Fly Ignitor Pro Heated Gloves
This is my first heated gear. Typically when riding in sub-freezing temperatures I layer up the hands and insert "Hotties" pads into passive cold-weather leather riding gloves. This works to a point, but has a side-effect of too much bulk in the glove and limits flexibility. It also becomes ineffective at -20C plus freeway windchill since I do not use hand deflectors, nor large windscreens.
I have found hand deflectors at -20C + 110 km/h + heated hand grips (which I do not use either) ineffective after 15 to 20 minutes of exposure. In my case, the fingertips suffer first.
So here I am: Cable-less heated gloves (7.4V battery source).
Initial Review:
Source: https://fortnine.ca/en/fly-ignitor-pro-heated-gloves
PROS:
[ul] [li]The assembly and product fit and finish is excellent, ... better than I expected. The palm is leather and the top nice textile. My size (XL) fits as good and slightly more comfortable than my similar designed non-heater cold-weather riding gloves.[/li] [li]With heat off the gloves are about as good as my non-heated Five branded gloves.[/li] [li]Heat on Low: Within a minute I feel heat on top of my hand and around my fingers. For me, it is quite noticeable and I can see myself using this setting often. Its performance and comfort already exceeds my old passive layering ritual.[/li] [li]Heat on Medium: For me, the heat is on! This is very exciting. I cannot wait to test this on-the-road.[/li] [li]Heat on High: For me, this is quite hot. I can't see myself using this setting too often, however, I am glad it is available. Maybe I will need it and just don't know it yet.[/li] [li]When wearing the gloves, I do not notice the battery packs.
[/li][/ul]
CONS:
At this point, none. The gloves came with a decent storage bag, but I felt it really was not necessary.
Maybe the glove's red LED indicators are bright at night and could be distracting, however, maybe they will also improve visibility to others? Dunno.
So this is my initial assessment without riding. Electrical durability will also be observed, however, the expectation is it won't fail anytime soon. The heater elements are stainless steel and thus, resistant to flexing wear and tear.
Very nice. I think you will love riding with them. I usually double down with heated grips + heated gloves. Unheated grips still draw a lot of heat from your hands, even if you are wearing electrics.
(10-24-2019, 03:35 AM)Stichill_imp Wrote: Very nice. I think you will love riding with them. I usually double down with heated grips + heated gloves. Unheated grips still draw a lot of heat from your hands, even if you are wearing electrics.
I am hoping the Grip Puppies might mitigate such circumstances. I usually don't have palm problems, but likely contributes to other hand circulation issues.
That would help, especially on the left grip that is in direct contact with the metal handlebar.
I bought a pair of Joe Rocket gloves that look remarkably similar to these. Even the packaging is the same. They never got hot enough for me and I tried two different pairs. However, I do not have a windscreen or heated grips. I hope yours work better than mine did. Looking forward to the report.
Will do MTC. I suppose people will have varying tolerance to heat/cold and maybe my experience will be exceptional. We'll see!
I have a pair of these https://www.thewarmingstore.com/gerbing-...s-12v.html they get nice and hot
(10-23-2019, 12:39 PM)GoldOxide_imp Wrote: Fly Ignitor Pro Heated Gloves
Initial Review:
PROS:
[/li][/ul]
CONS:
how did I get in the middle of your text ..
Apparently ...
https://www.revzilla.com/motorcycle/fly-...es-battery
[size=mediumit looks like they don't make a charger for the bike.. maybe someone can do a work around that for G.O. or maybe he could do it himself ..[/size]
  Still the GOAT of Short Motorcycle Boots & Now Gloves: Indie Ridge rdprdp01 4 628 09-14-2025, 11:02 AM
Last Post: rdprdp01
  My new heated gear peterbaron 63 5,465 04-09-2023, 10:21 AM
  Very excited for my new RSD F luck gloves PowerDubs_imp 8 781 09-15-2021, 04:46 AM
  Summer touch sensitive gloves rec? koehlerk_imp 11 958 08-09-2021, 02:02 AM
Last Post: tj_gee_imp
  Good deal on nice gloves - Scorpion Bixby Gone in 60 11 913 02-01-2021, 04:02 AM
  Anyone wearing Cortech leather gloves? Gone in 60 11 1,021 12-30-2020, 03:11 AM
  Held Titan Evo Gloves Houtman_imp 4 557 12-05-2019, 10:37 PM
  Leather gloves for touchscreen jasperc_imp 12 1,661 06-20-2018, 02:35 PM
  Heated Gloves rboe 8 705 02-08-2018, 03:59 AM
Last Post: rboe
  Electric Gloves/gear Bheezy27403_imp 30 2,106 02-08-2018, 02:10 AM
