Does the CB1100 motor become smoother over time?
(03-12-2019, 12:17 PM)VLJ_imp Wrote: I hope it stays just the way it is now. No more changes for me, thank you.
Big Grin
GoldOxide, will do.
You sound rather ominous, btw.
Smile <<< Does that take the edge off? Tongue
Hmm, with ~10k miles on my DLX, the high frequency buzz is still pretty noticeable right at that 3800ish rpm range. However 80mph in 6th is below that and fine, and when riding hard I generally stay above it.
Pretty sure all bikes that aren’t a gold wing have some sort of vibration in their rev range - my V7 feels quite rough under 3500, and the big twin in my Tenere prefers to be above 4k. My F800gt started to feel like it was shaking apart above 5k. Of them all, the CB has the smallest vibration range.
I ride my CB a lot! Over 53,000 miles in 3 years. I’ve found it gets “buzzy” when it’s time to clean, lube and adjust the chain.
(03-13-2019, 03:27 AM)MMC_imp Wrote: I ride my CB a lot! Over 53,000 miles in 3 years. I’ve found it gets “buzzy” when it’s time to clean, lube and adjust the chain.
Interesting observation.
Does that imply after servicing the existing chain the buzziness subsides?
From what I’ve experienced, yes. It does subside after servicing the chain. Also keeping proper air pressure in tires helps.
Hi MMC,
I’m curious about the valve adjustments you have seen in that many miles?
Thanks
Hi MMC,
Thanks
Hi MMC,
Thanks
None. Never even checked them. Still runs like a top!!
Hi MMC,
Thanks
Hi MMC,
Thanks
Hi MMC,
Thanks That’s very interesting since on my 17 the owners manual calls for every 12k and the dealer I called quoted $675 that seemed pretty steep to me.
Hi MMC,
Thanks
Hi MMC,
Thanks
Hi MMC,
Hi MMC,
Yeah. I believe my service manual says to check them every 8,000 miles. From what I’ve read many people check them, or pay to have them checked and they didn’t even need adjustment.
Hi MMC,
Thanks
Hi MMC,
Thanks
Hi MMC,
Thanks
That is some sweet talk there MMC.
  motor cycle magazine subscription problems Houtman_imp 4 494 01-02-2021, 12:21 PM
  that pinging noise when you turn off the motor.... jedd_imp 24 1,354 04-06-2018, 05:17 AM
Last Post: VLJ_imp
  Hero motor corp Bheezy27403_imp 5 389 11-30-2017, 12:02 PM
  All Black Motor - Can you do anything with it? Wanka_imp 9 518 07-06-2016, 02:00 PM
Last Post: riceburner_imp
  Emissions for Motor Bikes activedirt_imp 12 815 10-29-2015, 10:39 AM
Last Post: rboe
  Tokyo Motor Show - New CB1100 Shinchan_imp 9 664 10-29-2015, 12:28 AM
Last Post: Shinchan_imp
  Vin# & motor # Ridem32_imp 17 1,052 05-12-2014, 10:10 AM
