New possibilities for 2013 and older CB1100 owners?
IndianRider_imp Offline
Threads: 8
RE: New possibilities for 2013 and older CB1100 owners?
(02-05-2014, 02:31 AM)dlhmatt_imp Wrote: Can i jam 6 gears in my case? That's really the only part of the 2014 that i care about.
Ditto !!
That's all I care as well ..
I loved the blacked out wheels/engine, triangular side panels, lower headlight/seat stance (silohoutte ?)
I was actually worried they would release an all silver engine and wheels so I picked up a left over 2013 real quick ..
The 5 speed gearing especially at freeway speeds is not really too bad .. I'll play around with a larger one tooth front sprocket when it's available and that should be a easy $20 mod instead of going for the 6th gear tranny ..
It will never be perfect with ratios so it's always a give and take and fine balance on your favorite twisties and freeways ..
02-11-2014, 02:59 PM
davidsargee_imp Offline
Threads: 6
Yep, me too. It's funny, when reading the tests, reviews, etc., on the 2013, they all said that the 5 speed was fine, "it doesn't need a 6th gear" was an oft repeated phrase among most of the journalists that I read.
I would like to have the 6th gear, for sure, but it's not that big of a want. The new ones are nice, no doubt about it, but I'm happy with what I have.
02-12-2014, 02:57 PM
SCCBrider_imp Offline
Threads: 27
Six gears would be nice, but do you think it would it be as rider friendly as the 5 speed? I have rolled on the throttle in 5th, as low as 30 mph and not had the slightest hick-up. I think I would like a larger capacity fuel tank.
02-15-2014, 12:30 AM
Likes Given: 753
I took 2 multi day multi state trips on my 13 and absolutely no issues with the 5 speed even running all day on the freeway...and the trans is the same on the 14, same ratios 1-5, so you could still be in 5 th gear at 30 mph and pull without a hitch. The only difference with the 6 th gear is that revs will drop from the same speed in 5 th...my guess by about 400 rpms. Ie if you were running say 80 miles per hour in 5 th at 5000 rpms, the 6 th gear will run that same speed at say 4600 rpms. Same effect if you put a one tooth larger counter or 3 tooth smaller rear sprockets. However gear the bike UP with the sprockets to run at lower rpms, and it won't take off from a stop as easy as before, however with the huge torque that the CB 1100 has that should not be an issue. The issue right now is finding someone who makes a 1 tooth larger counter for the 13s.
02-15-2014, 12:43 AM
MrTim_imp Offline
Threads: 11
(02-04-2014, 08:49 AM)Guth_imp Wrote: Looking over the information on Honda's website for the 2014 CB1100 models, it struck me that some of these changes could potentially impact current CB1100 owners as well.
For example, if Honda modified the center stand on the Deluxe model to accommodate the dual exhaust configuration, then perhaps this stand could be used on the older CBs to accommodate a number of aftermarket exhaust options that many were interested in, but weren't willing to give up their center stands .
In addition, those interested in creating a hybrid look would more than likely be able to use the new EX/DLX side panels on their 1st gen bikes. Same probably goes for the seat, turn signals and tank.
It will be interesting to see what people come up with as this year progresses.
Sent from my iPhone using [url=http://tapatalk.com/m?id=1]Tapatalk
Oh please, please let this be true. I'm planning on buying a set of Pipemaster four into fours and was pretty devasted that I'd have to get rid of the centrestand, if this is the case I might be able to have my cake and eat it too.
02-15-2014, 02:30 PM
Honda Lover_imp Offline
Threads: 4
#26
Here's another "I wonder." Is the '14 Standards headers double walled and would they easily fit on our '13?
02-21-2014, 11:51 PM
  Corbin owners, would you have it made differently? Ollie 29 1,972 06-12-2022, 12:15 AM
Last Post: Ollie
  Rear Rack for 2013 CB1100 Closeout Redbird_imp 4 488 07-21-2021, 11:34 AM
Last Post: tj_gee_imp
  2014 CB1100 EX Seat Fit On 2013 and Older Bikes SUPERCRUZ_imp 36 2,064 06-05-2021, 08:14 AM
  2013 CB1100 with Pipemasters 4 into 4 Creasy_imp 33 1,845 12-06-2019, 01:15 PM
Last Post: iamheero_imp
  2013 cb1100 power commander help 2000zx750r_imp 4 431 06-16-2019, 05:43 PM
  Question for '17 EX/RS Owners Flytech99_imp 14 960 03-09-2019, 06:44 AM
Last Post: will866_imp
  Installed red side covers on 2013 CB1100 Frulk_imp 15 1,163 10-05-2018, 02:54 PM
Last Post: Desert viper_imp
  Chip Beck Corbin Seat owners iamlegend21087_imp 6 514 08-29-2018, 07:12 AM
Last Post: bflint
  Honda OEM(Japan) topcase owners iamlegend21087_imp 3 402 06-25-2018, 04:30 PM
  2013 CB1100 Rear Shocks - Adjustable KYB Reservoir shocks - CHEAP! pekingduck 20 1,275 11-10-2017, 11:45 AM
Last Post: okredneck_imp
