Any interest in cams?
You may be better off having never been infected by whatever I caught at an early age.
Grew up on 1970's into early 80's 2-stoke dirtbikes. At that time the only real source of info was magazines- which wrote articles about stuff like DG or FMF pipes, rejetting carbs, suspension stuff... so I fell into the rabbit hole of 'I can make it better'...
Once you realize just about anything can be made better- at least me for, I like to do so.
I'll admit though- most of it was for the fun of doing it, and a tremendous waste of money in reflection.
I play with the bike for fun. I like doing things nobody else has done.
Smile
Back in the garage,
After measuring the clearances several times again on the new cams last night– I just uninstalled them and the buckets and now I get to do more math.
Gee whiz thanks, fun.
Really hoping for good results. Anyone want to take a guess? Start a pool?
[Image: dee238a54a941a4cf9370dd7c9570019.jpg]
My guess is that you'll gain about 8 hp, but it will run hot, so you'll use a Power Commander to develop a custom map to tweak the fueling, gain another 2 hp, and gain crisp throttle response with zero hesitation. Then everyone reading this thread will want to do it, and you'll have an opportunity to gain fame and maybe a little cash Wink
Not to criticize or dispute knowledge, modification or comments, I'll keep my stock Tongue
No cash for me. I have no association with the cam company, no skin in the game.
As for hot- well I will be fueling 'correctly' with no concerns to meet gov regulations so cool with fuel.
Also, the dynamic compression ratio will be less now- so less heat there.
I can only dream for 8+2, especially since I am not changing the factory ign timing or redline (for now).
I have my own # in my head I want to hit, but I'll stay quiet for now and let others play.
I promise I'll break 100whp as long as it doesn't mechanically grenade. Pretty easy since that would be less than a 2whp gain. Wink
Well- just sat down and did the math. Another delay as I will be ordering more shims.
Just ordered 9 shims from Honda online as I needed higher resolution than what the Hotcam kit can provide.
..so we wait again.
Hope my measuring is good- or we may wait again again on more shims even after this. I'd buy a bunch of izes to be safe- but they are not cheap, which is why I originally bought the hotcam kit trying to avoid all this- not knowing it does .05mm steps instead of .025 like Honda does.
PowerDubs,
I like your approach, keep up the detailed reports that I find quite interesting.
Question for the hp junkies. After you spend thousands of dollars and countless hours of your time in the garage to increase the power of a stocker, where will you go to race your bike? The local drag strip?
As luck would have it- I have a drag strip about 15 minutes from my house.
But- even though I have raced there countless times over decades, I have never taken a bike. It has always been cars.
I'd have to have Guhl flash the ECU first as the bike even stock will hit the speed limiter before the 1/4 is up (1320feet).
More power can be used for more than just 'racing'. As my bike sits now before cams I am over 98whp and 71wtq with no loss anywhere in the rpm. My friends joke that my front wheel is always in the air.
And then my friend on a modern sportbike passes me effortlessly at 12 o'clock.
This is all just for fun and to see what I can get out of it.
He did mention he is thinking of selling his sportier bike so he can buy 'a bike like mine'.
Total package is a good thing to work towards.
(08-01-2018, 07:56 AM)DBM_imp Wrote: Question for the hp junkies. After you spend thousands of dollars and countless hours of your time in the garage to increase the power of a stocker, where will you go to race your bike? The local drag strip?
Some do
https://www.youtube.com/watch?v=DSVt5GxUsl4
  Cams, Compression, Head Work? boynton6spd_imp 12 991 08-08-2021, 02:27 AM
Last Post: old blue_imp
  Oil Change interest? Scotty_imp 10 927 09-15-2020, 09:40 PM
Users browsing this thread: 16 Guest(s)
