New Headlight Bulb
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: New Headlight Bulb
Yes, I have the FendaExtenda by Pyramid plastics and so do a number of us. It works very well and you do not have to drill and rivet. You can bond it on with your favorite adhesive. Some have used epoxy. I used 3M5200 fast cure, a marine adhesive.
02-22-2015, 10:29 PM
Honda Lover_imp Offline
Threads: 4
New Headlight Bulb
(02-05-2015, 09:37 PM)Honda Lover_imp Wrote: I was recently researching some LED headlight options to brighten up the front and increase visibility to other motorists. I often read while an LED bulb gave off more light, beam length and dispersion varied depending on the type of reflector housing and shape of the bulb. Rather than chance LED and install another relay, I went the most certain route and purchased a Piaa H4 Extreme White Plus 55watt halogen bulb. Piaa part number 15224. Same actual wattage as stock) I actually bought a 2 pack for $55 w/free shipping off eBay as I installed one in my 08 VTX1800 T as well. It accomplishes exactly what I was looking to do with an easy install. Take a look at before & after photos. It's a whiter, longer casting beam. Almost has an HID look. 15"+ of snow will prevent a road test until Spring buy it passed the "garage test" .
Bulb part number update & correction: The correct Piaa bulb for motorcycles is Piaa bulb 70456 which features the anti vibration feature. The Piaa 15224 bulb stated in my original post has the correct wattage and fitment, however it was designed for automobiles and does not specify the anti vibration feature for motorcycles. If you like this type of lighting for your headlight, be sure to order the motorcycle specific Piaa 70456 bulb.
03-29-2015, 10:36 PM
Ghis_imp Offline
Threads: 31
What kind of saddle bag / set up do you have on?
03-31-2015, 01:49 PM
Threads: 4
New Headlight Bulb
I ordered the slant pair of chrome saddle bag CB1100 brackets from Samurider (Willie & Max) and only installed left side for a Solo bag look. I had the leather Solo bag custom made by a company called Leatherworks out in CA. It's high grade leather with red stitching to match the red stitching in the seat and quick release Buckle. It's just large enough to fit tools, rag, spot/bug cleaner, gloves, and other small items. The bag is 14" w x 12 L x 3" d. I made my own custom inserts/cuts in the back of the bag where heavy gauge lock straps secure to the saddlebag solo bracket. It works well for me, easy to install and holds the bike to a vintage 70's look.
04-01-2015, 09:15 AM
  Headlight for 2017 deuce17EX 2 525 04-15-2025, 08:54 AM
  LED Headlight Upgrade Peddlin' Slow_imp 67 5,241 02-07-2024, 09:59 AM
  Worst headlight ever. Whoops 14 1,354 01-15-2024, 07:01 PM
Last Post: jtopiso_imp
  LED Headlight? 2014ltdltz 16 1,501 06-21-2022, 01:36 AM
  LED headlight bulb fitment Gone in 60 13 985 07-22-2019, 09:19 AM
  Headlight Modulator On a 2017 EX? Paris_imp 2 388 10-23-2018, 05:59 AM
Last Post: Paris_imp
  Moriwaki headlight bracket. misterprofessionality 35 2,254 10-07-2018, 12:37 PM
  ‘17 chrome headlight bucket on my ‘14 PowerDubs_imp 18 1,182 08-19-2018, 12:50 AM
  New LED headlight and bucket Mscb1100_imp 4 501 12-03-2017, 04:06 AM
Last Post: Mscb1100_imp
  Easy Headlight Upgrade to LED jackhammer50_imp 28 2,003 06-22-2017, 10:47 AM
Last Post: Jim21680_imp
