Electric Gloves/gear
Thanks for the heads up, JD. All I know at this piping is the batteries charged quickly. Next cold day, I’ll test the battery life.
I purchased (well ,my buddy did through his shop) a pair of gloves before my mountain trip. As stated, GIANT pain in the butt to wire them through your riding jacket. I ended up taping the wires in under the jacket liner and this helped with the bird nest of wires and the controller.
I wore the glove liners under my Klim windstopper gloves and was very comfortable other than being a little tight. I may purchase another pair of Klims in a larger size just for cold weather riding with the heated liners (the Klims are remarkably warm for how thin they are, almost no wind through at all).
The gloves are great, the brand escapes me right now, and they were on closeout for $77. Seems like a good deal. However, I will now be buying a heated jacket liner just to ease the use of the gloves.
It never ends...
The quickest of early reviews on the Joe Rocket Burner gloves....
Was not out long enough to test battery life, but I've used the gloves for a total of about 1.5 hours with 1 hour of that on "High" and they are not yet in need of charging.
Gloves get plenty hot when out of the cold/wind.
My fingers still got very cold after 15 miles (about 50 minutes) on the bike. However, it was +3f with a -12f windchill and I have neither heated grips nor hand guards on my bike.
Not great results, but also not a very fair testing environment.
More on these gloves at a future date.....probably February. LOL
(12-02-2017, 08:10 AM)EmptySea_imp Wrote: Just bought these. Rechargeable batteries. Supposed to work for at least 3 hours on High, longer if I don’t need to be as toasty. 55 tomorrow, so I won’t be testing them anytime soon, but I will report back once I do
So, I've worn these on two rides. I think it is important to note that one ride was 15 miles @ about 3 degrees Fahrenheit and the other was about 12 miles @ about 24 degrees Fahrenheit. It is also important to note that I do not have heated grips or hand guards. I feel that those temps are on the "extreme" side of things and it may be unrealistic to expect these gloves to keep my hands "warm" at these low temps. However, they should at least keep my hands from feeling cold. They did not.
The batteries charge easy enough and they include a double-ended charging cord to do both batteries at once. The batteries were fully charged in advance of both rides, although on the first ride, they were charged a couple of days prior to their use.
The gloves felt warm enough in the house, but in just a few minutes after mounting up, my hands were cold. Really very very cold. Burning fingertips cold. That was the 3 degree day so I chalked it up to the extreme cold. I did check the gloves again inside and again they felt warm. I was under the impression that these gloves are wired into the fingers, but only the palms get warm. This is "no bueno" since I don't need my palms warm; I need my fingers and the back of my hands warm.
My hands fared no better on the 24 degree ride. This time, the batteries were charged fully immediately prior to the ride, not sitting around even overnight. There are four settings on each glove and both gloves were on "high". I wound up trying to keep my fingers warm by holding my hands against the CB1100's cooling fins at stop lights/signs. I was very disappointed in these gloves at this point.
This morning, I thought I'd give them one more chance in a less extreme environment--shoveling snow in temps in the upper 20s. No wind to speak of and I figured that the physical activity would help my hands stay naturally warmer and the gloves would then have an easier time warming them. Same result only I didn't have the CB1100 engine block to warm them between scoops of snow.
One last thing... they do not seem to offer much in the way of abrasion protection either.
So, I have a glove that doesn't protect me in a fall and doesn't protect me from the cold, even for walking around.
Do not buy these gloves.
I have two pairs of heated gloves that I can't stand. They get plenty hot but where the hard plastic knuckles cover my knuckles, it gets so hot that I can't wear them. The plastic pushes the heating elements into my hand and that is very uncomfortable. I also don't like the bulk of thick gloves. My solution is to wear lighter deerskin gloves with long gauntlets and use Cycle Gear's heated glove liners. That combo has kept me warm in any weather and even when my hands get wet. Quality-wise, the liners have performed fine for three years. Cycle gear pretty much just replaces things with no questions asked, so that's nice.
A couple years ago I was at Aerostich in Duluth and was able to go through their leather glove bin and pick up a left and right glove that fit fairly well with liners. Still, no padding, still feels like two gloves and it pinches off circulation. I did recently convert the simple button controller in the liner to a wireless unit so I can tweak the levels without messing with the button which is usually all sealed up under my layers. I'm not convinced it actually works the way I want it to (variable control) - off and and for sure. Just don't have a way to test out the variable aspect yet. Maybe I should work on that tomorrow.
The liners hook up to wires in the electric jacket liner so I think I'll be able to piggy back off of that for juice if I don't go the battery route.
I have considered a pants liner and ditched the idea until my last ride where the top of my legs got cold. Need to rethink that a bit. Most of the time it would be over kill - but when you need it you need it!
My wife bought the women's version of this jacket a couple of years ago. https://mobilewarming.com/men-s/jackets/...t-12v.html
It's from Mobile Warming, some of whose products are sold at The Warming Store (see Stichill's recommendation). It can run on battery or 12v. If I recall, the sleeve heating elements do not activate when plugged to the battery. My wife loves this jacket. In fact, she wore it to work today because it's a little chilly here.
I was originally looking for a 12v heated vest liner for on my bike and a waterproof, fleece-lined shell (ie Northface jacket) because I don't have a mid-weight winter jacket. I tend to like multi-tasking gadgets and gear, so I am now considering the Mobile Warming dual-power jacket for myself. It's a little pricey, but I'm getting two jackets in one (three, if I can golf in it) or their dual-powered vest. Thanks, Stichill, for posting about The Warming Store which got me thinking about multi-tasking apparel...very helpful.
Addendum -- I won't be getting the vest because I cannot connect gloves to it...well, maybe I could connect gloves to the integrated hookup for pants, but that seems cumbersome. Also, all of this assumes that I can plug in any glove with a compatible connector, which I think is true.
My heated gear is the stuff sold at Cycle Gear.
(02-07-2018, 11:50 PM)EmptySea_imp Wrote: My wife bought the women's version of this jacket a couple of years ago. https://mobilewarming.com/men-s/jackets/...t-12v.html
I wouldn't recommend a vest for riding because your upper arms tend to get the coldest...you need heat there.
The dual-power jacket is pretty cool. You could go to a wintry football game on battery power for example.
What are folks doing about their toesies? I don't think I need heated pants, but my feet do get cold. Battery-heated socks?
  Still the GOAT of Short Motorcycle Boots & Now Gloves: Indie Ridge rdprdp01 4 634 09-14-2025, 11:02 AM
Last Post: rdprdp01
  A-Pro Gear alexzanutto_imp 0 265 02-12-2022, 07:18 PM
Last Post: alexzanutto_imp
  Fly Ignitor Pro Heated Gloves GoldOxide_imp 60 5,936 01-09-2022, 12:23 PM
  Very excited for my new RSD F luck gloves PowerDubs_imp 8 789 09-15-2021, 04:46 AM
  Summer touch sensitive gloves rec? koehlerk_imp 11 961 08-09-2021, 02:02 AM
Last Post: tj_gee_imp
  Good deal on nice gloves - Scorpion Bixby Gone in 60 11 927 02-01-2021, 04:02 AM
  Anyone wearing Cortech leather gloves? Gone in 60 11 1,029 12-30-2020, 03:11 AM
  Held Titan Evo Gloves Houtman_imp 4 564 12-05-2019, 10:37 PM
  Leather gloves for touchscreen jasperc_imp 12 1,668 06-20-2018, 02:35 PM
  Hi Viz Gear 2017EX_imp 35 2,734 06-10-2018, 04:35 AM
