  • 1 Vote(s) - 5 Average
Basic Maintenance: Brake Fluid
peterbaron Offline
Likes Given: 1,013
RE: Basic Maintenance: Brake Fluid
This method is not good : "So I held it open with one hand while pumping with the other"... unless the end of the outlet hose is submerged in a bottle of fluid and already primed by method below.
It might be ok with the front calipers, not the rear one.
This methot IS good: "Then I switched to the open-and-close routine on the valve for each pump of the brake lever and this made the fluid move along better", always creates good working pressure pressure.
The best bleeding methods:
#1 by pressurizing the reservoir = needs special equipment
#2 by vacuum bleeder = needs special equipment
#3 pumping by brake lever or pedal with an outlet hose submerged in a bottle of fluid and already primed = no special equipment needed
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
08-21-2026, 10:15 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Given: 1,002
I always do mine, front and rear, by pumping up the vacuum then opening and closing the bleeder valve before the vacuum drops too far. I never really pay attention to whether or not there's fluid in the catch reservoir on the other end, but invariably the outlet hose is submerged in the old fluid half-way through the process. Always works fine for me. I use the "pump with one hand, control the bleeder wrench with the other hand" method.
If I'm doing multiple bikes in one day, when I'm done I will have switched hands for pumping and have given my hands and wrists quite a workout.
08-21-2026, 10:56 AM
  Basic Maintenance: Handlebar Weight Assembly Replacement rdprdp01 4 537 07-01-2026, 07:19 PM
Last Post: HondaLou
  Basic Maintenance: Installing RLETs on a CB1100 (All Models) rdprdp01 20 2,490 02-20-2026, 02:53 PM
Last Post: E11even_Hunnit
  Basic Maintenance: Drivetrain (chain, sprockets, brakes) rdprdp01 2 112,655 07-12-2025, 11:33 PM
  Basic Maintenance: Paint Touchup rdprdp01 0 356 07-06-2025, 10:40 PM
Last Post: rdprdp01
  Basic Maintenance: Lithium Battery rdprdp01 7 1,323 06-11-2025, 10:35 AM
  Maintenance Check List for 2017 17-CB-002 1 546 04-11-2025, 05:25 PM
Last Post: rdprdp01
  Basic Maintenance: Daily Pre-Ride Check rdprdp01 0 357 04-10-2025, 07:38 PM
Last Post: rdprdp01
  Basic Maintenance: Turn-Signal Switch rdprdp01 0 359 04-10-2025, 07:31 PM
Last Post: rdprdp01
