Needing to lower my cb
Anyone got any idea on how to quickly and easily lower my cb about 1 inch or so
I don’t have a lot of time to build a system. So I’m looking to just buy and bolt it on
Don't know of any "bolt-on" way to lower the CB. You can slide the forks up in the triple tree slightly and add shorter rear shocks. That will get you a little. You can also look into getting your seat worked on to remove some height.
Webike has a set of lowering links listed. That they may not have, or may not fit your model. But here is the link: https://japan.webike.net/products/23842994.html
If not mistaken, there already was a thread or question like yours some time ago...shorter rear shocks or so???....search Forum.
Here are a few, good luck.
http://cb1100forum.com/forum/showthread.php?tid=12386
http://cb1100forum.com/forum/showthread.php?tid=7084
http://cb1100forum.com/forum/showthread....ear+shocks
Gremlinsteve, I have seen on this forum someone bolted on T100 shocks to lower the rear...
Ben
Best way is to buy shorter shocks and then raise the forks an equal distance in the triple clamps. Have you looked into a lower seat? I did see a kit somewhere that moved the upper mounting point for the stock shocks to lower the ride height.
Thanks for the direction
I’ll research each one carefully and decide
What’s right for me
The t100/120 shock sounds easiest
Provide pics when completed, please
I wonder how raising the CB two or three inches would go. Hmmm.
See http://cb1100forum.com/forum/showthread.php?tid=7084
  Lower back pain pdedse 31 2,899 03-09-2025, 11:36 PM
  Fork lower paint/ plasti dip? HBFL_imp 5 485 02-13-2019, 09:15 AM
Last Post: DBM_imp
  Polymer CB lower engine case protectors Frulk_imp 1 224 05-07-2017, 01:41 AM
Last Post: aschem_imp
   Lumbago - lower back pain Riko_imp 32 2,200 11-04-2016, 08:03 AM
Last Post: Ulvetanna_imp
  Rust on lower fork bracket LiveToRide_imp 134 10,684 05-12-2015, 05:23 AM
Last Post: Elipten_imp
  Lower Priced OEM Parts speedgeezer_imp 9 713 06-22-2014, 04:59 AM
  lower seat? ncgeezer_imp 7 741 02-13-2014, 03:38 AM
Last Post: AllenM_imp
  Do mods lower value? HikerToo_imp 17 1,143 08-05-2013, 12:01 AM
Last Post: Buffalorider_imp
