Battery tender
(01-28-2020, 01:28 AM)jedd_imp Wrote:
(01-25-2020, 11:35 AM)NickLHG_imp Wrote:
(01-25-2020, 11:31 AM)Houtman_imp Wrote: Your batterie is a 12 volt one and I like the Optimate / Tecmate batterie chargers . Check them out online.
sweet thank you. Another question for you.. my 2014 dlx just arrived today. Is it a CB1100 SA AC? Or it is a CB1100 AC? I’m looking at some oem parts on Babbits.com.
If I’m correct it’s a CB1100 SA but I’m not sure exactly what the AC is.
I get confused almost everytime I go to look for DLX oem parts.
NOw after the parts loads up, I view "EXHAUST" category, and see if qty=2 . This helps me confirm that I'm viewing the DLX parts fische.
A couple yrs ago when my oem battery died, i sprung for the lithium battery. no more battery tender! Beer
Wait.. you won’t need a battery tender if you use a lithium? Didn’t know you could use a lithium battery at all. Do you happen to have a link of the battery that will work with the dlx? Definitely interested one day.
My bike is now 6 years old with 3406 miles on it, how often do I replace the battery? Every someodd years or x miles?
Thanks for the help guys. I ordered the tender off jpcycles.. will be returning when I get it as I’ll be able to purchase 25.00 cheaper on amazon. Should’ve done more research before purchasing.
This is the one I bought for my dlx in jan 2018.
[url=https://www.ebay.com/itm/WPS-Featherweight-Lithium-Battery-HJTZ14S-FP-IL-HJTZ14S-FP-IL/231758656505?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649]Click here
I, like many of the other members, use a Battery Tender Junior 12V to keep the batteries in my CB and Monkey charged. The brand has been around for a long time, and I have found it to be very reliable. Currently Amazon has the Battery Tender Junior for $24.95.
Just like the battery tender, do your homework first before plunking down your hard earned cash. I had contemplated going with a lithium ion ( LI ) battery when the time comes to replace the stock Yuasa lead acid ( LA ) battery in my CB. You can read the results of my research here: http://cb1100forum.com/forum/showthread.php?tid=14995 . I am not knocking the LI batteries, or anyone that chooses to use them, just make an informed decision. From what I found out, I decided to stay with the stock Yuasa, but draw your own conclusions after doing the homework. I would recommend 2 things if you decide to go Lithium Ion: 1.) Only consider LI batteries that have a built in battery management system ( BMS ) as not all LI batteries have it. 2.) Buy and use only a dedicated LI battery tender, or a charger/maintainer specifically made for use with LI batteries.
2017EX speaks wisely. Do your research. Only buy LI with built in BMS and use a LI specific charger.
And understand how they work. When temps drop, you may have to run the headlight for a time to warm the battery before it will start the bike.
Disclaimer: I use OEM Yuasa batteries in my bikes.
(01-28-2020, 08:58 AM)Lord Popgun_imp Wrote: 2017EX speaks wisely. Do your research. Only buy LI with built in BMS and use a LI specific charger.
Seems like it’s easier to use OEM like I originally intended. That is what I shall do.
After you replace the battery, start the bike and meter the battery to ensure the charging system is working.
My current 2019 ride came with OEM lithium battery.
Tiny battery.
That’s interesting, GO.
(01-28-2020, 09:26 PM)Cormanus_imp Wrote: That’s interesting, GO.
Thx. If I learn about anything odd, I will indeed share. So far, uneventful (which is good).
G . O . Is that the A.T. ? with that battery?
  Die Hard Battery Tom_imp 5 481 05-07-2022, 03:21 PM
Last Post: Tom_imp
  Battery issues NickLHG_imp 5 459 07-08-2021, 02:00 AM
Last Post: Tom_imp
  Battery charger brand & size Brady Bourgeois_imp 15 1,109 07-20-2020, 12:41 AM
Last Post: venturer434_imp
  Level of battery charge ohiorider_imp 28 2,193 11-21-2019, 01:23 PM
  Battery question warman_imp 21 1,616 10-13-2019, 01:20 AM
Last Post: warman_imp
  Battery issue paulw_imp 12 706 08-02-2017, 03:06 AM
  What if... you don't keep your CB on a tender? ride4now_imp 13 897 08-22-2016, 03:11 PM
Last Post: riceburner_imp
