Gas Mileage?
(07-10-2016, 01:17 PM)memphismike_imp Wrote:
(11-09-2014, 12:51 PM)Todd_K_imp Wrote: Hey Tim - heated gear... What a novel concept. I'd be interested in getting your recommendations - battery operated, or did you run an outlet off the bike?
Hope you're doing well!
Im a HUGE heated gear fan. Will be hooking up the plug to the CB1100 when winter approaches. Use it on my GoldWing and Shadow. Makes a BIG difference ! https://youtu.be/Hzbb6Q-OctE
I suffer with what they call white finger, even temps of 50 degrees and below my fingers will loose blood flow and go numb. I have the hotwire coat liner and the heated hotwire gloves. They work really well in keeping the white finger in check, allowing me to ride clear down into the lower 30's. I am very satisfied with them. I've never had to go above medium heat setting with the gloves and coat liner.
Kevin
Kevin
Kevin
I absolutely LOVE it Kevin. Sounds like it woks very well for you too!
2014 Model. Just filled up. about 43.5mpg. The Speedometer said Average was 45.9mpg. I have gotten 49-52mpg. On a Backroad taking it easy about 50mph or so.
Going through this thread, I have to say that I've been on the way lower end of poor mileage (low 30s city and low 40s highway). I do have to calculate mileage by hand as I've got a stock '13 so rate of error is inherent, but I'm pretty good with math. Over the past couple of months my mileage has upped significantly as i'm getting around 44mpg in the city and 55 highway. My riding style hasn't changed nor my routes, should I just shut up and be happy about it?
I contemplated starting a new thread, but since this thread already has some good information, I figured I'd just add to it.
I was consistently getting between 40 and 42 mpg on my 2014 Std 6 speed.
I weigh about 230 lbs and do mostly suburban driving, ie., average speeds between 35-45 mph but a fair amount of stop signs and lights.
This Spring I changed the oil out from Honda "dino" 10w40 and went with Rotella T6 15w40 full synthetic. My gas mileage immediately improved to 46-48 mpg... And it's been consistent.
Until last week... Yesterday I measured 52 mpg!
That's both by pen and paper and the built-in mileage calculator.
I have another bike that was acting like it had dirty fuel injectors, so I got some Techron injector cleaner for the other bike and it cleared things up.
I had half a bottle of Techron left over, so I dumped it in the CB1100 with a fresh tank of gas.
I had absolutely no apparent issues with the fuel injectors on the CB1100, but it seems like the Techron did some good. 52 mpg is an all-time high for me, and we'll see if it remains consistent.
FWIW, The 15w40 makes the valves a bit louder compared to the 10w40, but I did experience about a 10% mileage improvement immediately following the change to Rotella 15w40.
I know, correlation does not equal causation, and the slightly noisier valves are making me consider a Rotella T5 10w30 for next year, but I'm fine with the T6 15w40 for now.
That is believable Yata.
I used T6 5W40 and got 4.5 L/100 kms for level warm season riding on the CB1100 in southern Ontario. Very spirited riding I still got 5.0 L/100 kms which is still very good and directly comparable to your figures.
Not my normal riding, but ultra conservative on 80 km/h back roads I could manage 3.9 L/100 kms.
Thanks for the reply!
I never thought of calculating liters per 100km.
Even in Japan I believe it's just a straight kilometers per liter measurement.
This will come in handy next time I need to do a fuel economy conversion...
https://www.calculateme.com/gas-mileage/...-to-us-mpg
(07-26-2022, 04:04 PM)Yata-Garasu_imp Wrote: Thanks for the reply!
km/L makes sense to me, but most of the metric western world seems to use L/100 kms.
(07-26-2022, 02:34 AM)Yata-Garasu_imp Wrote: I contemplated starting a new thread, but since this thread already has some good information, I figured I'd just add to it.
I have used Shell Rotella T6 synthetic 5W-40 in all my bikes for years now, including an ST1300, Bonneville, Tiger 1050, 2 V-stroms, 2 CB1100s and now 2 NC 750's. The greatest difference noted was in a CB1100 that constantly balked on 3rg gear engagement; I had been using the Honda synthetic 10W-30 during the warranty period and thought that getting it broken in would clear it up. After switching to the Rotella the 3rd gear problem cleared up immediately.
I see a lot of people here have used the T6 5w40, but after a visit to the "Bob is the Oil Guy" forum, I decided to go with the 15w40 due to its resistance to shearing.
From my understanding, the downside to using oil that's too thin is premature cam wear, which won't show itself until it's too late.
I'm absolutely convinced that the 15w40 is the correct weight and viscosity for my VT750 Shadows, but it does add some valve noise to my CB1100.
I'm considering the Rotella T5 10w30 for my next oil change interval, but since the T6 15w40 seems to be giving me good results otherwise, I plan to leave it in for 4k miles.
  High mileage and oil consumption Jurlie_imp 24 2,345 04-07-2023, 06:05 AM
  Nasty Decel Pop poor gas mileage adogsnyder99_imp 18 1,446 06-30-2021, 07:17 AM
  Tire Mileage Billie_imp 25 2,437 03-13-2021, 04:18 AM
Last Post: Scotty_imp
  The actual required services by mileage Streetshark07_imp 5 488 06-29-2019, 07:58 AM
Last Post: SportsterDoc
  Resetting tripmeter and fuel mileage meter White Dog_imp 3 374 08-04-2015, 10:36 PM
Last Post: White Dog_imp
  Tire mileage Ghost_diver_imp 23 1,311 06-13-2015, 02:08 AM
Last Post: Wisedrum
