SW MOTECH crash bars & hwy pegs
jedd_imp Offline
Threads: 27
RE: SW MOTECH crash bars & hwy pegs
Thanks for the JB weld tip. I'll do just that.
Did you remove the front fender to apply the glue and clamp?
If so, was the fender easy to take out and put back on w/out removing the wheel, I hope?
02-23-2016, 06:52 AM
Django Offline
Threads: 71
Likes Given: 20
(02-23-2016, 06:52 AM)jedd_imp Wrote: Thanks for the JB weld tip. I'll do just that.
Yes. It is very easy to dismount, basically 4 screws.
02-23-2016, 07:03 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 211 in 121 posts
Likes Given: 155
Jedd, it was a joke!
I have the Fenda Extenda too. I did remove the fender for Fenda installation (see what I did there? Smile )
It is easy to remove and reinstall. By removing it, you will be able to properly clean the inside surface so whatever adhesive you use will bond properly. Personally, I cleaned mine and then wiped it with acetone to remove any grease. I may have roughed up the inner surface some too. I did wipe the Extenda surface with acetone to deglaze it, and then scored it some to aid in adhesion. But, I tend to be a little anal sometimes. OTOH, it's been on there 3 years and is fine.
A number of us have used different stuff, like the JB above, some epoxy,etc. I used marine 3M4200 or 5200 (can't remember) and clamped it until set. Comes in black or white. I would advise against using silicone.
Done nicely, it will look just like the above pic and will last forever.
02-23-2016, 07:06 AM
Rocky_imp Offline
Threads: 26
(02-23-2016, 07:06 AM)Lord Popgun_imp Wrote: Jedd, it was a joke!
Not anal in the least. That's exactly how I did it too and used clamps while it cured overnight Thumbs Up Thumbs Up
The extenda on my other Honda has been on there for 12 years and hasn't moved. As stated above, preparation of both surfaces is the key.
02-23-2016, 09:09 PM
Lord Popgun Offline
Virginia
Likes Given: 155
In my above post to Jedd, the joke thing was supposed to be in about using JB on an KN oil filter nut. I must have gotten confused about what thread I was in Blush
Sorry about that. Undecided
02-23-2016, 10:34 PM
capttwb136_imp Offline
Threads: 12
That 3M 5200 will never come off!! You better be sure you'll never want to take it off. Especially if you use Popguns method! :-)
02-23-2016, 10:52 PM
Ltrypsin_imp Offline
Threads: 2
(02-23-2016, 10:52 PM)capttwb136_imp Wrote: That 3M 5200 will never come off!! You better be sure you'll never want to take it off. Especially if you use Popguns method! :-)
There is a way.. https://store.marinebeam.com/3m-5200-sea...e-remover/
02-23-2016, 11:26 PM
Lord Popgun Offline
Virginia
Likes Given: 155
Ltrypsin,
I never saw that before. Good to know!
Do NOT use 5200 to mount outboards. If you do, you might have a problem dismounting them... Been there done that at my friends shop. Don't use silicone either, won't hold a bond on fiberglass for long.
I used it on the Extenda as it is a marine product and it does get wet under the fender at times Smile
I also made sure to seal around the inside surface nicely so that no water could get between the Extenda and the metal to prevent corrosion.
02-23-2016, 11:38 PM
Rocky_imp Offline
Threads: 26
(02-23-2016, 11:38 PM)Lord Popgun_imp Wrote: Ltrypsin,
Good tip Thumbs Up Thumbs Up
I did that too.
02-24-2016, 12:12 AM
  SW-Motech Top Case (All CB1100 Models) rdprdp01 2 589 08-20-2025, 06:25 AM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 1 420 04-12-2025, 08:57 AM
Last Post: 17-CB-002
  SW Motech Pro Blaze Honda CB1100 Saddle bags for sale CAN$350 peterbaron 3 537 02-07-2025, 01:01 AM
  Fehling crash bars Newceebee_imp 13 1,162 02-03-2025, 11:47 PM
   Foot pegs Nick_imp 3 491 01-02-2025, 04:14 AM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 11 1,217 11-03-2024, 05:24 AM
Last Post: WRXer_imp
  SW Motech evo racks question 12milesout 6 816 05-07-2024, 06:55 AM
  Crash bars question from Biker Dave the Ferret 36 3,198 06-14-2023, 02:35 PM
  SW Motech soft panniers Ollie 19 1,920 06-03-2023, 01:52 AM
Last Post: mpuhl_imp
  3D printed strap adapters for the CB1100 mounting pegs LayerCake_imp 33 2,815 07-10-2022, 12:04 AM
Last Post: 1973cb750
