, muscle relaxant.
Don't have to work till the end of the week, so I hope I'm more or less restored by Monday. Undecided
Makes me wonder, what kidneybelts are worth it?
Too much choise, zero expereience and prices differ...
Are these cheap ones sufficient?
https://www.rad.eu/nl/x1/niergordels/f/10106
Or is a high end one a 'better' wich does the job better?
For example, this one from Leatt
http://www.fc-moto.de/epages/fcm.sf/nl_N...-Belt-0001
[Image: 3e68cbc95d6dc40143b96fa64f2d3227.jpg]
Its the only one wich seems to be 'certified' and 'tested'
tested and certified as impact protection: Lumbar EN1621-2 Level 1
ow believe me, the difference is night and day, you'd be amazed what a piece of wood of just 1cm (or 8mm) thick does to the centerstand proces Smile
And after investigation by the doc he asked me what I thought I had and I replied Lumbago, he concurred.
I had the least painfull one, so if its archaic, I had the least severe one, no harnia, no nerves touched etc, good old simple 'acute lumbago'
Still, I feel very handicaped.
Yeah, no doubt it didn't help matters at all. Just look at it like this, you are now in the club of folks who have bad backs. Your back will always have a tendency go out now so you gotta protect it. It's more valuable than the floor of your garage!
I used the centerstand on the CB1100 a few times and decided it wasn't worth the effort. I strained a few small muscles but never had what you've experienced. At that point I took it off, I'd already been using "race" stands for years so that was an easy call.
Our bodies break down over the years, sometimes they get help from a motorcycle accident or two (my case) and we gotta start adjusting or one day, sooner than we expect, something will happen and we won't be able to ride no more. That day is the one I am trying to put off as long as possible.
Use some force multipliers to help yourself. All the kidney belts and harnesses and stuff can't correct the real issue, weak back and abdominal muscles and bad lifting technique. In this case it's the centerstand itself (combined with the offending board) that creates bad technique, not you.
Take care of yourself, find a better way to get that bike up.
If you use a sheet of plywood so the whole bike is on it then it will be like using the center stand on the ground.
I've had easier bikes to pop up on the stand and worst (my old KZ550 Ltd was not easy, Goldwings were a piece of cake). For me, the trick is to shove the stand down with the foot while providing "some" assistance with right hand in pulling it up. You can do a good deal of the work pulling up with your hand/arm but that way leads to darkness. Pain. etc.
I suppose if you drew up a force vector diagram it would be about equal and you are essentially prying the center stand and the hand grip away from each other. You do have the advantage of your body weight on your foot though (some of us have more of an advantage than others Big Grin )
Get a sheet of 1/4" tempered hardboard, 1/4-3/8" wafer board (Blandex, OSB, etc.) which are solid materials and cheaper than plywood. I would imagine thick cardboard would be suitable too - if not that long lasting.
Good luck!
I'd say forget about "certified and tested"; a garden variety kidney belt is likely all you need. The purpose of kidney belt is not to offer any "impact protection"; if you need this, it should be provided by your jacket. The belt simply relieves your muscles from constant work and tension required to keep your spine reasonably straight, especially riding on slightly bumpy road. First and foremost, the kidney belt must feel very, very comfortable when worn under the jacket. It should be reasonably stiff, but if too stiff, it wont be comfortable. It must be slightly elastic, but not excessively so. I found that they wear out after a couple of seasons, but if the cost is in the order of about $25.- or so, I'd rather replace such item than use something "better made", more expensive and probably less comfortable. Mine is 7" wide at front, I wouldn't want it any narrower.
I find the center stand very easy to manage on the CB. If you are using your back or shoulders to get the bike on the stand you are doing it wrong. Upper body strength is not important. There is a thread on how to engage the CS easily.
(11-02-2016, 02:12 AM)Rboe_imp Wrote: If you use a sheet of plywood so the whole bike is on it then it will be like using the center stand on the ground.
Good luck!
No bike I owned required any showing or pulling; I could lift them on the center-stand merely by putting my full weight (80 kilograms give or take) straight down on the foot lever of the stand. Center-stands are, I believe, designed so that this is all that is required.
To those that doubt this, I suggest an experiment (on flat, hard surface, with side-stand extended, just in case):
Have a friend stand on the right-hand side of the bike, and hold it by both handlebars so it does not tip over. Now without touching any other part of the bike, step, while fully upright, in hard-sole footwear, on the center-stand's foot lever. Unless you are a true featherweight, I bet you the bike will pop on the stand. No discomfort or strain of any kind, and the effort will be no different than making the first step up a flight o stairs.
The trick is to be able to do it alone; that is to keep the bike in balance without being bent over it.
(11-02-2016, 06:03 AM)redbirds_imp Wrote: I find the center stand very easy to manage on the CB. If you are using your back or shoulders to get the bike on the stand you are doing it wrong. Upper body strength is not important. There is a thread on how to engage the CS easily.
thank I think I'm gonna have to look into that thread, just to be sure I did it right.
Best thing is using your full body weight, by simply standing on the CS, and engage it by a little pull on the rear rack (if installed).
Thats the theory, but I think I might have done it not in the ideal way to save my back.
And Sunday was the worst way I could have done it, if I remmeber correctly, I was in a hurry and happy to be home (after the long wedding day from the day prior), so I yanked on my rear rack to force it on the CS, instead of using the full body weight/standing on the CS manner.
However, because of the wood piece on the floor, the theory is more difficult to bring into practice...that is why I don't always do it the right way.
Somehow when I'm on the road and use the centerstand, I think I use the right way, but at home the wrong way.
Just wanted to add that my old boss was extremely active. He is an avid bicycles and hockey player now into his 70's. He started having back pains many years ago. He went to a Chiropractor for treatment and was given a list of leg lift "core" exercises as mentioned here. A few years later he ran into the chiropractor at a grocery store. The chiropractor asked him why he never came back for treatment? Bob, my old boss, told him he had been doing those exercises regularly and had not had a problem since. The chiropractor said, with a fair amount of amazement, "no one does those exercises!" just goes to show that we do, to some extent, control or own destiny. It's kind of a pay me now or pay me later type of a deal. So, I suggest we all start doing these "core" exercises so we can keep doing the things we love to do for a long time to come with minimal pain! Live long and prosper.
  Lower back pain pdedse 31 2,410 03-09-2025, 11:36 PM
   I am back from hibernation Ennsync_imp 1 216 05-11-2020, 03:11 PM
  Needing to lower my cb Gremlinsteve_imp 13 852 11-27-2019, 07:20 AM
Last Post: Redbird_imp
  Fork lower paint/ plasti dip? HBFL_imp 5 442 02-13-2019, 09:15 AM
Last Post: DBM_imp
  Polymer CB lower engine case protectors Frulk_imp 1 201 05-07-2017, 01:41 AM
Last Post: aschem_imp
  Test Ride/ Wrist Pain Kung Fu Joe_imp 11 816 06-19-2015, 02:58 PM
Last Post: Kung Fu Joe_imp
  Rust on lower fork bracket LiveToRide_imp 134 8,965 05-12-2015, 05:23 AM
Last Post: Elipten_imp
  Lower Priced OEM Parts speedgeezer_imp 9 631 06-22-2014, 04:59 AM
  lower seat? ncgeezer_imp 7 659 02-13-2014, 03:38 AM
Last Post: AllenM_imp
  Do mods lower value? HikerToo_imp 17 1,014 08-05-2013, 12:01 AM
Last Post: Buffalorider_imp
