Good article comparing the CB with the BMW R nine T Pure
(08-10-2017, 11:11 AM)Capo_imp Wrote: To the best of my knowledge, there are no shaft drive race, or true high performance motorcycles. There are ample benefits and drawbacks to each.
K1300S would qualify in my book, but your point is well taken.
Good review.
I agree on the "almost like a cruiser" feel
Riding stance is the same as the DLX and my Vulcan vaquero. "
Why are you guys lubing an o-ring chain?
All the lube you need is already sealed inside the rollers.
IMO- at best you are simply keeping cosmetic rust away. At worse you are adding a sticky substance that will attract dirt and therefore friction and wear/tear on the mating surfaces.
https://www.youtube.com/watch?v=O6O7RWIjl4A
About as close as you get to a high performance shaft bike. I have a R1100S. I would call it more a sport touring bike, but it is styled more toward sport.
(08-13-2017, 03:29 AM)PowerDubs_imp Wrote: Why are you guys lubing an o-ring chain?
Not all of it.
Chain needs lubrication at two points:
First, at the contact of links and rollers. On modern chains this is indeed already sealed inside the rollers.
Second, at the contact of the outside surface of the rollers and sprocket teeth. This lubrication must occasionally be re-applied, or both the chain and the sprockets will wear out and will have to be replaced more often than necessary.
Looking at the article, why would you want to do a "clutchless upshift"??
Got me? I use my clutch every shift up or down.
Guzzi has raced in the Big Twins (I think, I forget the section it raced under - and won it one year). Which segways into this: comparing the R9T to the Moto Guzzi Griso would have made more sense. Not the CB1100. Apples and Oranges.
Back to racing, people would ask about the shaft vs. chain, figuring the chain had the advantage. The Guzzi racing team said that the chain had the advantage early in the race (this was in the 90's I think) but wore and lost effeciency while the shaft remained constant. Not sure that would remain true today.
Full disclosure; I own a Griso and the CB.
(08-13-2017, 01:09 PM)The ferret_imp Wrote: Got me? I use my clutch every shift up or down.
I use the clutch on all down shifts but only on 1st to 2nd on upshifts. With the Honda trany, there is little need for the rest. I'm sure I could eliminate the 1st to 2nd as well, with better coordination!
Yes, close. There are examples of taking oddball engine configs and drive trains and layering performance goodies to make them sport- ish. I've ridden a friends and it is cool. But an unusual outlier, and even BMW has gone to chains for their S1000RR.
(08-13-2017, 11:49 AM)DaSwami_imp Wrote: Looking at the article, why would you want to do a "clutchless upshift"??
Once you use a quick shifter, it's intoxicatingly fun and the propulsion it provides makes for a nice sensation.
  Excellent article all about the CB1100’s PowerDubs_imp 15 1,452 02-04-2023, 05:37 AM
  CNN article on electric MCs pdedse 3 407 01-01-2020, 12:40 PM
Last Post: Bheezy27403_imp
  Good article and also contains launch video ohiorider_imp 3 329 10-18-2018, 11:06 AM
  Cycleworld article and custom cb Elevenminusoneblade_imp 0 185 09-16-2017, 12:46 PM
Last Post: Elevenminusoneblade_imp
  Yahoo article on CB1100 immgunn_imp 19 1,426 11-05-2015, 05:57 AM
Last Post: floopfloopington_imp
  2015 CB1100 Article in RideApart Pauley 38 2,332 03-27-2015, 02:17 AM
Last Post: treytexag_imp
