Bazzaz Fuel Control ***Update 6/7/13***
thumper_imp Offline
Threads: 7
RE: Bazzaz Fuel Control ***Update 6/7/13***
(06-09-2013, 09:01 AM)Hytecredneck_imp Wrote: Thanks for taking one for the team Thumper!
Did they give any indication this would fix the 112mph speed limiter issue?
This is the text answer I just received:
"No, there's no way to get past the speed limiter on a bike that doesn't utilize a gear position sensor."
06-09-2013, 10:12 AM
Hytecredneck_imp Offline
New to the Forum
Threads: 0
"No, there's no way to get past the speed limiter on a bike that doesn't utilize a gear position sensor." I know theres a wire going to the rear disc and there is a small slotted disc over the brake rotor I assume that is the speedo sensor.
I will email the folks @ power commander and get their input on this issue.
What this all tells me is all the dyno runs on US models are null and void because of the incomplete data after the rear tire reaches 112mph..
06-09-2013, 10:19 AM
thumper_imp Offline
Threads: 7
Dyno testing is mapping the engine output, not the bike's gearing. You don't need to run a motorcycle through all of its gears for dyno testing.
I know my CBR1000RR wasn't run to 180mph while strapped to the dyno drum.
06-09-2013, 03:39 PM
New to the Forum
Threads: 0
There's a cycle world dyno run that shows the CB11 dropping off abrubtly @ 7100 rpms like it bounced off the rev limiter.
06-10-2013, 10:46 PM
Guth_imp Offline
Threads: 125
That's actually the dyno plot from the Motorcycle.com test. I believe Cycle World's plot looks a fair bit different.
06-10-2013, 11:10 PM
  Handlebar control symmetry Uncle Sixer 17 1,567 08-07-2025, 05:24 AM
  What cruise control are you using for your CB1100? goldeneye_imp 51 3,234 11-16-2023, 12:26 PM
  Anyone using the Kaoko throttle control? milkmaster_imp 50 2,967 07-12-2023, 06:45 AM
Last Post: milkmaster_imp
  An update on my spoke wheel conversion. FLYTYM_imp 20 1,199 06-17-2023, 02:09 AM
Last Post: FLYTYM_imp
  KAOKO cruize control ozigoo 6 525 05-27-2020, 01:14 PM
Last Post: 17-CB-002
  Foot Control Relocation Kit reinie_imp 6 570 01-10-2018, 12:13 PM
Last Post: Nightengale_imp
  Kaoko Cruise Control Kit 17-CB-002 12 755 07-19-2017, 02:10 PM
Last Post: Nortoon_imp
  Update on my new cheap Chinese levers uscgmac_imp 11 865 05-09-2016, 04:11 AM
Last Post: olekzap_imp
  Update on the bike StreetFighter_imp 25 1,730 07-18-2015, 10:19 AM
  Brake Away throttle control Razor 25 1,602 07-16-2015, 10:05 PM
Last Post: redbirds_imp
