Easy Headlight Upgrade to LED
jackhammer50_imp Offline
Threads: 1
If you are wishing you had an LED headlight like the new EX's, take a look at this.
https://www.cyclopsadventuresports.com/7...p_169.html
I have installed this LED to my bike and all I can say is WOW! Plug and play.
I also have these bulb replacement LED's on my Beemer too.
Twice the light than stock.
And it doesn't get much easier.
02-13-2017, 01:44 PM
Elipten_imp Offline
Threads: 13
Is there enough space in the headlight bucket to get all that in the bucket?
02-13-2017, 03:29 PM
olekzap_imp Offline
Threads: 9
RE: Easy Headlight Upgrade to LED
I have the one linked below. It's decent, quite a bit more light than the standard bulb. The patter is OK, not perfect but it's not blinding to others and definitely lights up the road better than stock. I am really looking to get the LED headlight with the correct projectors that the new CBs have, though. Anyone know if those are available yet?
http://stores.advmonster.com/h4-r3-led-headlight/
02-14-2017, 02:03 AM
Threads: 1
(02-13-2017, 03:29 PM)Elipten_imp Wrote: Is there enough space in the headlight bucket to get all that in the bucket?
02-14-2017, 02:35 AM
Ridem32_imp Offline
Threads: 51
Good find
02-14-2017, 02:49 PM
AzBob_imp Offline
Threads: 6
I'm relatively certain, as with most LED bulb replacements with reflectors made for halogens, the light scatters all over the place and doesn't really shine down the road very much. It may SEEM like there's a ton of light, but it's all over the side of the road, not down the road where you need it.
02-16-2017, 04:36 AM
use2b_imp Offline
Threads: 39
(02-16-2017, 04:36 AM)AzBob_imp Wrote: I'm relatively certain, as with most LED bulb replacements with reflectors made for halogens, the light scatters all over the place and doesn't really shine down the road very much. It may SEEM like there's a ton of light, but it's all over the side of the road, not down the road where you need it.
you are exactly right and that is why so many cars [ mostly kids in ricers ] have that annoying blinding light.
04-07-2017, 09:37 AM
hdvalente_imp Offline
Threads: 3
(02-14-2017, 02:03 AM)olekzap_imp Wrote: I have the one linked below. It's decent, quite a bit more light than the standard bulb. The patter is OK, not perfect but it's not blinding to others and definitely lights up the road better than stock. I am really looking to get the LED headlight with the correct projectors that the new CBs have, though. Anyone know if those are available yet?
I was planning to upgrade mine with the 2017 CB1100 LED headlight, but after contacting Mr. Takashi (Samurider), he said that they will be about 100,000 Yen ($900) and he is not sure yet if they are a direct fit to older models.
I ordered this one instead:
https://wholesaler.alibaba.com/product-d...05962.html
I should receive it this weekend and then I will post pictures and impressions.
04-26-2017, 07:25 AM
Ferrealls_imp Offline
Threads: 17
There's something about the 2017 headlight that bothers me. I can't quite place it, but it has to do with the set of bezels and the inner LED ring. Almost makes it look like a standard lamp housing retrofitted to take a projector. Reminds me of something someone would throw together to make it work, without regard for aesthetics.
The motodemic evo 2 with the Triumph bucket was a fairly easy install and gives off great light. Then again, the individual LED projectors might not be everyone's cup of tea either.
04-26-2017, 08:27 AM
Ridem32_imp Offline
Threads: 51
Good find. Hope it works well
04-26-2017, 09:46 AM
  '17 Grabrail Upgrade for '14 HigginsNYC_imp 26 1,797 08-15-2026, 04:11 AM
Last Post: fabrimtb
  swing arm upgrade rtmoto1 8 501 03-09-2026, 09:31 AM
  Rear Suspension upgrade 17-CB-002 3 351 02-22-2026, 09:41 AM
Last Post: 17-CB-002
  2017 Fork Spring Upgrade deuce17EX 2 495 04-15-2025, 01:37 PM
Last Post: deuce17EX
  Headlight for 2017 deuce17EX 2 551 04-15-2025, 08:54 AM
  Speedometer Upgrade!? DirkDiggler_imp 12 1,278 02-23-2025, 04:57 PM
Last Post: Jurlie_imp
  LED Headlight Upgrade Peddlin' Slow_imp 67 5,696 02-07-2024, 09:59 AM
  Worst headlight ever. Whoops 14 1,463 01-15-2024, 07:01 PM
Last Post: jtopiso_imp
  LED Headlight? 2014ltdltz 16 1,598 06-21-2022, 01:36 AM
   BEST Cheap Headlight Upgrade for the CB1100 BE WELL SEEN IN THE DAYLIGHT! Havasu Secret_imp 18 1,580 02-25-2022, 12:16 PM
Last Post: Scoot_imp
